Shimmy on the Hiwy
by Char Baby - 03/29/20 06:06 AM
10w40 over 5w30 diesel
by angryorc - 03/29/20 03:20 AM
Clover Overseeding.
by GumbyJarvis - 03/29/20 01:52 AM
Crawfish Boil
by BlueOvalFitter - 03/29/20 01:09 AM
Crude Pricing Dynamics
by Y_K - 03/28/20 11:24 PM
Best battery tender for AGM
by painfx - 03/28/20 10:27 PM
Tinted my DRLs
by mclasser - 03/28/20 09:04 PM
Chicken Burritos tonight
by urrlord - 03/28/20 08:34 PM
ACDelco Oil filter date code
by nwjones18 - 03/28/20 07:43 PM
GM Plastic Heater Hose T-Fitting(s) Broke!
by jetman - 03/28/20 06:26 PM
Elite Iron Bipod
by claluja - 03/28/20 05:44 PM
Uneven Pad Wear?
by JeffKeryk - 03/28/20 05:43 PM
Left valve cover leaking oil
by NH73 - 03/28/20 05:03 PM
Pennzoil platinum high mileage
by Micahmcmeen - 03/28/20 04:04 PM
Beans!
by 53' Stude - 03/28/20 03:54 PM
1997 Dodge Ram v6
by urrlord - 03/28/20 03:31 PM
Blood shortages
by 53' Stude - 03/28/20 03:09 PM
Decent little score
by JPP - 03/28/20 02:23 PM
First Time Timesert Install Questions
by The Critic - 03/28/20 01:56 PM
Ontario Nuclear update
by OVERKILL - 03/28/20 01:42 PM
yulichris, jeff58, jimmyturner, ChainsawGuy, jbr
71038 Registered Users
71 registered members (atikovi, 4WD, 2009Edge, 94astro, 53' Stude, 9 invisible), 1,069 guests, and 18 spiders.
Topics303,303
Posts5,233,561
Members71,038
Page 1 of 3 1 2 3
Gold (brass?) flecks in drained Honda ATF #5353619 02/18/20 01:10 PM
T
TNM6i Offline OP
T
So I just did the first ATF dump and fill on my 2017 Accord Touring V6/6AT, at just under 52k miles. The fluid was definitely dark, but not burnt smelling and still had a reddish tint. The concerning part is the amount of brass-colored specs in the bottom of my drain pan. Does anyone know if this would be considered normal wear, or possibly from initial break-in? There was a little bit of metallic particulate on the drain plug magnet, but not too much, IMO. I’ve noticed that the trans downshifts from 2-1 and from 3-2 a bit harsh at times but it’s always done that since new. I had the car at the dealer for what I know now to be VCM operation noises, and also a rattle while under light throttle application. No parts were replaced and the tech found nothing out of spec. They even sent a torque converter snapshot to Honda to determine if a judder TSB was applicable on my car. It was not. I plan to do another dump and fill this weekend when I do an engine oil and filter change. Hopefully it’s nothing worrying!
[Linked Image]
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353643 02/18/20 01:36 PM
H
hallstevenson Offline
H
Willing to bet it's completely normal and fine. I'll also bet that you won't see any, or it will be less, in subsequent drains.
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353653 02/18/20 01:42 PM
P
parshisa Offline
P
I believe my 2016 Pilot employs the same powertrain combo 3.5V6/6AT and first time i did d&f at 20K there has been no particulates noticeable in the fluid drain. Can you post more pictures? also, have you kept the fluid drained?
'17 Honda Civic 1.5T/ 6MT
'16 Honda Pilot 3.5NA/6AT
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353657 02/18/20 01:50 PM
G
gregk24 Offline
G
Likely normal.
2012 Honda Accord EX-L K24z3
60,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Gold (brass?) flecks in drained Honda ATF [Re: parshisa] #5353662 02/18/20 01:55 PM
T
TNM6i Offline OP
T
I have collected a sample to send to Blackstone, and I saved the remainder of the 3.5-ish quarts in a separate container for recycling. I guess I can do another dump and fill this weekend and see what comes out. Although, if something is wearing prematurely, that may be too soon to notice any additional particulate in the drained fluid.
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353663 02/18/20 01:56 PM
F
Farnsworth Offline
F
I wonder if rigging up a coffee filter to screen such particles would help see them better and dtermine what they are. Like maybe an old thrift shop cone filter coffee maker to use as a filter stand.
Re: Gold (brass?) flecks in drained Honda ATF [Re: Farnsworth] #5353665 02/18/20 01:57 PM
T
TNM6i Offline OP
T
Good idea! I might have to give this a try.
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353669 02/18/20 02:03 PM
T
Trav Offline
T
Probably just break in wear from brass bushing/thrust washers and probably not an indication of impending doom. PM member Clinebarger and let him have a look.
Re: Gold (brass?) flecks in drained Honda ATF [Re: Trav] #5353741 02/18/20 03:54 PM
T
TNM6i Offline OP
T
Took your advice and sent a PM. Would love to get some insight on this. If it’s a problem, it likely won’t cause issues until just after then warranty expires crazy
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353751 02/18/20 04:09 PM
V
vw7674 Online Content
Online Content
V
That debris comes from the clutch friction discs too.
Your trans has only another 388k miles left till rebuild. : )
Re: Gold (brass?) flecks in drained Honda ATF [Re: vw7674] #5353754 02/18/20 04:12 PM
T
TNM6i Offline OP
T
Well crap! I was really shooting for 500k! grin2
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5353994 02/18/20 09:56 PM
Chuckh Offline
Use good fluids and change them at a regular interval or first sign of trouble and you should be fine.
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5354058 02/18/20 11:28 PM
B
bbhero Offline
B
This reminds me of that song on the Bering Sea gold show.... At the end of the shows beginning the last word sung is Gold !!! !!!!!
I had a decent bit of shimmering silver type material when I changed my CVT fluid the second time... First drain the fluid had nothing in it... Just looked like regular darker oil....
Second time I had shimmery silver colored flecks on my glove.. . Kind of spooky... Put in 4 and 1/4 qts of the Eneos CVT fluid back in... Car ran fine...
Did a third drain and refill. . Fluid came out dark brown color with NO shimmery silver colored flecks in it... I put 4 and 1/4 qts of Eneos CVT fluid back in it... Car has run better and quieter since...
Did those 3 drain and refills starting at 283,500 miles and did all 3 of them over a 6,500 mile distance... Now at 297,500 miles and the transmission has been very, very good. Glad I did that.
In this case here with the original poster... I agree with the guys that this was just from the break in running....
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5354160 02/19/20 06:40 AM
O
Olas Online Content
Online Content
O
all that glitter in the factory fill is the reason why you should drain&fill as soon as you get home from the dealership. 52k miles with all that metal in the oil may not have done any harm, but it certainly didnt do any good.
Cable ties should hold it
Re: Gold (brass?) flecks in drained Honda ATF [Re: TNM6i] #5355072 02/20/20 05:17 AM
SoNic67 Offline
I never saw those metallic flakes in my Ford, Hyundai or Toyota vehicles (I have owned many, right now I still have 5 in my family to take care of).
But none of my cars is CVT.
Personally I would drain and refill ASAP, a couple times.
Page 1 of 3 1 2 3
