Originally Posted by spasm3
Originally Posted by OilReport99
Is that a PEA based cleaner?
I don't think so, its a strong brew of solvents, but they clean. In my MPFI engines, i run a tank with b-12 dumped in the tank, then a follow up tank with a bottle of techron I do that before an oil change.
Correct and that's what I'm doing. I'm due to change the oil out next weekend so I thought it would be a good time to give this a try. In the future I think I will refill the can with a PEA based cleaner but using this mix of solvents should give the valves on my PI engine a good cleaning. The instructions say that the provided "T", which has a open hole, is dialed to meter and atomize the solution so as not to stall.. like I've had happen to me just spraying directly into the intake form a can. The instructions go on to say that at normal idle it should take between 8~10mins to empty out the can. I'm gonna do it with my son next weekend so I can have him behind the wheel to give the engine some throttle if needed but I'm hoping it goes as planned/described and that won't be necessary. Then we'll do the oil change once the cans emptied out and go for a nice long drive. That's the plan anyhow...
I plan wash all the plastic in a tub of soapy water afterwards and fill up the can with some MMO I have on hand to prevent corrosion until it's needed next winter/spring. Truth be told I really wanted the can and jig setup for use with other cleaners but I'll take the Berryman's. I thought about making my own setup..but meh, I decided I was too lazy for that and the price for this wasn't that bad
