Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
VIRGIN PRIME GUARD POF-241 CUT OPEN
by 53' Stude - 04/05/20 12:57 PM
What makes music CD-Rs go bad?
by aquariuscsm - 04/05/20 12:42 PM
what would you do
by FT92 - 04/05/20 12:17 PM
Fram Xg3682 for ISO 32 🛠
by SavagePatch - 04/05/20 11:58 AM
Honda V6 PCV Valve - Steel Bolt
by SWS - 04/05/20 11:50 AM
Ford Fusion wiper blade question
by Corollaman - 04/05/20 11:05 AM
Is this stainless steel?
by atikovi - 04/05/20 10:45 AM
Skyactiv 2.5L - Oil Capacity
by buster - 04/05/20 10:42 AM
khouan, daniell, carguy1701, London, Dave66
71105 Registered Users
108 registered members (2015_PSD, 07titan, 762fermeandyou, acmesupply, AandPDan, 2002 Maxima SE, 11 invisible), 2,701 guests, and 19 spiders.
Topics303,643
Posts5,238,980
Members71,105
What sort of ATF and is Merc V synthetic? #5355489 02/20/20 01:37 PM
Stinky123 Offline OP
I just bought 2 cars. So, the 1st thing I want to do is change all of the fluids.
#1...99 Corolla. The Owner's Manual (OM) says that the trans uses DeX III.
#2...96 Mercury Villager. The OM says Merc. What the heck, it is actually a Nissan Quest. My Repair Manual (RM) says DeX III.
I had a bunch of MercV and the bottle said that it would work for Merc and DEXIII...so far so good in the Villager.
I go to Napa and the counter guy says that Merc V is synthetic replacement for those? Dat Tru?
What would you use for them?
Also, is it Merc Vee or Merc5?
John 14:6
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5355503 02/20/20 01:48 PM
J
Jackson_Slugger Online Content
Online Content
J
I highly doubt it. Mercon V supposedly allows for a little more friction while shifting, which is why Ford products can have issues with Dex III. Lubegard specifically makes a additive for this, the green bottle one.
My guess is that it's considered a blend...
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5355506 02/20/20 01:54 PM
K
kschachn Offline
K
On those vehicles I'd be using either Maxlife ATF (if I felt like spending the money) or Super Tech Automatic Transmission Fluid (if I felt like saving money). Both will work in both vehicles. You don't need a separate additive or different fluids for one of the cars.
MERCON-V was not listed as backwards compatible with DEXRON-III so that is why the two listed fluids were interchangeable at the point your vehicles were built.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5355551 02/20/20 02:38 PM
E
exranger06 Offline
E
Mercon V is not necessarily synthetic. Most of them that I've seen are only synthetic blend, and I believe that even the Motorcraft stuff is synthetic blend. That being said, Mercon V IS the replacement for regular Mercon. Ford considers regular Mercon to be obsolete and says that Mercon V supersedes it. So any transmission that originally specified regular Mercon should be able to use Mercon V no problem.
And Dexron III is/was the exact same thing as regular Mercon, which is why you always see bottles of ATF that say "Dexron III/Mercon" or "Dex/Merc" for short. "Dexron" is a registered trademark of GM, and Mercon is a registered trademark of Ford. They literally had different names for the same fluid. So it stands to reason that any transmission that originally specified Dexron III could also use Mercon V.
Now, to further confuse matters, Dexron III is also an obsolete spec. GM replaced it with Dexron VI and says to use Dex VI in all transmissions that originally called for Dex III.
Even though the old Dex III was the same as regular Mercon, Dexron VI is NOT the same as Mercon V.
So, if you want to use a "modern"/latest spec fluid, should you use Mercon V or Dex VI? shrug Your call I suppose. Personally, I'd just use a generic "Dex/Merc" fluid and call it a day. There's plenty of selection, from a cheap conventional store brand, to a full-synthetic name brand. They'll all likely work just fine in your vehicles.
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: What sort of ATF and is Merc V synthetic? [Re: kschachn] #5355643 02/20/20 03:55 PM
B
bbhero Offline
B
Exactly right here ^^^^
I have Coastal Dex Merc ATF to go in my lady's Camry here in a bit ....
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5355648 02/20/20 03:57 PM
B
Black_Thunder Offline
B
I have a couple Fords that take the Mercon V and others that take regular Mercon.
I know they've listed the V as being backwards compatible but I've just decided to go with what the dipstick says and keep them seperate and use Dex/Merc on the older stuff and Mercon V on the newer.
Also there were some different transmissions in the same time frame that had different ATF's spec'ed like the 4R70W transmissions in the late 90's were speced for Mercon V while the 4R100 were speced for regular Mercon, gets confusing.
Anyways to sum up laugh I would just go with Maxlife Dex/Merc and make it easy.
I'd buy Callahan autoparts if I could.
Re: What sort of ATF and is Merc V synthetic? [Re: Jackson_Slugger] #5355676 02/20/20 04:16 PM
MolaKule Offline
Global Moderator
Global Moderator
I would NOT use a conversion fluid for various reasons.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: What sort of ATF and is Merc V synthetic? [Re: kschachn] #5355708 02/20/20 04:41 PM
W
Wolf359 Online Content
Online Content
W
I would just use Supertech Mercon V. Has the Ford certification on it. Maxlife doesn't and it's just suitable for multiple applications. It just makes sense to get the right fluid for the right application.
Re: What sort of ATF and is Merc V synthetic? [Re: Wolf359] #5355784 02/20/20 05:35 PM
B
bbhero Offline
B
It could just take a regular Dexron III / Mercon in both vehicles here...
My lady's Camry that's a 98 uses Dexron III like the Corolla mentioned...
Though I think you are right in that a Mercon V should be fine too... Ford did back spec Mercon V for older Mercon applications is that correct wolf ??
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5364019 03/01/20 08:06 AM
K
Kira Offline
K
How much (bunch?) Mercon V did you buy Stinky123?
I recently bought a Mercon specced '05 Ford vehicle and read Mercon V is now the stuff to use. Board members blithely suggested getting "a synthetic Mercon V". After looking high and low I conclude there is no synthetic Mercon V.
Synthetic BLEND Mercon V, yes.
I just loaded up on Car Quest brand and Super Tech (Walmart) brand Mercon V.
My 15 year old vehicle's shifting improved noticeably with a drain & fill.
I say go through your stock of Mercon V then get more of whatever you need when the time comes.
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5367796 03/05/20 08:04 AM
dwcopple Offline
Mercon V is what my 98 Stang GT is spec'd for. I have used the Carquest stuff from Advance. I would love to find a reasonably priced synthetic alternative but I guess for now, I'll keep using plain ol' Mercon V.
2017 RAM Big Horn 4x4 3.6L V6
2011 Chrysler 200 Limited 3.6L V6
Re: What sort of ATF and is Merc V synthetic? [Re: Stinky123] #5368647 03/06/20 06:20 AM
K
ka9mnx Offline
K
I looked into this when I purchased my 4Runner which requires DEX III. I decided to use Mercon V for my Ford's and 4Runner. No problems.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
