Originally Posted by dogememe
I don't rotate my tires. Waste of time.
Not if you own a Honda product. The tires wear unevenly, if you don't rotate them then you'll be replacing 2 tires sooner than the others. I'm sure there are many FWD cars that exhibit the same properties.
Interesting - on my Escape, I'm on like 50K miles on the same set of unrotated Hankook Dynapro HT tires. Although they have lousy traction in any condition and I would never buy them again, they do wear perfectly evenly. And no, I haven't ever got an alignment, I may or may not frequently go over 100, I drive very aggressively, and I've driven over curbs and medians with this car. I guess Ford does occasionally do things better than Honda
Its just the way the cars are set up to drive. Little to no camber on the front wheels, front biased weight dist, and in the case of the V6 cars, a decent amount of power going through 2 tires that have to go, steer and stop, usually means you'll wear the outside edge and center a little more. Between 1-1.5 deg of negative camber on the rear tires that don't work nearly as hard as the front wears the insides a bit. The cars drive great, but that's the trade-off.
