2013 Escape 2.0 Ecoboost surge
by HoosierJeeper - 01/19/20 10:36 AM
European Tools via Amazon - New Lug Wrench
by JHZR2 - 01/19/20 09:57 AM
Samsung 32 inch 4K curved monitor at Costco
by Cujet - 01/19/20 09:55 AM
2009 corolla 1.8
by Bettez88 - 01/19/20 09:41 AM
Remote key - OEM vs aftermarket
by AZjeff - 01/19/20 08:13 AM
Toyota Tundra Warranty
by Tundra73 - 01/19/20 08:10 AM
Shell Rotella gas truck oil change intervals?
by gtrplr71 - 01/19/20 07:12 AM
Ford Focus belt idler puller bolt ?
by rkpatt - 01/19/20 06:51 AM
Havoline 5w20 $1.72/quart
by Villalobos - 01/19/20 05:42 AM
Amazon 5qt PUP 5w-20 $16.24
by Matt1980 - 01/19/20 03:42 AM
US Miltary News - F22
by ZeeOSix - 01/19/20 03:09 AM
OEM to Ravenol
by graphine - 01/19/20 02:38 AM
D905 Brake Pads: Bosch vs. Centric vs. Akebono
by The Critic - 01/19/20 01:55 AM
Dodge dart running issues after filling up fuel
by ram_man - 01/19/20 12:58 AM
Akebono ProAct brake pads now include hardware
by The Critic - 01/19/20 12:43 AM
16 Audi S3 G13 Coolant - 40,500 miles
by agpatel - 01/19/20 12:43 AM
BMW “G3” Axle Alternatives?
by E365 - 01/19/20 12:20 AM
Scan Tool recommendation
by zmelli - 01/18/20 11:57 PM
Keyless Entry Help Needed
by DeafBrad - 01/18/20 11:55 PM
75/140 owners manual vs 75/90 tag
by BigGee - 01/18/20 11:36 PM
madjid, michWB, Brianhefty, JimBremer, Katdaddy
70471 Registered Users
98 registered members (alchargo, AlienBug, aircooled, 4WD, Alfred_B, aquariuscsm, 7 invisible), 2,560 guests, and 20 spiders.
Topics300,313
Posts5,173,065
Members70,471
Most Online3,728
Jan 11th, 2020
Page 1 of 5 1 2 5
Rescuing a critically sluged 6.4 F-350 #5266911 11/14/19 10:02 AM
N
NDServices Offline OP
N
Greetings Oil Gurus, and thank you in advance for any advice on this or a link to where on this forum this question has already been answered.
I acquired an 08 F-350 with a 6.4 Powerstroke with 92k miles this summer to use as my heavy hauler, and it had a laundry list of issues at the time that I felt could be solved to make the truck useful once more as a work truck for my tree service. Its primary function is to haul heavy loads such as my 14-yard and 20-yard dump trailer. The previous owner was in a bad way, and gave me what I thought was full disclosure of the issues and priced the otherwise nice truck for 9K. Those included blown turbos and the trucks remarkable capacity to shoot fire from the muffler during regen (I had heard about that but never seen it personally until this summer). That stated, it cranked right up and my local mechanic confirmed he felt doing a DPF-R delete and replacing the turbos and for good measure the oil cooler while the cab was off and he had reasonably easy access. All of this was in my budget to rehab it. His shop is quite reputable. It's a "get in line and wait so this particular man can work on your powerstroke" type shop. I bought the truck, had it hot-shotted from Jacksonville to Orlando straight to the mechanic and did all those repairs (New Turbos, DPF-R (Stock tune - no extra ponies added), OEM Oil Cooler). He suggested the rocker arms would need replacement sometime soon (by that he meant as soon as I could afford), and I agreed I'd get to them as soon as I had the cash and could deal with a couple days down-time without the truck. In the interim he suggested I attempt to address the sludge issue with Rotella T6 5w-40, changing the oil with every 2-3k miles for the first 10k miles I owned it...and the detergents should gradually reduce the sludge.
