Originally Posted by billt460
My only concern with a lot of these cleaning additives you add to the fuel, (especially some of the older ones like MMO, Berryman's, Sea Foam, and Rislone), is how do you know if they won't screw up your catalytic converter? I know they say they are, "Safe for catalytic converters". But how do you really know for certain? Is there a certain chemical or additive they contain that you should look for, and stay away from?
I've heard everywhere that both Gumout Multi System Tune-Up, as well as Techron are cat safe. But some of the others that have been around since before electricity, I'm not so sure about.
I suppose it's possible in extreme cases of additive overuse but I've personally never heard of additives destroying a Cat or 02 sensor (plug fouling, yes). My guess is that you'd have an 02 sensor code before your Cat got damaged. I'd imagine anything you pour into the tank is annihilated during combustion, leaving behind maybe some plug fouling and what's left exits the chamber in the form of gasses like CO, CO2, NOx... which the catalytic converter is designed to convert to less harmful emissions before escaping into the atmo.
The mfgs (and to some extent the public) of these products know the ingredients; I don't suppose it would be hard to employ a little chemistry to determine if harmful (to the Cat) by-products are produced as a result of combustion. Add to that, decades of empirical evidence suggests that these products are "cat safe" when used as directed. Deviate from the directions at your own peril....
