How drunk do you have to be to do this?
by dishdude - 02/17/20 11:09 PM
At least they show you
by Jake777 - 02/17/20 10:04 PM
Ryan Newman update
by P10crew - 02/17/20 09:17 PM
Thoughts on 2015+ Kia Sedona?
by 92saturnsl2 - 02/17/20 09:16 PM
Quiet riding tire
by wolf_06 - 02/17/20 08:27 PM
Where did the Ryan Newman thread go??
by P10crew - 02/17/20 08:02 PM
2013 FX4 repair.
by marine65 - 02/17/20 07:36 PM
New gaming build shutting down on Metro 2033
by Cujet - 02/17/20 07:09 PM
Snapon
by P10crew - 02/17/20 06:51 PM
Conventional or Synthetic
by charmer37 - 02/17/20 06:49 PM
Jeep Wrangler 3.0L Diesel
by HighbrowHillbill - 02/17/20 06:36 PM
94 B4000 overheat Eureka
by HyundaiAbuser - 02/17/20 05:48 PM
PP Euro 5w40 SN Plus formulation VOA
by BurntMusic - 02/17/20 04:35 PM
Bicycle Shops
by CourierDriver - 02/17/20 04:26 PM
EBC Brakes
by hatt - 02/17/20 04:17 PM
Dream Car
by MrQuackers - 02/17/20 04:06 PM
What are people using now for outdoor antennas?
by BAJA_05 - 02/17/20 02:49 PM
3.0L TDI
by Shorthorn - 02/17/20 02:48 PM
Mountain Bike Whee/Tire Sizes!
by jcartwright99 - 02/17/20 02:21 PM
Tgarst, Predator35001819, Markapuu, jds59, JimMorrison
70728 Registered Users
21 registered members (Black_Thunder, ctechbob, FT92, alanwayne1908, csandste, Geauxtiger, 2 invisible), 872 guests, and 21 spiders.
Topics301,597
Posts5,198,769
Members70,728
Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi #5274010 11/21/19 08:48 PM
SavagePatch Offline OP
Here's the latest UOA from my 2015 Ram 1500 EcoDiesel. The Redline 15w40 was ran over the summer camping season towing our travel trailer. I'm not impressed and wouldn't run it again. Lucky I got it at deep discount of $50 for 3 gallons.
Towed our travel trailer over a lot of "hard" grades: Kingsbury Grade between Tahoe and Carson, I80 between Sacramento to Truckee, Grape Vine, Cuesta Grade by San Luis Obispo, Pacheco Pass from Santa Cruz to Los Banos. So this little 3.0L was definitely worked hard but it held its own. I think that the finned oil pan with increased oil capacity along with removing the skid plate so it had better air flow under it definitely helped with the high temps these trucks see. That along with removing the sound deadening foam that's stuffed in and around the engine and leaving the engine cap/cover off.
If I had kept running this would the increase in soot be a concern?
The high silicon is from changing to an AFE oil pan. That increased the capacity 1.5qts to an even 12qts total.
Filled it with more M1 TDT 5w40 that I have on hand and bought at deep discount. Will be running the Valvoline Heavy Duty Maxlife 15w40 next summer camping season and will get an UOA from that.
(I do UOA's for fun and as a hobby)
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5274049 11/21/19 09:30 PM
double vanos Offline
I’ve used Redline driveline fluids (MTL, D4atf, and numerous diff lubes) and they’ve all done well. But looking at the UOAs here on bitog, I’m thinking their motor oils don’t justify the price. The YT channel project farm recently did a motor oil face off and Amsoil came out on top. But to me, the underlying theme was all the oils Project Farm tested, regardless of price, performed well. There’s a point of diminishing returns, where the extra dollars per quart just don’t translate to huge wear reductions.
A cheaper oil could have produced the same or better results.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5274070 11/21/19 09:52 PM
sloinker Offline
Looks ok to me. The silicon even without the new pan is a trademark of Red Line, they always have higher levels of silicon, straight from the bottle. The soot is a different story. It will be interesting to see if it diminishes with the M1 in it now or if you have a cylinder bypassing extra combustion by-products. The last oil had a high fuel load that the Red Line didn't have. Interesting.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5274271 11/22/19 07:54 AM
SubieRubyRoo Offline
I think you've already found your answer, and would personally stop with the musical oil choices... JT8 synblend and RT6 give the best individual data points, and it's not on the order of splitting hairs over a couple PPM. Both of those oils are well respected, and I'd say you'd gain more knowledge about your engine by sticking with one of those for 2-4 OCIs in a row. Especially since you knew your silicon was going to be high this time, and gasket silicon is not abrasive, there's nothing to explain higher iron and aluminum counts.... which leads back to JT8 and RT6 giving the best overall picture for your engine, in your usage from the data collected so far. Get some trends instead of individual data points and make a decision from there.
De omnibus dubitandum.
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5274295 11/22/19 08:17 AM
I should a couple of things that changed between this OCI and the last one.
My truck had the Approved Emissions Modification (AEM) tune flashed to the ECM at the dealer as part of the EPA lawsuit against FCA. Perhaps that's where the higher soot came from?
Also, the new oil pan (along with the increased capacity) has a magnetic oil plug.
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5274417 11/22/19 10:03 AM
P
paoester Offline
P
You mentioned soot; Yes it would be a concern. Probably high due to hard towing pulls. I guess the AEM would reduce NOx emissions, increasing soot some, although shouldn't be too much difference.
The soot is likely responsible for the higher iron wear this time around.
I'd just pick the cheapest qualified Rotella at walmart. Name brand stuff, easy to get.
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5274656 11/22/19 02:49 PM
J
jayg Offline
J
That AEM is junk. I know you're in California but a tune and exhaust dropped my soot and EGTs dramatically. If only you had a way to get around it these days.
The oil looks fine but that soot from the new programming on EGR isn't doing you any favors. Have you replaced your factory EGR cooler under warranty and did you sign up for the class action lawsuit for 2014-2016s?
2019 Toyota Prius E-AWD- TGMO 0w16
2017 Ram 1500 Ecodiesel- CP Triton ECT 5w40
1973 Datsun 240Z 10w30- VWC from '73
...and a bunch of old motorcycles
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5276518 11/24/19 06:40 PM
J
jkhawaii Offline
J
From past redline useage I found that redline has high silicon from the factory. Additive likely
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5277868 11/26/19 11:34 AM
M
mpack88 Offline
M
Seems like 15w40 mystic synblend had the least amount of wear.
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5281035 11/30/19 11:09 AM
P
panthermike Offline
P
Other than higher soot, looks fine to me. But it is hard to justify regular usage at RL prices and Lower OCI's.
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5282998 12/02/19 02:23 PM
F
Fraser434 Offline
F
Thank you for posting, I too had the AEM recall, which i'm not happy about and wish I could've opted out. Doesn't have that nice deep torque band anymore and always wants to downshift from 8th on the slightest grade, everything feels somewhat numbed.
I'm running Mystik JT8 10W40 since your good results with that brand and heavily discounted pricing locally, gonna run it down till I see single digits in the forecast then put in 5W40 or 0W40.
Re: Redline 15w40, 2015 RAM EcoDiesel 3.0L, 6,146mi [Re: SavagePatch] #5283254 12/02/19 06:21 PM
A
ad244 Offline
A
Dang! 12 quarts every 6,000 miles starts to get pretty spendy quick!
