Where do you buy super cheap reading glasses?
by MoneyJohn - 02/20/20 11:34 AM
Caliper Boot Was Loose When Changing Pads
by Fitz98 - 02/20/20 11:15 AM
Non-Detergent and Additized Mono-Grades
by MolaKule - 02/20/20 11:14 AM
$25 Pennzoil rebate on 1 case of 6 qts
by Ride_Red - 02/20/20 08:28 AM
Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
Jason454, Max331, 4fordsd, Mayberryminitruc, DaiwaGuy
70759 Registered Users
110 registered members (AndyB, apollo18, Anduril, Astro14, 928, 2012AccentSE, 7 invisible), 2,077 guests, and 19 spiders.
Topics301,698
Posts5,200,888
Members70,759
ST9688 gasket #5326334 01/18/20 01:26 PM
F
Farnsworth Online Content OP
OP Online Content
F
It's beveled, never saw that before yesterday in the store. The base almost looks like the ecore base without the extra cover plate.
https://www.walmart.com/ip/SuperTech-ST9688-3-Spin-on-Oil-Filter/725840436
Re: ST9688 gasket [Re: Farnsworth] #5326354 01/18/20 01:43 PM
MrMoody Offline
[Linked Image]
I've seen lots of round ones, never one that was triangular like that.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: ST9688 gasket [Re: Farnsworth] #5326381 01/18/20 02:28 PM
danez_yoda Offline
Should seal fine. For the same torque you get higher pressure (PSI) on the smaller lip than a wider one. On their side, I can also see this as a way to reduce the amount of rubber per seal.
Looks like a 10-15% reduction and that could add up to big bucks on a high volume market. Good value engineering in my opinion. lower cost and marginally better performance.
Just don't overtorque these or I suspect the small lip will tend to stick due to the higher pressure.
Re: ST9688 gasket [Re: Farnsworth] #5326390 01/18/20 02:38 PM
Sayjac Offline
Been that way since the newer ST 9688 hybrid design filter introduced as seen in 53' dissection linked. Champ decided rather than narrow gasket inside OD used on most 9688/3593a, extend it to OD.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4901234/all/super-tech-9688-cut-open
Re: ST9688 gasket [Re: Farnsworth] #5326396 01/18/20 02:50 PM
Chris142 Online Content
Online Content
The filter for my pickup is beveled like that.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: ST9688 gasket [Re: Farnsworth] #5326566 01/18/20 07:28 PM
J
jayjr1105 Online Content
Online Content
J
Is this what supertech recommends as a 7317 replacement? If I remember there is no ST7317 correct?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: ST9688 gasket [Re: jayjr1105] #5326567 01/18/20 07:30 PM
B
Bettez88 Offline
B
If you look in their books or the little computers it recommends the 6607 size.
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: ST9688 gasket [Re: jayjr1105] #5326656 01/18/20 10:51 PM
I
Imp4 Offline
I
Correct. No ST7317 is available.
They recommend a 9688 for every 7317 application I've seen.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: ST9688 gasket [Re: Imp4] #5326737 01/19/20 03:20 AM
W
WhyMe Online Content
Online Content
W
9688 is also for hyundai correct?
Re: ST9688 gasket [Re: WhyMe] #5326761 01/19/20 05:32 AM
T
Triple_Se7en Offline
T
For less than a dollar more, you can get a NAPA Proselect with silicone ADBV and built like OEM. I paid $3.49 for it..... #21334
Being Trolled? Use the Ignore User Option
Keepa' Ya' Pistons, Valves & Injectors Clean
19' Hyundai Santa Fe 2.4 GDI / 20' Kia Soul XLine 2.0 MPI - both Pennzoil Ultra Platinum 5W30 Mobil1 Filters
Re: ST9688 gasket [Re: Sayjac] #5326767 01/19/20 05:50 AM
Sayjac Offline
Quote
No and yes. It's true there is no 7317 application the ST line however the shorty 6607 is what ST consolidates for that application. The topic 9688 is too wide for many 7317 vehicle applications now. Many newer Honda and Nissan have block, pan and/or diameter restriction rings that prevent the wider 9688/3593a from being used, screwing on. The 6607 will always mount on a 7317 application vehicle.
The 9688 is the common size for Hyun/Kia with spin on filter application, eg., 2.4L engine.
The previous ST line made by Champ, years ago, did have a 7317 application.
As an aside, the AZ STP blue filter line used to be very similar to or same as current ST line, they too had no 7317 application. Since the new manufacturer with China coo, the blue line now has now added a 7317 application.
Re: ST9688 gasket [Re: Sayjac] #5326988 01/19/20 11:13 AM
J
Online Content
J
Originally Posted by Sayjac
Quote
Are we talking the can is too wide or the gasket?
Re: ST9688 gasket [Re: Farnsworth] #5327061 01/19/20 12:29 PM
Sayjac Offline
The reference to 9688 being too wide and restriction is in regard to the outer diameter (OD) of the 9688/3593a can.
Pic shows a comparison of the more common standard 9688/3593a baseplate and 7317 application size side by side.
[Linked Image from i.imgur.com]
Re: ST9688 gasket [Re: Sayjac] #5327077 01/19/20 12:46 PM
F
OP Online Content
F
The reference to 9688 being too wide is in regard to the outer diameter (OD) of 9688/3593a can.
That probably is the reason, to maintain contact diameter. The sealing pressure should be greater since the thicker rubber concentrates it's power into the narrower band. the other observation is the base plate looks like ecore without the extra metal cover. I like the look of the ST filters they are going forward it seems. Maybe because Champ has this very fat WM contract now.
