Use penetrant to loosen the fastener, chase it several times (run the nut completely up and down the threads), then clean the bolt and stud with a wire brush. Apply some anti-seize (not too much) and you should be good.
For battery corrosion in general, I've used LPS3 with good results. It's an industrial lubricant that leaves a heavy waxy film and has preserved many battery trays in many of my vehicles.
