Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
Heaviest 5w-30 Synthetic?
by Propflux01 - 03/30/20 11:53 AM
Upgrade from HDD to SSD
by diyjake - 03/30/20 11:39 AM
Z08969, TCU_Adam, deaner1979, jdana24, KlenFrappe379
71061 Registered Users
38 registered members (bachman, BAJA_05, A_A_G, 14Accent, ajchien, Bailes1992, 6 invisible), 756 guests, and 19 spiders.
Topics303,497
Posts5,235,129
Members71,061
Page 1 of 3 1 2 3
ST 0W-20 2013 Sienna 100k #5352513 02/17/20 09:43 AM
M
Mangos86 Offline OP
M
Super tech 0w-20. I accidentally wrote 0w-30 on the slip I sent in. I’ve been sticking with the Toyota recommended 10k interval.
Attached PDF document
2015 BMW 535i X-Drive Castrol Edge 0W-40
2013 Toyota Sienna SuperTech 0W-20
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352544 02/17/20 10:20 AM
diyjake Offline
Is this the first time using ST 0w20 in this Sienna?
Re: ST 0W-20 2013 Sienna 100k [Re: diyjake] #5352551 02/17/20 10:26 AM
M
Mangos86 Offline OP
M
No. The second change in a row. Before was pennzoil platinum. Before that all done at the Toyota dealer.
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352566 02/17/20 10:43 AM
diyjake Offline
I use ST sometimes and reports like yours proves that it is in need very good oil. What filter did you use?
Re: ST 0W-20 2013 Sienna 100k [Re: diyjake] #5352572 02/17/20 10:50 AM
K
kschachn Offline
K
It shows a lot more about the specific engine and the operating conditions as opposed to the oil. As Blackstone themselves have indicated they see no statistically significant difference in UOA wear results between any appropriately rated oil.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352575 02/17/20 10:53 AM
T
Triple_Se7en Offline
T
It thinned out a little ([email protected]) and there's some fuel dilution in there (.5) - which Blackstone didn't mention. I'd stick with 7K OCIs with this oil.
Otherwise, I'd suggest 10K runs.
Were you getting Toyota's synthetic oil at the dealer? (which is better than ST). Or was it bulk synblend 0W20 for 10K runs? If it was bulk synblend, then try 10K with STsyn
Just keep sniffing the dipstick for fuel in the latter part of that next 10k run. You may even smell it inside the vehicle once in a while.
Keep Your Pistons Valves & Injectors Clean
19 Hyundai Santa Fe 2.4 GDI
20 Kia Soul X-Line 2.0 MPI - both Pennzoil Ultra Plat. 5W30 / AC Delco PF1127 Ecores
04 Chev Colorado Napa Syn 0w20 & K&N
Re: ST 0W-20 2013 Sienna 100k [Re: Triple_Se7en] #5352630 02/17/20 12:02 PM
M
Mangos86 Offline OP
M
Before I was just letting Toyota change the oil. So not sure if it was their bulk stuff or what. I continue to use the genuine Toyota filter. This van sees a lot of very short trips to and from school. Very few long trips. I’d say the oil only gets up to temp around once a week, and my wife doesn’t drive it very hard. Since the oil changes are so infrequent, I may use either genuine Toyota oil or some other brand and continue my 10k changes.
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352633 02/17/20 12:06 PM
F
FlyNavyP3 Offline
F
I see little evidence to suggest that you need to do anything other than ST 0w20 at 10k intervals. Flash point is excellent at 425, wear metals in check, and it meets the Toyota requirement.
Nice boring report.
Luke
Re: ST 0W-20 2013 Sienna 100k [Re: FlyNavyP3] #5352634 02/17/20 12:07 PM
M
Mangos86 Offline OP
M
Nice boring report.
Thank you for the feedback. I find all these forums fascinating. Lots to learn.
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352651 02/17/20 12:45 PM
T
T
The bulk stuff might have been in the $35 range for oil change-only. But if it was Synthetic, they may have charged you $65+ for oil change-only.
If you were paying the lesser amount, that indicates the motor is easy on oil and going 10K with Supertech syn and little to none fuel smell for 10K, might be fine to try-out.
Re: ST 0W-20 2013 Sienna 100k [Re: diyjake] #5352699 02/17/20 01:50 PM
CT8 Offline
To add,,, an oil that meets the specs from a quality blender gets the job done with out sponsoring NASCAR.
2015 F150 2.7
2018 F350 6.2
Re: ST 0W-20 2013 Sienna 100k [Re: CT8] #5352813 02/17/20 03:33 PM
T
T
Some oils are like jobs...... oils/jobs done better than others. Any good mechanic will tell you this.
Buy oils that proclaim they exceed specs..... not just meet specs. The Exceeders are usually the ones sponsoring NASCAR events.
Re: ST 0W-20 2013 Sienna 100k [Re: Triple_Se7en] #5352820 02/17/20 03:42 PM
K
kschachn Offline
K
If they are making that determination by the results of meaningful tests of course, such as the Sequence IVA for wear or ASTM D7097 (TEOST) for deposit control. But a typical UOA as presented here is incapable of making such a distinction.
1994 BMW 530i, 252K
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352872 02/17/20 04:47 PM
A
ad244 Offline
A
Honestly, a great report. Good flashpoint and wear metals are lower. I too wouldn't go that far on a run but thanks for posting up this report.
Re: ST 0W-20 2013 Sienna 100k [Re: Mangos86] #5352874 02/17/20 04:49 PM
L
Leo99 Offline
L
I just bought some ST 0w20 today for my Camry. And some 0w16 for the new Rav4.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Page 1 of 3 1 2 3
