2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
63 registered members (2000ltdken, ArrestMeRedZ, bdcardinal, AndyB, 2strokeNorthstar, BBDartCA, 5 invisible), 1,401 guests, and 20 spiders.
Topics300,449
Posts5,176,030
Members70,506
Page 1 of 3 1 2 3
At home tire rotation protocol question #5286897 12/06/19 12:57 PM
N
NissanMaxima Offline OP
N
Hi all:
I'm thinking of starting to do my own tire rotations to avoid frustrations with tire places that jam through cars like a pit stop at the Indy 500. One of my cars uses the simple front to back pattern and the other one uses the criss-cross pattern. I'm looking into a nice torque wrench and set of jack stands and came across the thread below. It was a nice discussion where some folks just use the spare in the sequence and totally avoid using a jack stand and merely using the car jack or a floor jack.
To those here doing their own rotations - which of these techniques do you favor?
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3638838/1
1995 Nissan Maxima SE 5 speed
2015 Toyota Corolla S+
Re: At home tire rotation protocol question [Re: NissanMaxima] #5286905 12/06/19 01:13 PM
demarpaint Offline
Typically with a 4 tire rotation I jack the rear up first and put it on jack stands, then remove the tires. Then I jack up the front, [jack stands in place for safety] remove the tires, swap the back tires to the front, to where they need to be, tighten up the lugs [remove the jack stands] and lower the vehicle. Then I put the back tires on, jack it off the stands and lower it. FTR I have about 5 pair of jack stands and 2 floor jacks. My vehicles are RWD and 4WD. It doesn't take very long to do, or much jack movement.
God Bless Our Troops
Re: At home tire rotation protocol question [Re: NissanMaxima] #5286942 12/06/19 01:52 PM
R
Rand Offline
R
jack stands can be a pain on some cars no real good place for them.
2 jack method:
in the case of cross rotation I jack up one end and switch the tires.. then do front to back by jacking up 1 side at a time.
if you have them you can also use 1 jack and a spare tire or winter tire
Example subaru outback 2013- recommends a forward cross.
I jack the rear from the differential skidplate. swap tires side to side. put one tire back on with a lugnut for safety as my driveway has a small sideways slope.
then I jack the front driver side and swap driver side tires front to back, repeat for passenger side.
also I check for nails in the tires found 2 today but neither penetrated.. also a couple pieces of glass in the tread sipes I removed.
typically for standard lugs I use my milwaukee m12 fuel stubby impact to remove and replace the lugnuts for cars with 80ft-lb or lower.. I then final tighten with torque wrench.
if they are 100ft-lb or higher I use the dewalt dcf899 big impact.. to remove then final tighten with torque wrench.
if they are tuner or other odd lugs I will first loosen them all by hand with breaker bar.. and the final torque step takes longer as you have to ratchet the torque wrench because I dont zip them on as tight with the impact.
Re: At home tire rotation protocol question [Re: NissanMaxima] #5286944 12/06/19 01:54 PM
P
PandaBear Offline
P
I've never used torque wrench on my own car for tire rotation. Basically what I do is look up how heavy I am, and about how much I step on a chair will reduce that much weight on my other foot from my scale. I then practice a few times to remember how much I should step on the tire iron. The tire iron is about 1 foot long, so that many pound times 1 foot is that many pound foot.
If you need to use a torque wrench to replace a flat, what are you going to do at the road side when you got a flat? You don't need to be that precise as long as you are not over torquing and all lug nuts are tighten about the same in a star pattern.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
Re: At home tire rotation protocol question [Re: NissanMaxima] #5286950 12/06/19 02:03 PM
Dave Sherman Offline
I lower the spare, put the spare on the first one that comes off, rotate the others through, and swap the spare back. Good time to check the spare tire pressure too. Also good to lube the cable and windlass for the spare, they get rusty around here if you have the spare on the underside. Unless you have the jack stand securely under the one missing wheel, jacking other wheels may cause it to shift on the jack stand. Happened to me once.
