Originally Posted by kschachn
What kind of problems could it cause?
Soften/dissolve the friction clutches?
If that is a fear you have then I'd say don't use dexron VI since any subsequent failure would be automatically attributed to the fluid, regardless of actual cause.
But if that was an actual technical concern then dexron VI would not have been back-specified. Any fluid that would dissolve the clutch material would be quite the failure.
While that's a good point, Dexron is made for GM cars primarily. I doubt they would test it on other car makes that used the fluid to make sure it was backwards compatible with them too.
