Michelin Premier LTX Different Tread
by chuck wood - 01/20/20 08:49 AM
Best ear plugs for concerts,clubs?
by aquariuscsm - 01/20/20 07:47 AM
Oil ideas for 2 v6 fords and more
by kessellrun - 01/20/20 06:50 AM
Chery A520 2.0 L Transmisstion Oil
by Omar_Eltahan - 01/20/20 02:38 AM
castrol 5w30 c3 for an LS?
by neo3 - 01/19/20 11:32 PM
Windows 10 Upgrade Guide
by OVERKILL - 01/19/20 09:59 PM
FCA and Foxconn partner on EV's
by OVERKILL - 01/19/20 08:55 PM
IIHS Crash pics of Full Size Trucks
by kstanf150 - 01/19/20 08:15 PM
Are Engine Splash Guards Really Needed?
by Mr_Luke - 01/19/20 08:14 PM
supertec cartridge filters
by super20dan - 01/19/20 06:17 PM
More Valvoline on rollback at WM
by jayjr1105 - 01/19/20 06:13 PM
Crossed poles on jumper cables
by 3Aone - 01/19/20 05:33 PM
Napa Gold 7060 7.5K miles
by KenshinHimura - 01/19/20 05:09 PM
Can you move a car with the starter?
by atikovi - 01/19/20 04:49 PM
Leaf spring advice.
by mpack88 - 01/19/20 02:19 PM
Bobjr94, GarageKings, JohnnyD1980, Harry_Seaward, MrH1325
70486 Registered Users
98 registered members (AndyB, 2002 Maxima SE, ABerns, A310, aquariuscsm, atikovi, 10 invisible), 2,280 guests, and 43 spiders.
Topics300,341
Posts5,173,728
Members70,486
Most Online3,825
Jan 19th, 2020
508.00-509.00 oil for Honda K24Z3? #5288216 12/08/19 01:36 AM
A
allepunta Offline OP
A
Hi everyone,
new poster, been a long time lurker. Could not find any "introduce yourself" section so I am posting my question.
I bought a Euro Accord Tourer 2.4 (Acura tsx wagon in the US) with 50k miles. Currently 76k miles the car runs great but burns around
1.5 liter per oil change (10000 km-6200 miles). Been using Motul oils for since I got it, anything from xcess 5w40 and 5w30 to synergy 10w40.
My last change I decided to go with Eco-nergy 5w30 and the engine seems to like it, revs much easier and sounds great, quiet at idle.
So after reading around I am starting to understand that I can go thinner without any "risk" like you do in the US
I would like to try a real synthetic 0w20 to see how the car takes it and I found the Motul specific 508509:
Viskosität SAE J 300 0W-20
Dichte bei 20°C ASTM D 1298 0,833
Viskosität bei 100°C ASTM D 445 7.8 mm²/s
Viskosität bei 40°C ASTM D 445 38.5 mm²/s
Viskositätsindex ASTM D 2270 179
HTHS-Viskosität bei 150°C ASTM D 4741 2,5 mPa*s
Stockpunkt ASTM D 97 -52°C
Flammpunkt ASTM D 92 222°C
SulfataschegehaltASTM D 874 0,79 Gewichts-%
TBNASTM D 2896 8,3 mg KOH/g
I am in Switzerland, winter can be quite chilly here, the cars sees 98 % motorway use, most of the time long runs (700 miles journeys)
a few of the in german motorways.
Can I use this oil?
2012 Euro Honda Accord Tourer 2.4 (CW2)
Re: 508.00-509.00 oil for Honda K24Z3? [Re: allepunta] #5288236 12/08/19 03:11 AM
J
john_pifer Offline
J
I had a 2004 Honda Accord EX sedan (5-speed manual transmission) with that 2.4L engine. Great car! Leather interior, automatic climate control, sunroof, really nice. Engine didn't have a lot of low-end grunt, but it did quite nicely once you got it up to speed out on the highway. I usually got in the high 20s for fuel economy. Nice gearbox, but the clutch was inadequate - started chattering a bit after just a handful of aggressive launches. Oh, and the brake rotors were garbage. Always warping. Just too small for regular higher-speed use. But oh well, what can you expect from what is a relatively pedestrian family car. I only got rid of the car because I got into riding dirt bikes, and needed a truck, hence my current Tacoma.
If your Accord is already using oil, switching to a 20W oil will only make the problem worse.
The only reason for the specification of 20W oils here in the USA is government pressure on the automakers to eke out a few more tenths of a MPG in fuel economy.
I can't see any good reason to switch to a 20W oil in your car. I suggest sticking with a quality synthetic 30W. Possibly a Euro 30W with a bit higher resistance to shear if you do a lot of higher-speed driving, like on the Autobahn.
As for your oil usage problem, it might be due to carbon fouling of your oil control rings, causing them to stick in the ringlands and not seal the cylinders, allowing oil to bypass them and get burned in the cylinders. Lately I've heard mention here of an oil called Valvoline Premium Blue Restore 10W-30. It's a very high quality oil designed to clean carbon/soot deposits out of diesel engines, but it won't hurt anything to run in your car for at least one oil change interval to see if you can get those ringlands cleaned up.
Welcome to the site!
And do let us know what you end up doing.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 223K
18 Civic HB 1.5T 6MT (Fiancee's) - Edge 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: 508.00-509.00 oil for Honda K24Z3? [Re: allepunta] #5288265 12/08/19 05:27 AM
A
A
Thanks for the advice. I might stick with the Eco-Nergy for a while then. HTHS is 3.2 and viscosity at 100°C is 10.1. The car actually feels very good with this oil. The 5w40 was definitly too thick, could feel the drag. Gonna try to get hold of Valvoline Premium Blue Restore 10W-30 for the summer and see if I get some result.
Re: 508.00-509.00 oil for Honda K24Z3? [Re: allepunta] #5288273 12/08/19 06:01 AM
M
MParr Offline
M
I would think any 504.00/507.00 oil would work well and be readily available.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Kendall GT-1 Max 5W30 FS & NAPA Gold 1348
93 Octane Non-Ethanol
Re: 508.00-509.00 oil for Honda K24Z3? [Re: allepunta] #5288326 12/08/19 07:56 AM
O
Olas Offline
O
You can do what you like with your own car and your own money, but remember, viscosity is dictated by climate.
Google 'SAE J300' for specific information
Cable ties should hold it
Re: 508.00-509.00 oil for Honda K24Z3? [Re: MParr] #5288364 12/08/19 08:57 AM
K
Kamele0N Offline
K
++++1 smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: 508.00-509.00 oil for Honda K24Z3? [Re: Olas] #5288414 12/08/19 10:03 AM
A
A
Meaning 0w20 are not apt for europan continemtal clima, average speeds and other variables? Please clarify that.
I recall reading somewhere the K24 engine was developed around a 0w20 oil already at that time.
Re: 508.00-509.00 oil for Honda K24Z3? [Re: allepunta] #5288464 12/08/19 11:18 AM
M
MParr Offline
M
Go to the Mobil, Shell or Castrol sights and do a search for your vehicle. I came up with the 504.00/507.00 recommendation from Mobil UK
