Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
Cadillac CTS 4 AWD driveline care and feeding
by IMSA_Racing_Fan - 03/30/20 12:13 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
107 registered members (4WD, 53' Stude, 1978elcamino, 10ecfarmer, 2004tdigls, 55hambone, 10 invisible), 1,361 guests, and 18 spiders.
Topics303,499
Posts5,235,279
Members71,063
Ariens L-3 Synthetic Severe-Duty Gear Lube #5326369 01/18/20 03:04 PM
A
Astro_Guy Offline OP
A
Looking for a suitable alternative to this lube for the auger gearbox on my 4 year old Ariens Deluxe snowblower. "Suitable" means something I might already have on hand or anything else that might also be useful in my vintage 1985 Troy-Bilt Rotottiller. Presently I have some Mobil1 75w-90 on hand. I've found one other forum thread saying that Ariens L3 is just a 75w-140 EP gear oil, but it wasn't what you might call "well sourced." I should probably also mention that the Troy-Bilt calls for a yellow metal friendly lube.
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5326406 01/18/20 04:04 PM
gathermewool Offline
Nevermind - wrong link
14 Forester XT Touring FA20DIT (Cobb Stage 1)
Castrol Magnatec 5W-30 D1G2 + FU filter (2nd OFI) (77,760mi, 3/7/20)
15 Legacy Premium FB25
Magnatec 0W-20 D1G2+ FU filter (2nd OFI) (54,621mi, 3/4/20)
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5326431 01/18/20 04:42 PM
J
JC1 Online Content
Online Content
J
Are those lubes good for cold temperature? I need to do that to my snowblower as well. I've never added gear lube in the 8+ years I've owned this snowblower.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5326446 01/18/20 05:01 PM
SHOZ Offline
MTD uses 000 grease.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5326855 01/19/20 09:41 AM
M
mattwithcats Offline
M
Ariens L3 grease is still available...
A 75W-90 GL-4 grease may work, but that’s more expensive and unicorn tears..
https://www.walmart.com/ip/Ariens-O...w-Blower-Snow-Thrower-00068800/209305617
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: mattwithcats] #5327156 01/19/20 04:11 PM
A
A
Yes, but that wasn't the question. I want to know if I can use the Mobil1 75w-90 that I already have on hand, or if forced to buy the Ariens L3, could that be used in the Troy-Bilt rototiller.
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: JC1] #5328044 01/20/20 05:32 PM
A
A
Those lubes are fine in cold temperatures for this application. One of the two gears is partially immersed in the oil, and it's not as if it is getting pumped anywhere.
I've also found a few youtube videos and other sources on the topic of auger gearcase lubrication. It seems as if 000 grease is something used in applications where they expect you to run it to failure without ever checking or changing the lube. MTD does it this way, and you may note that there is no way to check the lube level on their machines, let alone change out the lube. Ariens, on the other hand, does make it easy to check that level and change the lube if you want to. Aside from leaky seals, grease doesn't seem like a very good option.
'01 Volvo V70XC, 251k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5328664 01/21/20 12:16 PM
W
Whimsey Offline
W
I have one of those MTD (Troy-Bilt) snow blowers. I bought it new in 2014, Model 2410. The gear box developed a leak. I tightened the bolts but it pushed out the RTV gasket material though it leaks a lot less now, but still leaks. The leak is not severe enough to disassemble everything to reseal it at this time. I found the 00 grease at Tractor Supply Co for $5.25 versus around $20+ everywhere else I looked. I just squeeze in some more grease once in a while. I'll do this until it fails or I move to Florida, which ever comes first grin2.
Whimsey
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5329752 01/22/20 07:07 PM
F
Fatboymoe Offline
F
I just bought 2, 8oz bottles of this stuff for $22 on Amazon. I know it's expensive for what it is, but these 2 bottles will last a lifetime for my Sno-Tek snowblower. In the 2 years I have used it 20 hours total. I don't know the actual change interval, but I check the level every year and will change it every 5 years.
2016 F150 XLT 4x4 3.5 EB R.I.P.
2003 HD FatBoy
2018 Subaru Legacy with EyeSight
2017 F150 XLT 4x4 3.5 EB, Max tow
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Fatboymoe] #5329848 01/22/20 09:06 PM
A
A
Originally Posted by Fatboymoe
I just bought 2, 8oz bottles of this stuff for $22 on Amazon. I know it's expensive for what it is, but these 2 bottles will last a lifetime...
I am not opposed to buying it per se, but would really like to know if the 75w-90 gear oil I already have on hand won't do the job. I've already got enough of that to last several years for my other gear oil application.
Speaking of lasting a lifetime, I used a Yard Machines (MTD) 26" snowblower with 8HP Kohler Snow King engine for 16 years and never touched anything related to grease or gear oil. I pulled that machine out of storage after three years and gifted it to a neighbor. That machine had a lot of hard hours on it, but I had very little time for maintenance then. Now that I have the time, I plan to take better care of the 24" Ariens Deluxe. The 26" MTD machine was retired not for performance reasons, but rather that we needed that extra two inches of clearance in the garage. Now that we are four seasons into the new Ariens, I have to say that it performs better in your typical four inch snowfall. Something about the sound and performance of the two motors says that the older MTD machine might actually outperform the Ariens in those 12 inch and higher snowfalls. The Ariens hasn't seen one of those yet, some perhaps I will yet be pleasantly surprised.
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5344714 02/08/20 03:44 PM
A
A
We had nice weather here today so I took advantage of it to service the Ariens Deluxe 24 snowblower. Checking the Auger gear oil I found it to be low. I've not purchased any of the Ariens L3 lube, hoping that another gear oil would do the trick. The Ariens lube is red but the gear oil I have on hand isn't. Should I just bite the bullet and get the Ariens L3. or top it up with the Mobil 1 75w-140 I already have on hand?
I gather that the Ariens L3 is supposed to be yellow metal friendly, which is something my other application calls for as well. I guess it won't go to waste if i buy some.
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5344721 02/08/20 04:09 PM
A
andyd Offline
A
Ancient Ariens. I keep it topped off with 80w90 MTL. If the M1 75w140 is brass friendly, go for it. grin2
Thick oil is better grin2
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5345971 02/10/20 10:05 AM
A
A
It turns out that my stash of gear oil was far less than I thought it was, and my local Ariens / John Deere dealer stocks the L3 lube. Expensive? Yes, but chaeper than buying online.
[Linked Image from skiesunlimited.com]
Re: Ariens L-3 Synthetic Severe-Duty Gear Lube [Re: Astro_Guy] #5348380 02/12/20 06:49 PM
2
2K2AcuraTL Offline
2
ive been using the Penz Plat synth 75w90 GL-4,
its the same oil i use in the transfer case in my AWD MDX
it was far better than what was in there from the original fill... it was gelatinous..
2002 Acura TL-P --- 2013 Acura MDX-Elite --- 2008 Civic
ALL on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
