Water softener input/recommendations
Iowa
Hey guys, not long ago we had a new well drilled - the old well had a 3" iron casing that rusted through, allowing sand to enter and wreak havoc on our domestic water. New well is in a different aquifer and has MUCH improved water (old well was very high in iron and manganese, plus very hard), so we don't need the level of softener that we currently have - it is a big Culligan rental. I'd like to buy a smaller unit and get rid of the $60+/mo bill. The well guy tested the water and stated no iron and had 8 grains hardness and said that a softener from Menards would suffice. While I'm inclined to believe him, I'd like to get others' experiences and input, as well as get alternative brands or systems.
We went to Menards and found a few Morton units (considering the M45) and a Water Boss (Pro 180).
The raw water line will have a double spun poly filter to remove any calcium and lime that may be in the water (well guy said it may take some time before it shows up) ahead of the softener.
Anything BUT Culligan. I have a Culligan and wish i had done lots more research b4 wasting my money with them.
$60 a month for a water softener rental? That's felonious. I know there's a hefty markup on dealer installed systems that you purchase. So if you can do the plumbing yourself, any decent name brand should do.
We have a Kinetico, no electricity required and works flawlessly. But I'm by no means an expert, I've only had well water for the last 6 months!
I would suggest giving a good filtration system a try for a while to see if you even need a water softener. That's what I did, after trashing the softener the previous owner installed. It turned out what the system really needed was just filtration.
8 grains is not much. I would also try a filter first... get the long blue one from Menards for about $80. Otherwise the Morton softener from there should serve you well. Since one is already there, a plumber should be about two hours to put it in if you can't.
I just put in one two and a half months ago from Discount Water Softeners (.com). It softens well and uses very little salt, but it does not meter water flow correctly so I have had to modify the hardness setting or else I get hard water every 5th or 6th day. At least one other person on the reviews said the same thing. After sale support has been poor from the vendor, once they have your money they don't care about any problems and don't return calls or emails.
A water softener uses ion exchange process to pull calcium (hardness)(and generally a modest level of iron) from the water and replace it with sodium ions. Hence the "soft" water. The "size" of the softener is related to how many ions can be exchanged before it needs to be recharged (60,000 grain) . Small tanks vs. large (at a glance) are a pretty good way to know. BUT, unscrupulous companies could use a large tank and only one bag of resin... (I've seen this)
A spun poly filter will help remove particulates above a certain size, not calcium. It's just a filter.
A carbon filter will help remove chlorine, tannin's, and other organics (VOC's) and some metals (lead) that a softener can't remove. If you use one, it must come after the softener.
Of note, some softeners have low flow rates, especially if they are small/cheap units. If you have a large house or higher water flow needs, I suggest a full sized unit with good flow capacity.
My preference is the "old school" softener with a mechanical valve, and a separate salt tank. Very tolerant of lightning strikes/power surges, easier to service and very reliable. The quality of the water is the same, but the price of digital (or flow meter) equipment can be double or triple.
Let's put it this way, you can purchase a good flowing, full size, ultra reliable mechanical timer, 64,000 grain system (large enough for a modest family) with mechanical valve, for $650.
https://www.discountwatersofteners.com/water-softeners/fleck-5600-timered-water-softener/
https://www.discountwatersofteners.com/fleck-5600-sxt-on-demand-water-softener/#compare
[Linked Image from cdn11.bigcommerce.com]
I was just parroting what my well guy said when I asked about calcium/lime - I'm relatively sure he stated that the filter he sold me would remove them, but I very easily could be mistaken.
I hear you on the flow ratings - I'm almost always suspicious of claims made in consumer grade equipment and this is no different. The Morton units were claiming 15-20 gpm, but that's at 30psi, our set up is 50.
You stated the filter must come after the softener - why is that? To ensure sufficient water flow for regeneration cycles? On that note, the filter is a 20", 5 micron blown microfiber spun polypropylene unit. (p/n 14-GSP2-05)
That Fleck 5600 Timer set up you linked looks good, but I couldn't find how it regens. Does the timer just count down X amount of days, then run at the time you set it to?
I too have a Kinetico and very happy, have had for over 15 yrs without any problems and extremely low on salt consumption .
I had a Culligan rental before, nothing but problems and when I complained Culligan told me that they never rent the latest technology only past tech & refurbished.
What a great company!
