Originally Posted by NoNameJoe
Originally Posted by toad
Just finished flushing the brake fluid on our 2013 Civic LX. The master cylinder cap has a lot of wiggle to it after tightening it as much as possible (unless I am missing some trick involved in it's tightening). Is this normal? I find it hard to believe that this could be normal !
It's hard to answer your question because "a lot" and "wiggle" are highly subjective terms.
Some small amount of rotational movement is normal. Maybe 5mm in each direction. I know because I've had a lot of Civics (2009, 2011, 2015 to name a few), all of them use the same master cylinder (or very close). The important thing is the cap does not wiggle vertically, if you can lift the cap up that's abnormal. Once you tighten it fully it is normal for the cap to have some rotational play though before it hits the stop that prevents it from tightening any more or the stop that starts loosening it.
If it's anything more than that check the cap carefully, there's a track the lips on the cap are supposed to ride, eventually the track forms an angle to force the cap to tighten downward.
The movement is vertical but small, perhaps 1.5 mm. I was able to see the track the lips ride on and the cap was right up against the hard stop.
