My 2011 Sonata SE 2.0T
by strongt - 07/05/20 05:39 PM
Throwing in the towel on local clothing retailers
by Reddy45 - 07/05/20 05:09 PM
Castrol Edge vs Edge EP
by Gene K - 07/05/20 05:03 PM
Car related YouTube channels
by dishdude - 07/05/20 04:59 PM
Suspension Bushings Oil Resistant?
by TacoFergie - 07/05/20 03:43 PM
Building a solar generator
by BeerCan - 07/05/20 03:22 PM
Used CVT fluid in a power steering application
by mahanddeem - 07/05/20 02:06 PM
New Mobil1 EP HM, API SP label design.
by wemay - 07/05/20 02:00 PM
Generator oil
by Eddie - 07/05/20 01:51 PM
This never ceases to amazing me
by SLO_Town - 07/05/20 01:46 PM
Empty shelves and lack of variety.
by sloinker - 07/05/20 01:17 PM
Mann HU816 (28 month service)
by Barwich - 07/05/20 12:23 PM
Napa Gold 1348 and Mahle OC148 C&P
by BeerCan - 07/05/20 10:38 AM
Dead rechargeable batteries on cordless drill
by 97tbird - 07/05/20 10:35 AM
2018 Silverado 6.0 Idle Stumble
by Phishin - 07/05/20 10:20 AM
U.S. Gasoline Production
by Snagglefoot - 07/05/20 07:39 AM
Trying to save an otherwise junkyard bound car
by agarb - 07/05/20 07:08 AM
TacoFergie, electro, SilentC, paolo9fla, SunnyB
71850 Registered Users
103 registered members (55hambone, AndyB, 2010Civic, 2002 Maxima SE, 4WD, 92saturnsl2, 12 invisible), 1,985 guests, and 19 spiders.
Topics307,456
Posts5,311,475
Members71,850
Page 1 of 5 1 2 5
Hot or Cold oil change? #5262272 11/09/19 05:23 AM
SR5 Offline OP
I was always told to do an oil change when the oil was hot or warm, I think the logic was that more contaminants were in solution and the oil drained out faster.
But now I think on that logic, if the oil needs heat to keep contaminants in solution then I should have changed the oil long ago and I already have an engine full of sludge and varnish.
With modern thin synthetic oils used over reasonable intervals, does it make any difference if you change the oil hot or cold ?
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Hot or Cold oil change? [Re: SR5] #5262274 11/09/19 05:34 AM
PimTac Offline
I’ve always done it hot but you add a interesting point. I started back in the days of SAE30 grade. The oil drained easier and better when hot. Now with 0w20, maybe it doesn’t matter that much?
On the other hand, draining it hot also means stuff is suspended better so you might be getting more stuff out that would otherwise build up inside.
I’m still on my first cup of coffee here at 0230 so my brain is not yet activated.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Hot or Cold oil change? [Re: SR5] #5262275 11/09/19 05:35 AM
demarpaint Offline
Warm or hot oil indicates to me the contaminants are in suspension, and warm oil drains quicker and easier in cold weather. That's how I was taught well over 40 years ago and I stayed with it.
God Bless Our Troops
Re: Hot or Cold oil change? [Re: SR5] #5262278 11/09/19 05:55 AM
F
FordCapriDriver Online Content
Online Content
F
I've always done them cold because i don't fancy getting my arm or hand burnt touching a hot exhaust or oil.
And as we know, on BITOG the ultimate performance spec is : "It hasn't blown up yet"
And certainly i have never had an engine blow up yet from doing oil changes cold lol
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: Hot or Cold oil change? [Re: PimTac] #5262280 11/09/19 05:57 AM
Duffyjr Offline
I have to ask where do the contaminants go when the oil is cold? As the engine cools and the oil drains back to the pan do the contaminants get left behind. Just trying to wrap my head around this because I don't change my oil any longer so when I take it to the quick lube the oil is warm but when I leave it with my mech it's usually the night before so I know he's not letting it warm up so if this is an issue I might consider going back to the quick lube.
89 GMC Sierra Advanced 5w30/TG
08 Lucerne CX Advanced 5w30/TG
18 Toro Super Recycler T5 10w30
Re: Hot or Cold oil change? [Re: Duffyjr] #5262282 11/09/19 06:06 AM
PimTac Offline
Mind you, I’m a bit old school so this might not apply as much as it did 45 years ago with thicker oil. It was the thinking then that stuff settled in the pan. In that era engines ran dirty and sludge was a battle.
This is a interesting point that SR5 is trying to bring up. I do the change hot because of beliefs that are decades old. Maybe they don’t apply anymore? In either case I still drain the oil hot as I’ve done for decades. Old habit I guess.
2017 Mazda CX5
Roki OEM filter.
