Need a sensible but fun daily
by dparm - 05/25/20 03:52 PM
FJ cruiser knock sensors
by Chris142 - 05/25/20 03:51 PM
Rock Auto now carries Maval steering racks and pumps
by slacktide_bitog - 05/25/20 03:10 PM
Review: Cardone Reman Power Steering Pump
by RevelationLion - 05/25/20 02:09 PM
Carvana
by Bogdon - 05/25/20 02:06 PM
Mitsubishi SP-III universal fluid
by MontePrix28 - 05/25/20 12:22 PM
4th Gen Ram 1500 tranny pan question
by stenerson - 05/25/20 11:26 AM
logic behind no trans dipstick?
by flinter - 05/25/20 11:25 AM
2012 Dodge Charger patrol car alternator meltdown
by IMSA_Racing_Fan - 05/25/20 11:25 AM
MMO vs Oil Consumption.
by Vladiator - 05/25/20 11:19 AM
Oil filter – clean/empty – reuse
by 2K2AcuraTL - 05/25/20 10:40 AM
Mazda 3 1.6 DV6C which Oil to buy
by mossietheno1 - 05/25/20 09:58 AM
APR dyno: Passat 2.0T 87 vs 93 Octane
by wemay - 05/25/20 09:31 AM
Quick Lane attempted to fraudulently upsell me
by Hermann - 05/25/20 08:58 AM
Frankenbrew question
by jdw1222 - 05/25/20 08:40 AM
Yamaha SHO Oil
by SDGolden - 05/25/20 08:33 AM
1909 Blackstone Oil Engine
by 2015_PSD - 05/25/20 08:22 AM
Garden of the Gods - Colorado Springs pictures
by wwillson - 05/25/20 07:17 AM
2008 Tundra tire rotation
by Amkeer - 05/25/20 06:35 AM
showtyme1958, rickyradit, YogiTheCat, StevePLR, BBC_bias
71526 Registered Users
103 registered members (86cutlass307, aba4430, ajchien, 14Accent, 53' Stude, 928, 10 invisible), 2,648 guests, and 17 spiders.
Topics305,857
Posts5,281,557
Members71,526
waterpump fan clutch and thermostat now overheating #5331843 01/25/20 01:43 PM
H
HyundaiAbuser Offline OP
H
So i recently replaced the water pump, fan clutch and thermostat in my mazda b4000 due to a leaking water pump. After bleeding i let it idle for about 20 minutes with no problems at all but once driving around my neighborhood it slowly climbed to the hot whereas this has never happened before. I used an aftermarket thermostat in this case where there was a motorcraft one before which is my first instinct. Secondly i am wondering if the rtv i used on for gaskets could be clogging it up that bad? What do you guys think?
03 Hyundai Tiburon:
PP High Mileage 5w30
Amsoil MTG
94 Mazda B4000
Supertech 10w40 High Mileage
Valvoline Dex/Merc
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331845 01/25/20 01:47 PM
CT8 Offline
Air pocket ? Did you check the fluid?
2015 F150 2.7
2018 F350 6.2
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331852 01/25/20 01:55 PM
slacktide_bitog Offline
Maybe it's due to air in the coolant. If you don't have one, get the Lisle coolant funnel. It makes bleeding the coolant much easier smile
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331856 01/25/20 02:00 PM
Nick1994 Offline
Probably air in the coolant. But just because a part is new doesn’t mean it’s any good. Aftermarket fan clutches often times suck, it might take a few tries to get a good one.
Take it for a drive, pop the hood, and shut off the engine and see if the fan keeps spinning or if it stops within a second or so.
2015 Hyundai Genesis 5.0L 60k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Mobil 1 HM 10w40 & Fram Ultra
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331865 01/25/20 02:09 PM
Chris142 Online Content
Online Content
Recheck the level after it cools. If it's low fill and drive again. Did you put the stat in the correct direction? A little bit of rtv won' t plug anything up.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331881 01/25/20 02:29 PM
H
H
Update, after cooling i went back out and checked the coolant level and holy cow about a 1/2 gallon low. Total rookie mistake I just did the water pump on my hyundai and totally forgot about this. After topping off i drove around a bit and now the gauge stays between 45-55% in its given range whereas it used to sit at 25 then 55 then 70 and back to about 40 at random. I'm letting it cool off again then going to check and repeat. Thanks for the quick responses guys.
03 Hyundai Tiburon:
Amsoil MTG
94 Mazda B4000
Valvoline Dex/Merc
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331883 01/25/20 02:29 PM
H
H
On the flip side i have lost heat in the truck so i am going to flush the heater core.
03 Hyundai Tiburon:
Amsoil MTG
94 Mazda B4000
Valvoline Dex/Merc
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331886 01/25/20 02:33 PM
M
mk378 Online Content
Online Content
M
The heater can't work when the coolant is not full. Heater not working is often the first symptom it isn't full.
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331895 01/25/20 02:47 PM
R
ragtoplvr Offline
R
or first symptom that a head gasket is failing.
Rod
Re: waterpump fan clutch and thermostat now overheating [Re: HyundaiAbuser] #5331917 01/25/20 03:02 PM
Delta Offline
Air bubble.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
