Spliceline wire connectors
by Donald - 02/16/20 05:22 PM
Found a few clearance oils at AZ today
by PantherFan88 - 02/16/20 04:55 PM
NASCAR electric
by CourierDriver - 02/16/20 04:52 PM
Valvoline Modern Engine vs Regular synthetic?
by PantherFan88 - 02/16/20 04:50 PM
Converting 1970 396 to Fuel Injection
by 007 - 02/16/20 04:47 PM
2016 frontier.
by red7404 - 02/16/20 04:34 PM
Ruger .22 SA - not a good show
by JHZR2 - 02/16/20 03:48 PM
engine maintenance Jaguar
by jssaab - 02/16/20 03:02 PM
New TSC clearance
by Greg L - 02/16/20 02:58 PM
Castrol Edge 5w20 and 5w30 Costco
by nlife - 02/16/20 02:41 PM
Generator Hour Meter
by spasm3 - 02/16/20 01:44 PM
VW Budack Cycle 2.0T - hugely unimpressed.
by pezzy669 - 02/16/20 01:13 PM
Michelin Crossclimate+
by wolf_06 - 02/16/20 11:32 AM
Dash cam restarting only via OBDII
by RamFan - 02/16/20 10:37 AM
Removing mold from washing machine door seal
by grampi - 02/16/20 10:08 AM
Sig P365
by Colt - 02/16/20 10:01 AM
Question for those of you who have an Apple TV
by grampi - 02/16/20 09:58 AM
Clifton, JohnEmm, Fastvette, Geode, rob1715
70716 Registered Users
106 registered members (01rangerxl, aba4430, 2013ecof150, 762fermeandyou, 2010Civic, 53' Stude, 8 invisible), 2,280 guests, and 41 spiders.
Topics301,534
Posts5,197,463
Members70,716
Page 26 of 26 1 25 26
Re: G48-mb325.0 [Re: 660mag] #5298368 12/18/19 06:56 PM
R
Red91 Offline
R
05 Chevy Silverado 1500
5.3 v8
Water pump, radiator hose and heater hose replacement
Out: mix of probably dexcool and some green coolant, water, qmi cooling system flush
In: 60/40 prime guard universal green and water, qmi cooling system conditioner
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: G48-mb325.0 [Re: 660mag] #5298485 12/18/19 09:29 PM
N
NissanMaxima Offline
N
1995 Maxima SE - 77k miles
simple drain and refill with new Lisle funnel - yee hah! that funnel is nice!!
out: Nissan genuine green coolant
in: same, mixing 50/50 with distilled water
specification is every 30k or 24 months
1995 Nissan Maxima SE 5 speed
2015 Toyota Corolla S+
Re: Post Your Latest Coolant Change. [Re: 660mag] #5304899 12/26/19 06:39 PM
R
Red91 Offline
R
94 gmc c1500
5.7 v8
Out: reddish orange water, Clean water, qmi cooling system flush
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post Your Latest Coolant Change. [Re: 660mag] #5308846 12/31/19 06:25 AM
R
Red91 Offline
R
11 Dodge journey
3.6 v6
Out: presumably factory orange coolant that was diluted with an unknown, white substance, water, qmi cooling system flush
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post Your Latest Coolant Change. [Re: 660mag] #5330620 01/23/20 07:25 PM
R
Red91 Offline
R
06 jeep liberty
3.7 v6
Radiator, radiator hose and radiator cap replacement, cooling system flush
Out: probably mostly prestone universal green premix, water, qmi cooling system flush
In; 60/40 napa universal green and water, qmi cooling system conditioner
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post Your Latest Coolant Change. [Re: 660mag] #5330774 01/24/20 01:51 AM
B
Black_Thunder Offline
B
I changed the water pump on my 98 explorer 5.0 awhile back, had a mixture of green and prestone extended life (neon light green), refilled with Resolute Extended life (light/neon green) from Fleet farm.
refilled my 96 contour with the same kind of coolant when i did the thermostat a few weeks ago.
I'd buy Callahan autoparts if I could.
Re: Post Your Latest Coolant Change. [Re: 660mag] #5334006 01/27/20 05:38 PM
R
Red91 Offline
R
04 Buick lesabre
3.8 v6
Out: unknown green coolant, qmi cooling system flush
In: 60/40 napa universal green and water, qmi cooling system conditioner
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post Your Latest Coolant Change. [Re: 660mag] #5337628 01/31/20 06:41 PM
F
FordFETruck Offline
F
99 Mercury grand marquis, 4.6 V8.
Flushed out the original coolant from 1999 when I got it last year. it was horrid. Put supertech coolant back in. 6 months later I decide to put a new water pump in it since the bearings were a bit worn. Coolant was dirty, but not as bad as original. It's stayed clean since, but the hoses look like a clogged artery from deposits and can't get the reservoir clean plus I can see sediment still floating around. Have new reservoir and hoses to install. Going to flush again and use Zerex G-05 this time and install a coolant filter. This was a bad one. Only neglected part of the car, very nice otherwise. Luckily the coolant passages inside of the engine block look relatively good. Nothing super rusty, and the original heater core is capable of putting out 170* F vent temps.
1986 F250. 4x2 351w Edelbrock heads, xe250h cam and the works. 245k miles
1999 Mercury Grand Marquis gs 4.6. 3.27 LSD, JMOD 120k miles
Re: Post Your Latest Coolant Change. [Re: 660mag] #5341543 02/05/20 06:28 AM
R
Red91 Offline
R
00 Chevy Silverado 1500
5.3 v8
Water pump, hoses, cooling system flush
Out: unknown, qmi cooling system flush
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post Your Latest Coolant Change. [Re: 660mag] #5341811 02/05/20 12:04 PM
F
FordCapriDriver Offline
F
1975 Ford Capri 3000 Ghia
Out : Febi Bilstein G12++ 50/50
In : 55/45 Repsol G11.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Re: Post Your Latest Coolant Change. [Re: 660mag] #5342233 02/05/20 08:28 PM
CT8 Offline
2015 Ford ,coolant with the proper approvals.
2015 F150 2.7
2018 F350 6.2
Re: Post Your Latest Coolant Change. [Re: 660mag] #5344796 02/08/20 05:27 PM
A
A_User55555 Offline
A
2011 DTS. I did my annual coolant "flush"
1 Gallon of Prestone Dex-Cool Concentrate and 1 Gal of Distilled Water from Target. I mixed the two to get a 50/50 Dexcool Mix.
I disconnected a coolant return line going to the surge tank. I then start the engine. As coolant drains through the hose, I top off the surge tank. I poured in 2 Gallons to the surge tank.
The whole car holds 3 gallons of coolant. Because the thermostat controls flow into the engine block, I'd be exchanging all the coolant in the system except the radiator.
I know DexCool has a 5 year service life, but I like to change it every year. It only costs $15.
2011 Cadillac DTS. No the headgaskets have not blown.....
5W-30 Napa Full Synthetic with a Carquest 85522 (Wix) Filter
Re: Post Your Latest Coolant Change. [Re: 660mag] #5345156 02/09/20 08:50 AM
F
F
1988 Escort XR3i
Out : Febi Bistein G12++
In : Repsol G11 50/50