I'm not going to hate on our Culligan dealer here - they've been pretty good to us and our old well WAS a terrible source of water. It was relatively shallow with water starting at ~40' with the pump set at ~70'. This after we replaced the old school leather cup and rod set up - not sure the depth it was drawing water from. The water coming out of there was VERY high in manganese, iron and I think, calcium. Also had a sulfur smell at times too. We used to have a product that they called a Col(d?)-Sorb that was installed before a smaller softener unit ( less rent) that they changed out every month but it was disco'ed so we had to upgrade unit capacity. To give you an idea, if the softener messed up and we had to bypass it (or we ran outdoor water), it would often come out with a light orange tint. It was like that since my wiff and her (ex) husband bought the place in '91. She had said that for the first few months or year, they didn't have white clothing, it was orange. And man, when piping was disturbed for changes or upgrades... Whew! Nastiness!
At any rate, now that we have (IMO) really good water, we don't need all that capacity/capability and I really don't want that monthly bill. I feel that buying a much less capable unit is the answer and it will only take a year or so before it's paid for itself.
Hello The_Eric,
I installed a new water softener about 2 years ago. I spent about a month getting up to speed about the diy process. The Terry Love plumbing forum is a good place to start.
- It's best to start out with a complete water test, not just a hardness test from a sales person. This will confirm if there are other challenges beyond the hardness minerals. A media filter will not remove hardness ions.
- It's my opinion that the better units have separate brine and softener tanks vs. the cabinet models. Who wants the valve and controls sitting in the salt fumes.
- The better units use one of three valve options: Fleck, Clack, or Autotrol. These are the standard of the industry and U.S. made with parts/service available. Culligan, Kinetico, and others have proprietary systems and you are at the mercy of those companies for repairs. A good softener doesn't necessarily have a recognizable brand name. It is a unit made up of one of the mentioned valves, a good tank/components, and good resin (the simple parts of any softener).
- It is very important to evaluate your home and water use needs to select the most efficient softener size. It's similar to the importance of sizing your furnace and air conditioning.
IF your water contains zero iron and is only 8 grains hardness, you "should" be able to regenerate with only 6 lbs. salt per cu. ft. and maybe up to a month or so between regenerations. The newest softeners have computer controls. You program it to your water quality and amount used. It monitors amount of water used and regenerates based on your programming, not on calendar days. Extremely efficient, both salt and water usage.
Here's a just a few links to get you started, IF you are interested in a quality installation (high quality components properly sized):
https://www.aquatell.ca/pages/learn
https://www.aquatell.ca/pages/ultimate-water-softener-guide
https://blog.uswatersystems.com/2013/11/which-water-softener-is-the-best-clack-autotrol-or-fleck/ This site is hawking their Chinese made valve.
https://www.apswater.com/Water_Soft...nshard=30&iron=1.56&perperson=65
https://www.apswater.com/softener-info.asp?widthin=10&heightin=42&hard=30
FYI the Do It Myself named member at Terry Love is not me.
"IF" you use a whole house Carbon filter, it must be installed downstream of the softener. Any calcium in the water will quickly fill the micropores of the carbon and render the filter useless in short order.
The 5600 softener timer is just that, a timer. It does not sense your water use. However, it's pretty easy to know when you've gone too long between regen-cycles. As the water gets hard. My setup cycles every 2 weeks. Salt use is minimal. For most people, there is no need for constant regen-cycles "just to be sure".
Also, if you find yourself with hard water, simply go over to the softener and manually start a regen cycle. I've had to do this exactly twice in 20 years.
The spun poly filter can be thought of as a very fine screen for particulates. It cannot filter out any dissolved calcium (lime) . Calcium will pass right through, unaffected. The softener's only real job is to remove calcium, and it does this effectively. As I mentioned above, it does this through a process of ion exchange. A softener is not a filter, and there is no filter that can do what a softener does.
What is the carbon filter going to remove?
VOC's (pesticides/herbicides, benzene, among many others), chlorine, weird odors and taste... we just use the fridge filter. ~$80 a year in filters and a nice reminder built into the fridge!
Do you have any idea how long they typically last? I understand that it will vary with water use... Do they suffer from aging too (low use vs time)?
Softener beads expand and contract with use. The cycles are what break down the beads. Along with iron when not sufficiently regenerated. Of course chlorine is also hard on beads. Generally 15 years of use is a good rule of thumb. It's not all that hard to replace the beads. The bigger the softener (for a given application) and the fewer the cycles, the longer the beads will last. I don't believe the years degrade the beads.
Beads are rated by "crosslink" and 10% crosslink beads simply last longer (generally twice as long) . In a proper setup, they will last 20 years.