2015 Honda Pilot EX AWD Valvoline 0W-20 Bosch filter
1977 MG Midget Valvoline VR-1 20W-50 Bosch Filter
Re: At home tire rotation protocol question [Re: PandaBear] #5286968 12/06/19 02:32 PM
AZjeff Offline
That's a well thought out method but there's really nothing wrong with using a t-wrench and mfg's specs. No you wouldn't need to carry the wrench in your car, get them tight then loosen and re-torque when back home. Wondering if you keep a chair in your trunk so you can get your calibration right? wink
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: At home tire rotation protocol question [Re: NissanMaxima] #5286973 12/06/19 02:41 PM
ctechbob Online Content
Online Content
*Flame Suit On*
I don't use jack stands at all. Both of my cars will lift the entire side of the car from the front jacking point. I make it a point to not be under the car at any point. Air impact the wheels off, flip front to rear, hand tighten, off the jackstands, torque wrench. Tires rotated every oil change front to back only. Spare is a compact so it stays put.
Now, I have a nice flat concrete floor and air power available. The worst that will happen is a jack collapse and the car falls to the floor. I never have any body part under the car at any point so the risk to me is minimal. It takes me a couple minutes a side to get the job done.
And yes, if I'm doing something more involved, the jack stands come out and are properly used.
2008 Acura TL Type S-165k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: At home tire rotation protocol question [Re: NissanMaxima] #5287004 12/06/19 03:14 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I use a jack, log, and torque wrench to cross rotate my tires that allow cross rotation.
TPMS precludes including the full sized spare in rotation.
If I feel the need, I'll include a rebalance from my home balancer on each tire.
Re: At home tire rotation protocol question [Re: NissanMaxima] #5287005 12/06/19 03:14 PM
Z
zfasts03 Offline
Z
4 Floor Jacks is a game changer. Been doing tire rotations this way for years.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: At home tire rotation protocol question [Re: zfasts03] #5287018 12/06/19 03:41 PM
javacontour Offline
I can do it with 3.
I can use 2 on one side of the car and then lift the other side with 1 about 1/3 of the way from the front to the back.
FWIW
network down, IP packets delivered via UPS -BOFH
Re: At home tire rotation protocol question [Re: ctechbob] #5287033 12/06/19 03:59 PM
E
eljefino Offline
E
Originally Posted by ctechbob
*Flame Suit On*
This is how I did the HHR. Just lifted by the unibody "frame rail" approx 1 foot aft of the firewall. The front tire came up first, obviously, but as I kept jacking the rear one did too.
At some point your time is worth something.
Re: At home tire rotation protocol question [Re: Dave Sherman] #5287049 12/06/19 04:13 PM
Squirrelee Offline
This. I drop the spare, check the tire pressure, and take it to the driver's side front wheel. I jack up the truck just behind the front wheel, remove the front wheel, and replace it with the spare (temporarily holding with 2-3 lug nuts). I roll the front wheel over to the air compressor checking for nails or other objects in the tire as I go, then check the tire pressure and fill if necessary. That tire goes to the driver's side rear, and the process keeps going until the passenger side rear gets moved to the driver's front and the spare gets removed and put back into its holder.
FWIW, I do use a torque wrench to tighten the lugs.
Some guy's dog thinks I'm a good man.
Re: At home tire rotation protocol question [Re: NissanMaxima] #5287058 12/06/19 04:23 PM
Propflux01 Offline
4 jackstands, cross rotate while the oil is draining.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: At home tire rotation protocol question [Re: PandaBear] #5287060 12/06/19 04:25 PM
M
maxdustington Offline
M
I used to do the same thing, just stand on the L shaped tire iron from the tool kit. Works like a charm!
Get a split beam wrench, I ALWAYS leave my clicker cranked up for some reason. I left it for a few days cranked up to 150 ft lbs last weekend after torquing an axle nut! sick
99 Toyota Tercel CE 5EFE/C151
Re: At home tire rotation protocol question [Re: Dave Sherman] #5287065 12/06/19 04:31 PM
J
JLTD Offline
J
+1 on this method...but get the rear axle on jack stands so only have to jack it up once.
"Let’s not pretend like 0w20 is anything but a CAFE required crutch to eek another 1/2MPG" - BLND1
Hers: 2018 Ford Flex AWD EB, 35k, dealer fill
His: 2015 4Runner 60k, SS 5w20/Amsoil
Page 1 of 3 1 2 3
