Gratitude
by rrretiree7 - 02/27/20 11:56 PM
Maxlife for 35yo Ford C6
by Cubey - 02/27/20 11:35 PM
New 2-post lift on order
by clinebarger - 02/27/20 11:07 PM
by tenderloin - 02/27/20 09:59 PM
New F-150 2.7 EB recommendations?
by mattri - 02/27/20 09:37 PM
Honey I bought a set of wheels
by P10crew - 02/27/20 09:29 PM
PQIA Pennzoil Hybrid 0W-16
by kstanf150 - 02/27/20 08:32 PM
100,000 ducks sent to Pakistan.
by Vern_in_IL - 02/27/20 08:07 PM
06 Camry Coolant??
by Jcountry - 02/27/20 07:54 PM
PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
Sony MEX-GS820BT, good AM/FM?
by sasilverbullet - 02/27/20 05:59 PM
hogryder007, Sabbag77, RpR, jameswilliam, Agraz400
70819 Registered Users
54 registered members (Avery4, allgm59, bbhero, ArrestMeRedZ, AC1DD, BLND1, 5 invisible), 1,219 guests, and 23 spiders.
Topics302,026
Posts5,207,447
Members70,819
valve body torque difference #5266204 11/13/19 04:07 PM
H
HyundaiAbuser Offline OP
H
I recently did a band adjustment and valve body bolt torquing on my 94 b4000 w the a4ld transmission and let me tell you, it has made the world of difference. Where reverse used to delay about a second then have a hard engagement (not quite a slam although that happened once or twice) it is not smooth and immediate. My first to second gear shifts used to be hard, delayed or if low on fluid at all slip a little. After the adjustments and torquing the shifts are also smooth as can be while still noticeable when paying attention. I also did this in part to my store of valvoline dex/merc. Down to 3 gallons...
But if you get the opportunity, have the tools and the specs and the willingness. I would 100% recommend torquing valve body bolds and performing band adjustments whenever you pull the pan. Do any of you guys have similar experience in this subject?
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Supertech 5w30 Full Synthetic
Valvoline Dex/Merc
Re: valve body torque difference [Re: HyundaiAbuser] #5266240 11/13/19 05:04 PM
bdcardinal Offline
This is the first I have heard of doing this, but it does make sense.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