Re: Hot or Cold oil change? [Re: SR5] #5262288 11/09/19 06:21 AM
demarpaint Offline
Modern synthetics still drain a lot slower from a stone cold engine, especially during the winter. I would imagine there is also some slight condensation in a cold engine, that would otherwise be burnt off had the engine been driven long enough prior to changing the oil. Which brings up more questions. If you're going to run the engine prior to changing the oil should it be run long enough to burn off excess fuel and moisture? Or change it cold?
Truth be told I'm sure there are millions of DIY'ers who change their oil cold and drive 100's of thousands of miles doing so.
Re: Hot or Cold oil change? [Re: SR5] #5262291 11/09/19 06:41 AM
dlundblad Offline
I do whatever is convenient. Also, if the filter gets unreasonably hot due to its location from say the exhaust, I’d just dump everything cold.
Contaminants should be kept in suspension even on a cold engine (assuming its DD’d and hasn’t been sitting), but getting everything stirred up certainly won’t hurt and it’ll make everything flow out faster since it’ll be hot.
On a side note, various manuals for all sorts of auto fluids say to run before dumping, which IMO is important on stuff without filters like diffs and PS systems and arguably less on engines with filters.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Hot or Cold oil change? [Re: SR5] #5262294 11/09/19 06:44 AM
B
bbhero Offline
B
I have done it both ways... Scalding hot and stone cold...
Like demarpaint said in the winter a bit of heat is very very helpful... When I changed the oil in my Altima several years ago it was like 14°F or -10°C with a wind chill below 0°F... I am glad I warmed the car up for several minutes prior to starting that fun experience.
Nissan Altima 3.5 Coupe
Royal Purple 10w30 Carquest red 84356
"Treat your family like your friends and treat your friends like your family."
Re: Hot or Cold oil change? [Re: SR5] #5262296 11/09/19 06:46 AM
B
bbhero Offline
B
Ohh and by the way... Very good to see you on here. I hope that you and your family have been doing good.
Re: Hot or Cold oil change? [Re: SR5] #5262297 11/09/19 06:48 AM
B
billt460 Offline
B
Originally Posted by SR5
I was always told to do an oil change when the oil was hot or warm, I think the logic was that more contaminants were in solution and the oil drained out faster. But now I think on that logic, if the oil needs heat to keep contaminants in solution then I should have changed the oil long ago and I already have an engine full of sludge and varnish. With modern thin synthetic oils used over reasonable intervals, does it make any difference if you change the oil hot or cold ?
You could argue it shouldn't.... But why? If you have particulate matter in a liquid, mixing that liquid right before you drain it from whatever container is going to leave less of it at the bottom. Add to that being hot makes ANY motor oil, regardless of it's viscosity, drain faster and more completely. Especially off of hot engine parts, of which there are many. Which helps contribute to all of this in a positive manner.
You have 2 choices when changing oil. Do it hot or cold. I can't see any possible advantage to doing it cold, other than you won't possibly burn your hands. And most everyone who takes their vehicle in for an oil change, has it done hot. As do most people who do their own. So what percentage does that leave of cars that have cold oil changes performed? It has to be an all but insignificant number.
You might say this is one case where, "running with the sheep" won't get you slaughtered.
Re: Hot or Cold oil change? [Re: PimTac] #5262298 11/09/19 06:51 AM
Duffyjr Offline
Thanks and nothing wrong with old school if it works. So the contaminants settle to the bottom of the pan and don't drain out when cold so it can build up and then mix back in the fresh oil, I can see this being an issue down the road.
Re: Hot or Cold oil change? [Re: SR5] #5262300 11/09/19 06:54 AM
R
Railrust Offline
R
I've always been told to do it when hot because the contaminants are held in suspension when the oil is hot, otherwise they settle on the bottom of the pan and the oil will flow right over it as it drains...leaving them in there. Don't know how much I agree with that, so I usually just do it when it's warm...I'm not into burning myself and having hot oil splash all over me.
2018 Chevy Silverado 5.3 (sold, with 52,000 stumbling and bumbling miles)
2007 Lexus LS460 (deceased)
2008 Honda CRV
2016 Toyota Avalon XLE
(Whatever synthetic oil is on sale or rebate)
Re: Hot or Cold oil change? [Re: billt460] #5262303 11/09/19 06:57 AM
demarpaint Offline
I agree. I'm going to stick with the way I was taught. Drive the vehicle, let it cool while I gather my tools and change the oil warm to hot. I have a nice pair of oil proof rubber gloves that protect me against burns if needed.
Re: Hot or Cold oil change? [Re: SR5] #5262304 11/09/19 07:02 AM
K
KingShalamar Offline
K
I don't think being hot makes any difference since the oil does not freeze when cold. Or is there something am missing?
Page 1 of 5 1 2 5
