NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
2012 Acura TSX Wagon
by WhyMe - 01/20/20 10:47 PM
Should I Stick With My Truck? Buy "new"?
by Miller88 - 01/20/20 08:04 PM
Not sure what Pep boys is up to
by Chris142 - 01/20/20 07:38 PM
NAPA Gold vs Platinum vs Ultra in Jeep JLU
by The_Captain - 01/20/20 06:07 PM
Love the Irish
by SAJEFFC - 01/20/20 06:07 PM
Pennzoil Gold 5W-30
by kstanf150 - 01/20/20 05:49 PM
AC Delco CF188
by K20FA5 - 01/20/20 05:00 PM
Wix WL10255 6,254 miles
by K20FA5 - 01/20/20 04:56 PM
when did handsfree and bluetooth
by WhyMe - 01/20/20 04:50 PM
2020 Dodge Durango GT
by parshisa - 01/20/20 04:18 PM
F1 filters
by Bettez88 - 01/20/20 04:10 PM
dfrybeck, ckinch1, EAC1, Kronguy, jamespeter26
70492 Registered Users
70 registered members (65convertible, BBDartCA, 750IX, bbhero, 5 invisible), 1,356 guests, and 13 spiders.
Topics300,377
Posts5,174,552
Members70,492
5w20 #5277452 11/25/19 10:22 PM
T
tiger862 Offline OP
T
I have been trying to find a heavier 20 grade since I drive in Louisiana heat one day and cold days in same week. I always ran 5w30 for everything but for warranty purpose I wanted to stay in 20 grade. From the viscosity number I get Synthetic is thinner so I did some math. 5 qts of 5w20 and 1 qt of 5w30 which pushes the Synthetic to same grade of 20 but heavy as conventional. Kills 2 things in I buy 5 qt jug of 5w20
for van and 5 qt jug of 5w30 for lawn equipment so no 1qt jugs. Best part of it all is if the dealership sends a sample out it will come back as 20 grade. Van runs nice and quiet on 20 grade and what I drive it will take 25 or so years to get to 200k. Anything wrong with the assumption? Both oil have same additive package
Tiger862
2018 Grand Caravan
Re: 5w20 [Re: tiger862] #5277454 11/25/19 10:24 PM
JohnnyJohnson Offline
I'm running PUP HM 5w-20 in my Corolla for the first time it seems to be doing great. Nearly 700 miles now.
2004 Corolla 138348
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: 5w20 [Re: tiger862] #5277456 11/25/19 10:25 PM
Z
zfasts03 Offline
Z
just run a light 5w-30 like pennzoil platinum
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: 5w20 [Re: zfasts03] #5277476 11/25/19 10:50 PM
T
tiger862 Offline OP
T
I am under warranty for 6 more years and 5w20 is recommended and 5w30 only when 5w20 is not available so a grey area. It takes 6 qts.
Tiger862
2018 Grand Caravan
Re: 5w20 [Re: tiger862] #5277487 11/25/19 11:08 PM
2004 Corolla 138348
2006 Duramax 77060
Re: 5w20 [Re: tiger862] #5277493 11/25/19 11:16 PM
dave1251 Offline
Unless you are tracking your daily driver the difference between the two ISLAC grades isn't worth worrying about. Unless you are concerned about the thickness of human hair.
don't use.
Re: 5w20 [Re: JohnnyJohnson] #5277504 11/25/19 11:24 PM
T
tiger862 Offline OP
T
Tiger862
2018 Grand Caravan
Re: 5w20 [Re: tiger862] #5277515 11/25/19 11:37 PM
Skippy722 Offline
Manual says 5w30 is fine, you won’t have any issues if you need warranty work. The Pentastar originally called for 5w30. You could try that new Pennzoil “Maximum Power” 0w30, as it has the MS-6395 spec. I was debating trying it, but I’m pleased with the Castrol 0w40 I put in both mine.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: 5w20 [Re: tiger862] #5277523 11/25/19 11:46 PM
R
Rolla07 Offline
R
Use any 5w20, why do you think heat or cold would cause any issue with it? You can run 0w20 if you want also.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: 5w20 [Re: Skippy722] #5277608 11/26/19 05:32 AM
demarpaint Offline
+1 I run 0W30 or 5W30 in mine, since about 1K miles IIRC. Many of the 5W30 oils carry the MS-6395 spec.
God Bless Our Troops
Re: 5w20 [Re: tiger862] #5277655 11/26/19 07:06 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Huh?
You mean at -35C? Otherwise this makes no sense.
Viscosity in the oil ratings system is a range of measured values. There are theories about flow characteristics of syn, but that’s not measured in the viscosity rating, at temperature.
You mentioned operating hot and cold, but are you routinely encountering far below freezing? If not, your math is suspect, because it’s just a measured value.
I think as others have said, find a light 30wt oil and run that.
Re: 5w20 [Re: tiger862] #5277676 11/26/19 07:31 AM
M
Mr_Luke Offline
M
Will not run Havoline ProDs any more.
I don't blame you. I will not run Havoline anything again.
I can't feel at ease while hearing my engine rattle like it's got sewing machine oil in it.
2012 Toyota Prius C / 108k
Conoco Phillips 0w20 FS
Not sure what brand the filter is
Re: 5w20 [Re: tiger862] #5277687 11/26/19 07:44 AM
I
IndyFan Offline
I
Mobil 1 EP 5w20 has a 100 degree cSt of 8.9. That seems to be on the thicker end of the 20 weights.
18 Jeep JLUR Wrangler 3.6 25k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 22k
08 Jeep Wrangler 3.8 135k
04 Jeep Grand Cherokee 4.7 105k
99 Mercedes E430 Sport 92k
Re: 5w20 [Re: tiger862] #5277688 11/26/19 07:44 AM
K
kschachn Offline
K
Does your owner's manual or warranty book say that the new car warranty is dependent on oil grade?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: 5w20 [Re: tiger862] #5277839 11/26/19 10:55 AM
P
parshisa Offline
P
No issues at all. I'm running mix of 5w30 and 0w20 Pennzoil in my '16 Honda Pilot specced for 0w20. Engine doesn't care, same sounds, same mpg.
