MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Rislone New Gas Hy-per Cleaner Rebate
by Jackson_Slugger - 04/03/20 03:33 PM
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil
by apollo18 - 04/03/20 03:15 PM
FRAM Extra Guard PH16 CUT OPEN
by 53' Stude - 04/03/20 03:11 PM
CARQUEST R 84502 CUT OPEN 4,600 MILES
by 53' Stude - 04/03/20 02:58 PM
5w-20 PP Walmart & Amazon $12
by jayjr1105 - 04/03/20 02:28 PM
Chicken Marsala Recipe Help
by 97prizm - 04/03/20 02:02 PM
Oil Filter Removal
by Kansas_Ron - 04/03/20 01:24 PM
Pressure regulator made in USA
by rainman49 - 04/03/20 01:08 PM
mitsubishi outlander
by ernied - 04/03/20 12:43 PM
WM - Pennzoil Platinum $18.68
by The Critic - 04/03/20 12:13 PM
Going from a PAO to a Ester base MT oil
by Bill_W - 04/03/20 11:54 AM
Spring Cleaning
by Mad_Hatter - 04/03/20 11:40 AM
Starting Over - 2013 Prius
by Greg L - 04/03/20 11:15 AM
Glue for dovetail joints
by spasm3 - 04/03/20 11:08 AM
In my face "wake up" call
by Kira - 04/03/20 10:58 AM
TJim, Andreeas1978, lawmanracing14, ebarker, Knop
71082 Registered Users
107 registered members (55hambone, 01rangerxl, 2oldtommy, 53' Stude, 007, 9 invisible), 2,758 guests, and 20 spiders.
Topics303,535
Posts5,237,023
Members71,082
Dodge 42RLE transmission fluid change. Or not? #5346081 02/10/20 12:05 PM
F
Fordiesel69 Offline OP
F
I know the answer but want your opinions......
On my ford 4R70W, 4R75E variants, I have never caused a failure by changing the fluid and filter. Even when the fluid was poor.
I have a 42RLE in a dodge nitro, and with 150k I do not know the history. It shifts perfect but I experianced a neutral flare after a very sharp right had turn. I think it sucked air from the super aggressive turn and it being a touch low. The fluid is a brownish motor oil color and smells stale, not burnt! I heard ATF+4 does not retain its color dye very well with age. And acceptable fluid can look bad and not smell burnt.
I want to pull the pan, and unless it is covered in clutch debris change the filter and put in new fluid for however much came out, and call it a day. I do not want to do a "flush" or multiple fluid change with that kind of mileage and condition of existing fluid.
Is this ok, or is this tranny sensitive to fluid changes washing the debris into the valve body and damaging the rest of the transmission?
99' Crown Vic Police - SAP (P71)
00' Crown Vic Police - SAP (P71)
08' Crown Vics Police - SAP(P71's) (total of 3 garage queens)
13' Taurus Police
14' Fusion S Base
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346147 02/10/20 01:23 PM
J
jeepman3071 Offline
J
Yes, definitely change the fluid. Chrysler transmissions are very sensitive to having good fresh fluid. Use only ATF+4.
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (60k) - Liqui Moly 5w40, MANN HU816X
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346155 02/10/20 01:30 PM
demarpaint Offline
I'd do it. But if I were dropping the pan, I'd change the filter unless everything inside was pristine.
God Bless Our Troops
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346182 02/10/20 02:01 PM
slacktide_bitog Online Content
Online Content
Get an aftermarket pan with a drain plug, so future ATF changes are much easier smile
Redline C+ is good stuff to use where ATF+4 is called for. If that costs too much for you, then use any ATF+4.
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346184 02/10/20 02:03 PM
K
Kira Online Content
Online Content
K
I think the OP wants to change the filter.
The "unless" he employed referred to going to a plan B due to severe internal woes.
When the pan resembles a person's lawn after a roof tera-off, it's bad.
Re: Dodge 42RLE transmission fluid change. Or not? [Re: Fordiesel69] #5346242 02/10/20 02:50 PM
T
TriMoto Offline
T
These 42RLE are garbage. FWD trans flipped around.
Re: Dodge 42RLE transmission fluid change. Or not? [Re: TriMoto] #5346478 02/10/20 06:31 PM
Z
zrxkawboy Offline
Z
How have they failed for you? Ours has 130k miles and is going strong.
"Think of all the Ford owners who will someday want an automobile." John Dodge