4k miles and one oil change later, I took the truck to our farm outside of Gainesville this past weekend and the #4 rocker arm failed catastrophically at about 35 mph. The truck was immediately turned off (less than 15 seconds of total run time after failure) and I threw the transmission into neutral and wrestled her over to the shoulder using the truck's forward momentum to steer it. It was flat-bedded to Ocala where the following work was done on it by what most locals deem the best guys around for powerstrokes: These are the direct notes from the invoice.
"Verified customer concern, performed diagnosis, determined noise to be coming from internal driver side of engine, requested tear-down time for further inspection, found #4 exhaust-side rocker broken, also noticed a large amount of sludge in the engine most likely due to a lack of maintenance, recommend and replaced driver side rocker arms and bridge assembly along with injector harness and glow plug harness as well as injector supply tube. ADVISE CUSTOMER CATASTROPHIC ENGINE FAILURE MAY OCCUR DUE TO LARGE AMOUNT OF SLUDGE IN THE ENGINE."
He was less clinical in our verbal discussion which went something like, "Normally when I hand the keys to someone after fixing their truck I tell them they can drive to Texas right now and get there. I can't promise you'll make it to Sanford before the engine comes undone altogether. If you get it home you need to sell it ASAP. It might go two weeks, and it might go 2 years, but you can never trust this engine after this level of neglect. Any aggressive attempts to de-sludge the engine while its running using available products may result in a large piece of the sludge breaking free and clogging something vital which will finish it off. It's a time bomb on wheels."
He said he did his best with time and budget constraints, which included two full oil changes and dropping the pan and scraping it and completely cleaning that component of sludge. He said the only good news was a lack of any sizable metal in the pan.
I cannot in good faith sell this truck to a private owner. I don't have the cash or know how to tear it apart and manually desludge it. Nor do I really have the money right this instant to get a replacement truck. Remarkably, it is running quiet as a 6.4 ever does (top end is super quiet), and better than it has since I bought it. Computer says 14.4 mpg. No codes. No smoke. No odor. That stated, he was adamant. I'm a small company and I am responsible for this gamble which I lost out on big time, it seems. Based on this information, is there anything that can be done from a lubricant perspective short of a complete tear-down to buy me some time on a time bomb? I will listen carefully to any advice here, and answer any questions you may have to better understand the situation. I'm already pretty humbled, so play nice, please. Thanks again.
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5266918 11/14/19 10:09 AM
B
Bailes1992 Offline
B
Get the rocker covers and sump removed. Use plastic scrapers and a shop-vac to clean out as much sludge as you reasonably can. If there's any baffles or windage trays that can be removed and cleaned, do so. Make sure the strainer/pick-up tube is cleaned and free of sludge. Make sure the sump and rocker covers are spotless before you re-install them.
Carry on using a HDEO with short intervals, this will gently clean the engine over a period of time. Maybe after a good number of intervals and you've got a feel for the engine and you start to trust it look to do a long interval with Valvoline Blue Restore 10w30 to give the ringlands a good clean.
I'm sure this engine will live a long life given a little TLC.
19 Volvo V40 D3 Auto Shell Helix ECT 0w30
07 Saab 95 TiD Auto Castrol Edge 5w30 LL
03 Ford Mondeo 3.0 V6 Shell Helix 5w40
96 Defender 300TDi Maxlife 15w40
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5266952 11/14/19 10:50 AM
R
Rand Offline
R
Why is the engine sludging?
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5266954 11/14/19 10:52 AM
R
ragtoplvr Offline
R
The mechanic has to cover his (edit - mod). A new reman ngine is how much $$$$$ He does not want to be on the hook for that.
They make low oil pressure alarms, I would invest in one just in case
Rod
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5266970 11/14/19 11:10 AM
c502cid Offline
A couple of slow deep breaths here to start. Any used vehicle carries risk otherwise you buy new with warranty. I've bought vehicles that I discovered after the fact many things wrong, some major like yours. Some lasted a short time, some lasted a very long time. Take this one day at a time, and continue on your plan to gradually de-sludge it. Taking off the pan was a good first step to remove larger chunks of it, and as suggested above, under the valve covers are next. Engines are tough birds, they can take a remarkable amount of abuse. Good luck!
