Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
101 registered members (4WD, alcyon, AlaskaMike, 38Chevy454, 2015_PSD, Aero540T, 5 invisible), 1,947 guests, and 56 spiders.
Topics298,361
Posts5,133,783
Members70,047
Most Online3,589
Nov 2nd, 2019
Discount tire lift question #5273955 11/21/19 07:32 PM
N
NissanMaxima Offline OP
N
Hi all;
Got some WeatherReady all-weather tires installed today at Discount. Are folks here familiar with the little lifts they use - see photo I found on internet which is similar to what they used. After the car was over the lift with those lifters that basically recess into the floor, they raised up the car and I noted each long rectangular and padded side of the lift contacted the underbody of the car rather than contacting the length of each pinch weld. The length of the non-contacted pinch weld was actually about 2" above the length of the top of the rubber padded lift surfaces. I looked under the car from the parking lot and noted there was perhaps 1/2" to no gap between things like exhaust pipes and the like. I asked the manager, who was actually the one that started work on the car, about it and he said they do this all the time and no worries it was not contacting the pinch weld. I asked my Toyota service manager about this and he said Toyota only approves lifting via those pinch weld areas and their four pole lifts contact only the pinch welds. The dealership agreed that although probably not the best, likely no harm was done due to the huge contact area and distribution of weight but yet I'm still surprised DT would do this especially since they had giant metal blocks with black rubber cushions all over the place and I noted they used them on other cars on the lifts basically suspending the car with four blocks contacting the pinch weld areas (two blocks per side obviously I did look under the car at home afterwards and it seems there are some support members running front to back on the car but who knows what else the lift was contacting under the car. This sure doesn't seem like an ideal way to lift a car.
Also, they tightened the lug nuts by hand and then used the torque wrench rather than impact driver/torque stick per my request but is it acceptable to run each lug nut to torque spec one by one in the star pattern and then once again checking torque around in a circle? I would think you would want to cinch them up past finger tight below torque setting and then again to spec rather than one by one to spec. which is supposedly what doing it with an air gun/torque stick would do, right?
Thoughts?
Re: Discount tire lift question [Re: NissanMaxima] #5273961 11/21/19 07:37 PM
O
oldhp Offline
O
They wouldn't touch my car/truck. I don't care how many they with no harm. The factory has lift points. Period.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Discount tire lift question [Re: NissanMaxima] #5273985 11/21/19 08:10 PM
E
earlyre Offline
E
i have no problems with them..
the local tire shop I go to lifts cars with 3 trolley jacks. every time I've gone there.
2 at the front pinch weld lift points, and one under the middle of rear subframe.
the DT lifts seem...better...
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
Re: Discount tire lift question [Re: NissanMaxima] #5273986 11/21/19 08:15 PM
skyactiv Offline
In my opinion, Discount Tire is the worst national tire retailer in the USA. Every single installer in the shop is a guy under 25 it seems. Have fun and good luck getting quality work done on Black Friday.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Discount tire lift question [Re: skyactiv] #5273999 11/21/19 08:33 PM
E
earlyre Offline
E
wow... who do you expect to work as an "installer" at a tire chain?
maybe My experience is skewed...that's what you get at 90%+ of shops in the area...we are home to a nationally known Auto/Diesel/Motorsports college...
Mine:
Re: Discount tire lift question [Re: NissanMaxima] #5274000 11/21/19 08:33 PM
H
hallstevenson Online Content
Online Content
H
Originally Posted by NissanMaxima
Thoughts?
Sounds like you're just looking for reasons to criticize them. Best thing for you is to simply not go back to them.
Re: Discount tire lift question [Re: NissanMaxima] #5274018 11/21/19 08:55 PM
A
atikovi Offline
A
There is a reason they are called DISCOUNT and you found out.
Re: Discount tire lift question [Re: hallstevenson] #5274028 11/21/19 09:02 PM
N
N
Thoughts?
Not sure why you got that impression. I wanted to see if the forum agreed with the dealership about pinch points being the only location acceptable to lift the car and the only time I have lifted a car is to change a flat tire which has occurred maybe three times in my lifetime so not much experience with lifts. Plus, one would think after all that a huge national chain like Discount that is supposedly corporate-owned and not even franchised, would have lifts that would not damage cars they are working on. And, in general, it seemed DT had a fairly good reputation on this forum.
Re: Discount tire lift question [Re: NissanMaxima] #5274064 11/21/19 09:44 PM
Skippy722 Offline
They used the little blocks when they did my 300, the lift would rest on the side skirts otherwise. As long as it wouldn’t bend/break anything I wouldn’t care if they used the pinch weld or not personally. I’ll definitely be using them again, they had me in and out in less than an hour and had my RT43’s balanced perfectly.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Discount tire lift question [Re: skyactiv] #5274066 11/21/19 09:46 PM
slacktide_bitog Online Content
Online Content
They way they lift is fine. A real 2/4-post lift isn't necessary since they only have to raise the car high enough to get the tires off the ground and they're not going under the car smile
Also, Toyotas do NOT have to be lifted by the pinch welds! You can lift the front of the car by the bar in the front. It will be near or at the front axle, right between the front wheels. There is also a rear jack point between the rear wheels.
DT and Walmart are the only ones that torque properly and don't just zip it down with an air gun!
Re: Discount tire lift question [Re: slacktide_bitog] #5274074 11/21/19 09:55 PM
N
N
[quote=slacktide_bitog]They way they lift is fine. A real 2/4-post lift isn't necessary since they only have to raise the car high enough to get the tires off the ground and they're not going under the car smile
/quote]
Thanks... basically I didn't know what support members (if any) are under the car to be able to lift it in this way. I was thinking it was lifting up against the underside of the floorboards or other areas that shouldn't be contacted but like I said originally, it does seem there are some rectangular looking beams running front to back on both side about 8" or so in from the pinch weld that I think were in contact with the two lifts of their assembly. I am aware in general about the other jack points as my factory service manual for my Maxima show the locations I think you are talking about and I think some of them are quite common to cars, but thanks for that too.
Re: Discount tire lift question [Re: NissanMaxima] #5274100 11/21/19 11:08 PM
Online Content
The QuickJack is basically a home-use DIY version of the setup DT has, so if you'd trust a QuickJack, you can trust DT
Re: Discount tire lift question [Re: hallstevenson] #5274111 11/21/19 11:31 PM
Sayjac Offline
Quote
Thoughts?....
Been buying tires from b&m DT since 2004 and had them installed and regularly serviced to maintain warranty, balance and rotation. Whether lift or floor jacks, and I've had both used, never an issue.
So based on my experience my thought is in agreement with a previous post quoted. Lots of other places to buy tires.
Quote
Re: Discount tire lift question [Re: NissanMaxima] #5274115 11/21/19 11:39 PM
J
JGmazda Offline
J
Never had a problem with DT and I've had them work on Trucks, Sport cars, and Sedans. Sometimes they used the rubber blocks to gain the correct distance from suspension and exhaust members. I would agree with those that question the age-factor. I've had to stop a few of the "young-un's" a few times to correct the torquing and lug nut applications. They do a pretty good job and I would imagine they are trained well. Having said that, I prefer they don't behave like a NASCAR pit crew and slow it down for guys like me that want it done correctly.
2008 KIA Sportage
Re: Discount tire lift question [Re: slacktide_bitog] #5274139 11/22/19 01:14 AM
N
N
Interesting product. I looked at a few YouTube videos. It looks like it comes with pads that contact four points on the pinch weld area though - not like what I experienced today where the lift cleared the pinch weld area and made contact on the underbelly of the car.
