2009 Infiniti G37x
by mjk - 01/22/20 10:51 PM
Boy did I have a scare today! Still a little concerned...
by SubieRubyRoo - 01/22/20 10:32 PM
Castrol Edge 0w20
by Mr_Luke - 01/22/20 10:17 PM
Air purifier/vacuum scheme?
by The_Eric - 01/22/20 09:14 PM
Car for short, elderly person?
by BBDartCA - 01/22/20 08:34 PM
Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Jeff1024, EricWestland, Brian200001, Phildrum, 335xiE92FBO
70506 Registered Users
57 registered members (AC1DD, 2009Caraman, allgm59, 928, 2000ltdken, 67ZL1, 7 invisible), 1,391 guests, and 22 spiders.
Topics300,449
Posts5,176,033
Members70,506
Page 1 of 3 1 2 3
Leaf springs last how long? #5286725 12/06/19 09:27 AM
supton Offline OP
Doah! Took my 20 year old car in for inspection, expecting it to fail (it didn't--yay!), took my 10 year old truck in and it fails... Broken leaf. Considering how little I've used it, I'm kinda miffed. Should I be? I mean, it's rust country, and it's a Toyota. But anything and everything can fail, right?
I tried to keep fluid film on it, but apparently to no avail. The shop said the other side was on its way out too.
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: Leaf springs last how long? [Re: supton] #5286730 12/06/19 09:32 AM
JohnnyJohnson Offline
Should have lasted 20 more years easy. My guess is you got a factory defect.
2004 Corolla 138441
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Leaf springs last how long? [Re: supton] #5286732 12/06/19 09:33 AM
E
emmett442 Offline
E
Garbage parts.
The leaf springs on my 45 year old pickup are still fine.
2011 Ford Crown Victoria LX 4.6L V8 auto
2009 Chevrolet Malibu LT 2.4L I4 auto
1974 Dodge D200 360 V8 4 speed manual
Re: Leaf springs last how long? [Re: supton] #5286735 12/06/19 09:36 AM
AZjeff Offline
A little surface rust has nothing to do with that one way or the other. If the same leaf in both packs is failing there must be a problem. Some searching will tell you. Springs aren't very expensive and it's a simple fix.
A quicky search finds lots of reference to broken Tundra springs.....
14 RAV4 2.5 5W-20 PP
18 Nissan Titan 5.6 DI, QSUD
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Leaf springs last how long? [Re: supton] #5286739 12/06/19 09:39 AM
K
Kestas Offline
Global Moderator
Global Moderator
K
My 17 year old 1957 Chevrolet had multiple fractures on the leaf springs.
Corrosion is a nasty fact of life in the rust belt. A corrosion pit forms, bores below the shot penned surface, and provides a toe-hold for fracture from high cycle fatigue. I've seen it a number of times on springs examined in the lab.
The same happens with coil springs. The difference is coil spring surfaces have a coating that doesn't get rubbed off from fretting against the adjacent leaf springs.
Re: Leaf springs last how long? [Re: supton] #5286742 12/06/19 09:41 AM
supton Offline OP
Haven't had a chance to research yet, got the diagnosis and had to go to work.
Shop gave an estimate of $890 to do both sides.
Re: Leaf springs last how long? [Re: supton] #5286749 12/06/19 09:47 AM
Char Baby Offline
The Firebird in my signature still has the OE leaf springs. ATMOF, the car still has all OE suspension parts except shocks. Granted, it's a summer only car w/45K mi.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Leaf springs last how long? [Re: supton] #5286788 12/06/19 10:44 AM
SteveSRT8 Offline
I have run service vans 200k plus miles on all original springs despite the fact they were about 9000 pounds every mile driven.
Leaf springs do not break often in my experience. I even took them out of a truck I drove to shows to be re-arched to rake the body a bit. Just not a typical failure at all IMO...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Leaf springs last how long? [Re: supton] #5286791 12/06/19 10:46 AM
Dave9 Offline
Yes that was too short a service life, bad metal or defect. Then again salt. You could've been driving through piles of it every day, but I would have expected the nearby areas in the pic to be swollen up from rust scale if the primary cause was salt.
Re: Leaf springs last how long? [Re: supton] #5286813 12/06/19 11:11 AM
F
Fawteen Offline
F
I would be. I've never had a single leaf or coil spring break in my life, and that includes some pretty severe loads and rough backroads. A quick search shows that in addition to all the frame rust issues, Toyota pickups also have an issue with breaking springs. There was even a recall on some models/years, so it seems to be a pretty common problem.
Re: Leaf springs last how long? [Re: SteveSRT8] #5286826 12/06/19 11:26 AM
L
Linctex Offline
L
Have some shipped up from a wrecking yard in AZ/NM/TX/OK - they'll be rust-free
Leaf springs do not break often in my experience. ........ Just not a typical failure at all IMO...
Agree 100%
Re: Leaf springs last how long? [Re: supton] #5286859 12/06/19 12:18 PM
A
andyd Offline
A
You could see a 50s-60s 10yr old Ford from a mile away at night by the angle of the head lights. 10 yrs was about what it took for the rears to lose temper. grin2
Thick oil is better grin2
Re: Leaf springs last how long? [Re: supton] #5286870 12/06/19 12:29 PM
02SE Offline
In a highly corrosive environment, anything can rust/corrode and fail, if sufficiently neglected.
Here's a 10 year old Explorer. It was all so bad it ended up being scrapped.
[Linked Image]
$890.00 is fairly steep. If you can source some new springs and install yourself it would be much cheaper. Of course then you're doing the work, too.
Re: Leaf springs last how long? [Re: Linctex] #5286873 12/06/19 12:30 PM
supton Offline OP
Hrm. Time to fix and flip I guess. Bummer as I liked the truck, but all good things come to an end.
Meh, they'll just be as failure prone I'm guessing.
Re: Leaf springs last how long? [Re: 02SE] #5286876 12/06/19 12:33 PM
supton Offline OP
I don't think it will fit in my garage, and at my new house I don't have a good spot to do the work (and if I did, it'd be covered in snow). And it's a "do it now" repair, I don't have time on my side.
Page 1 of 3 1 2 3
