Did some fluid changes this weekend, put Valvoline SAE 75W-140 Full Synthetic Gear Oil in the differential and GTX MAGNATEC 5W-30 and the power steering fluid. The diff was gross, grayish goo and the power steering was brownish. It drives so differently now, acceleration seems tighter if that makes sense. Also put on 4 new tires. Next weekend is probably drop the transmission pan and do a filter and gasket and 5 quarts of fluid. The current coolant has a yellowish color, is that the correct one for this year?
