Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Rotella Multivehicle 5W-30
by js1956 - 05/31/20 10:54 AM
Tesla Model 3 Driving Guide
by JeffKeryk - 05/31/20 10:41 AM
Keep OE carb vs replacement
by JHZR2 - 05/31/20 10:00 AM
Gave away some of my stash
by Chris142 - 05/31/20 08:32 AM
Two year check in - Dewalt 20 V String Trimmer
by Snagglefoot - 05/31/20 08:07 AM
AbbeyRoad, RPF, Rayi, juca, jrow96
71584 Registered Users
89 registered members (10WSmuckers, anndel, ammolab, A_Harman, 55hambone, 2015_PSD, 8 invisible), 2,386 guests, and 23 spiders.
Topics306,102
Posts5,286,465
Members71,584
Page 5 of 6 1 4 5 6
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #3385805 05/31/14 07:29 PM
R
RISUPERCREWMAN Offline
R
My Harley V-Twin runs cooler with Syn oil this I can see on the oil temp gauge!
2018 Ram 2500 HD 6.4 Hemi Crew Cab 12K miles Pennzoil Ultra 0W-40
8'Boss SuperDuty Plow
2017 Harley Davidson Milwaukee 8 Limited 10KMiles Amsoil 20W-50
2010 Toyota Avalon XLS 56K miles Amsoil SS 5W-30
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #3385939 05/31/14 11:01 PM
M
MileHigh18 Offline
M
My temp gauge in my Trailblazer seems to have dropped a few degrees now that I'm using PP. Pretty crazy. Usually it sat right at 210 with PYB, but now it's just outside of the 210 mark and usually stays there even with the AC on and at red lights.
2002 Trailblazer LT 119K
Pennzoil Platinum 5-30
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #3387245 06/02/14 07:00 PM
boxcartommie22 Offline
absolutely!!
2001 Lincoln Conti,RL,K&N,Hotshots,Lubegard,Archoil
2007 Grand Marquis,RL,K&N,Hotshots,Lubegard,Archoil
2010 Raptor,RL,Hotshots,Lubegard,Archoil
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #3387460 06/02/14 10:58 PM
R
Ram01 Offline
R
Dino oils are protecting and cleaning motors just as or if not not better than syn
Re: Does full synthetic make your car run better ? [Re: Ram01] #3388362 06/04/14 01:18 AM
R
raytseng Offline
R
Here's another question.
So if synthetic and dino cost the same price, some would pick the dino? How about if it were only 50cents more expensive?
I find that a lot of people's justification dino really always come down to cost. But they don't discount that synthetic does no harm.
Yet with the price gap relatively small (the cost of a burrito), basing the choice on cost seems to be a false choice to me.
Re: Does full synthetic make your car run better ? [Re: RISUPERCREWMAN] #3388374 06/04/14 03:22 AM
Clevy Offline
You know that means the oil is absorbing less heat right,proven by the oils lower temp,since the engine is shedding the same heat it always does because of combustion and friction.
Synthetic lasts longer in service but its still just oil.
At 5000 mile intervals for conventional and 10000 for syn in the same engine I will bet there is no difference whatsoever in wear or cleanliness.
And truth be known I've found conventionals to run smoother and more quiet then their synthetic counterparts.
2006 Charger RT
Miles x 2 per oil filter
Re: Does full synthetic make your car run better ? [Re: DaveInIreland] #5267616 11/14/19 10:29 PM
DaveInIreland Offline
Originally Posted by DaveInIreland
I have a pair of 30 year old Universal Japanese Motorcycles, and can say with some certainty that changing to synthetic to get the 5W grade at the bottom end paid dividends in eliminating cold clutch drag and it also lets the engine rev more freely, of that I'm sure.
Butt dyno says it's a little bit better, but who knows - these things are totally subjective and I could be feeling something that I'm looking for.
The other benefits of synthetic in an air-cooled engine; greater resistance to heat breakdown and (hopefully) shear resistance will make themselves known in the next few months. This is my first fill of synthetic and I'm waiting to see how it pans out.
Currently I'm running a diy blend of 1L 5W/50 Champion Race Synth (to get some of the extra ZDDP) and 2L 5W/40 Pennasol (re-branded as Lidl synth) and according to this, I have a viscosity of 97cSt
http://www.lubebase.com/cgi-bin/graph/calculate-blending-vg?desired_vg=97&visc1=88&visc2=118
The overall result is pleasing; no cold clutch grab and gearchanges are nice and smooth, although the quality of gearchange might deteriorate as the oil ages. Clutch slip, while not totally absent, only shows when provoked and isn't a problem, as such.
Thought I'd just update that above.
The clutchslip became a little mor frequent over the next few thousand miles, but never enough to prompt me to replace it. I eventually replaced the clutch as a clean-sweep when I had the top end and barrels off to refresh the top and fix an inevitable bottom-gasket base leak the GS850 Suzukis all suffer from.
On examining the old clutch and springs, there was nothing wrong with the plates, save a bit of glazing - no discernable wear thin-ness but the springs were all weak. Standard factory springs from 1980. I replaced with new plates and a mix of 3 HD and 3 new factory springs, and it's now perfect. The old clutch had done at least 80K miles and likely a lot more.
I'm sure if I de-glazed the old plates they'd probably do fine in another engine used purely as a second-line bike.
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #5267624 11/14/19 10:40 PM
J
jongies3 Offline
J
I run syn in my Tacoma and dino in my Buick, I can't tell a difference.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: QSGB 5W-30, FRAM PH3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #5267731 11/15/19 02:00 AM
slybunda Offline
Noticed engine takes a bit longer to warm up with synthetic.
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: Does full synthetic make your car run better ? [Re: gathermewool] #5267739 11/15/19 03:36 AM
G
GMBoy Offline
G
Originally Posted by gathermewool
Originally Posted by DirtyMoe21
Better starting in cold weather is all ive noticed.
In TX? You got jokes,huh?
It was in the 20's this week. We get the occasional cold snap here and there lol
Re: Does full synthetic make your car run better ? [Re: RISUPERCREWMAN] #5267740 11/15/19 03:37 AM
G
GMBoy Offline
G
Absolutely! I noticed the same thing - a good 10-15 degrees cooler on a hot day.
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #5267818 11/15/19 07:58 AM
blupupher Offline
I have never noticed a difference in how a vehicle runs based on what oil is in it.
A lot of the butt dyno improvements are justification for spending more.
I know of no butt calibration device to be able to qualify "improvements".
I am not saying there are not benefits to synthetic, because there are, but have never personally seen, felt or heard difference base on syn vs dino.
Main reason I use synthetic is it is cheaper that conventional when you find it on sale/clearance/rebate.
I don't do long intervals and have no specialty vehicles that "require" it, and could use the cheapest "dino" oil (which is all a syn blend now anyway) and have the same results.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Does full synthetic make your car run better ? [Re: GMBoy] #5268014 11/15/19 11:20 AM
K
ka9mnx Offline
K
Yep. My 2 Fords and Ram Van run cooler on synthetics (highway running). The 4Runner doesn't change.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #5268035 11/15/19 11:50 AM
L
littleant Offline
L
Can not say if my 02 jeep runs better but I will state this fact. At minus -20--40 using (5W30 Pennzoil platinum high mileage with a fram ultra will start without an oil pan or block heater where synthetic blend or conventional 5W30 will not.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Does full synthetic make your car run better ? [Re: Merkava_4] #5268099 11/15/19 12:59 PM
F
FordCapriDriver Offline
F
I only noticed more noise in my cars and higher oil consumption ( none on Dino or Syn-Blend )
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Page 5 of 6 1 4 5 6