16 F150 2.7 EB 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: Rescuing a critically sluged 6.4 F-350 [Re: ragtoplvr] #5266977 11/14/19 11:13 AM
carviewsonic Online Content
Online Content
Rod
- This -
You've got nothing to lose at this point, so you may as well use it. And good on you for not unloading it on someone else. IMO, if the engine is running good now, some TLC in the form of frequent oil changes and not abusing it with excessive loads will keep it running good for a long time to come. Disclaimer: I'm not a mechanic, but have always had a high mileage beater in my personal fleet, and have never had an engine fail.
'18 Impala
'05 Park Avenue
'03 Park Avenue
'07 Honda Accord
'09 VStar 1300
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5266999 11/14/19 11:31 AM
W
WhyMe Online Content
Online Content
W
continue with the desluding and drive it till it dies. if it does ,part it out or find a used engine
Re: Rescuing a critically sluged 6.4 F-350 [Re: ragtoplvr] #5267036 11/14/19 12:09 PM
J
jeepman3071 Offline
J
Rod
+2
The 6.4L is a bit of a fragile engine to begin with. I would do as he suggests to try and de-sludge it gradually. The fact that this engine has been neglected is a bad sign, because this already money pit of an engine has the potential to become even more expensive. Have you tried selling it to carmax?
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5267055 11/14/19 12:26 PM
J
Jimmy_Russells Offline
J
Williams Diesel?
6.4L has known rocker issues. They are famous for diesel in oil from regens which in turn destroys the valvetrain. Not to mention the somewhat fragile fuel system. I also recommend unloading the truck if you can. Most shops here in town will not even attempt to fix a 6.4L like this, they immediately call for new engine because the fixes almost never seem to work long term.
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5267074 11/14/19 12:41 PM
N
N
Okay, so I don't want to call out the specific shop in Ocala, because it does seem they did a [censored] good job fixing the left side. I've never heard or felt it so smooth. I am also going to take it to Carmax this afternoon just to see what they say. Cosmetically it's in great shape. Always a central florida truck. No rust. F-350 Crew Cab SRW 4x4 Off Road Pkg...(I literally cannot fathom the first owner neglecting this engine like this. This was an expensive truck!) Might be able to recoup some money that way and absolve myself ethically from its future.
If they come in too low, I'll go to plan B, which is to take the advice given here on how it's life may best be preserved. Will update here after I get back from CarMax. Thanks all!
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5267107 11/14/19 01:00 PM
Donald Offline
All the Ford pickup diesel engines prior to the 6.7 had minor to major issue. Go to powerstrokehelp.com and read up.
Typically people spend some major money on these engines and then they are super. Sludge may be the least of your problems.
2015 Ford F-250 w/Powerstroke
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5267108 11/14/19 01:01 PM
J
J
Wasn't trying to call anyone out, was just curious because we work fairly closely with some of the guys at Williams, and they absolutely know their stuff. thumbsup
Hope you get this sorted, nightmare.
Re: Rescuing a critically sluged 6.4 F-350 [Re: Jimmy_Russells] #5267134 11/14/19 01:21 PM
Donald Offline
That does not mean that they have a diesel engine expert. Which is what you need.
I would shop around for an indy diesel shop who has experience with the earlier PSD engines. Once they are upgraded they are great engines and do not have all the pollution stuff the 6.7 engines have.
Re: Rescuing a critically sluged 6.4 F-350 [Re: NDServices] #5267137 11/14/19 01:23 PM
M
Miller88 Offline
M
I don't think Carmax is going to take an emissions deleted truck, and if they do, they won't offer anything because it's going straight to the auction block.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Rescuing a critically sluged 6.4 F-350 [Re: Donald] #5267158 11/14/19 01:41 PM
BeerCan Online Content
Online Content
Williams Diesel, it's literally in their name and all they do is diesel. They have a good reputation
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Page 1 of 5 1 2 5
