Get your physicals done people
by BeerCan - 03/29/20 08:41 AM
2004 Silverado
by mjk - 03/29/20 08:29 AM
Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
99 registered members (2K2AcuraTL, 4WD, 53' Stude, alarmguy, Alaskanmont, 007, 9 invisible), 1,935 guests, and 20 spiders.
Topics303,305
Posts5,233,638
Members71,038
redline 75W140 #5354605 02/19/20 03:50 PM
M
mobilaltima Offline OP
M
It's time to change the oil in the rear end of my 2012 F-150 work truck that I recently bought. Its currently sitting at 156, 530 miles and I'm not sure if the previous owner ever changed it. its a 2wd with the 3.7 V6. I,m trying to figure out if its limited slip or not, giving the local dealer my VIN was no help. Anyway, Im considering running Redline 75W140 and changing it every 50-100k miles. I picked up a 4 oz bottle of the Motorcraft XL-3 friction modifier, in the event that it is limited slip, I'll have it when I'm ready to change it.
Asssuming that the Redline already has the LS additive in it, will it hurt to add the XL-3? I plan on scraping off the factory silicone and using a Lube Locker gasket. It has a 10 bolt cover, would anyone know the torque spec? Would it be better to buy a gallon of Redline off Ebay or Amazon?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: redline 75W140 [Re: mobilaltima] #5354615 02/19/20 03:59 PM
V
vw7674 Offline
V
You can get both rear tires in the air, turn one tire & watch the other.
If the other tire turns in the same direction as the one you're spinning, it's a limited slip unit, turns opposite, open diff.
At least that way you will know if you need a friction additive..........
Re: redline 75W140 [Re: mobilaltima] #5354620 02/19/20 04:03 PM
Cujet Online Content
Online Content
A quick and dirty test is to rotate one rear wheel while in park (parking brake off) , and in the air. If the opposite wheel rotates the opposite direction, it's an open differential. If no rotation happens, it's a limited slip.
The exception to this test is the rare Torsen differential, which acts as an open differential until power is applied and both tires have traction, then it locks up. You don't have a Torsen.
Re: redline 75W140 [Re: mobilaltima] #5354632 02/19/20 04:12 PM
cb_13 Offline
Check the axle code on the vin tag. Ford uses a letter as the first digit on limited slip and a number as the first on open differentials. The only exception is L it is used for the electronic locking. So examples 86 would be a 3.73 open diff b6 a limited slip 3.73 diff and L6 for a 3.73 with an e locker.
Re: redline 75W140 [Re: mobilaltima] #5354673 02/19/20 04:49 PM
ls1mike Offline
Why so heavy on the gear oil? Just wondering.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: redline 75W140 [Re: mobilaltima] #5354713 02/19/20 05:49 PM
M
M
My axle code is 26, so it appears I have a Dana 60, 3.55 gears, open differential. I'm not complaining, no limited slip additive to worry about.
ls1mike, 75W140 is the spec'd fluid for my truck and most F-150s for quite a few years. I'd like to know as to why they use 75W140, versus most GM 1500, 2500 and 3500s calling for 75W90.
Re: redline 75W140 [Re: ls1mike] #5354714 02/19/20 05:51 PM
RDY4WAR Online Content
Online Content
OEM is 75w-140.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: redline 75W140 [Re: mobilaltima] #5354715 02/19/20 05:51 PM
M
M
cb_13 , thanks for reminding about the axle code on the VIN tag
Re: redline 75W140 [Re: mobilaltima] #5354720 02/19/20 05:53 PM
ls1mike Offline
That was why I wondered. I have a 3500hd. Interesting. Not sure why the difference. Thanks!
Mike
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: redline 75W140 [Re: mobilaltima] #5354787 02/19/20 07:16 PM
B
benjy Offline
B
looking at the dana web site when i changed my frontiers drivetrain lubes shows they recommend a real synthetic 75-90 which redline is! the cheap OE Nissan lube is a 75-140 semi-syn for the nissan-dana 60 in it so i opted for the redline 75-90 + it requires NO xtra additives that could upset their chemistry. using all redline lubes netted me about 4 mpgs! my 6 spd manual 4.0 4 WD 2011 fronty king cab was averaging 19 mpg when i checked in the summer, VERY pleased!!
Re: redline 75W140 [Re: benjy] #5354805 02/19/20 07:33 PM
R
Rand Offline
R
uh what? if that was true redline would have been bought by a car manufacturer and it would be an OEM fluid. Auto manufacturers spend billions searching for a mpg. I am a redline fan but that is physics defying.
Re: redline 75W140 [Re: mobilaltima] #5355158 02/20/20 08:01 AM
J
jeepman3071 Offline
J
75w140 is supposed to hold up better for towing. I know in my Jeep's owner's manual it says to use 75w140 in the Dana 44 rear axle when towing, and have seen that recommendation in other owner's manuals also.
I use Redline in the diffs of all the vehicles I service. The last time I did a diff fluid change on a friend's vehicle I used Redline in previously, the Redline had been in there for 50k miles and looked brand new. I actually wished I had left it in there.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (60k) - Liqui Moly 5w40, MANN HU816X
Re: redline 75W140 [Re: mobilaltima] #5355310 02/20/20 10:44 AM
M
M
my mistake I dont have a Dana 60, its a Ford 8.8 rear. Would anyone have the torque specs for the diff cover? I'm getting various answers of 25 ft lbs, 33 ft lbs, and 28-38 ft lbs.
