hand sanitizer
by matrass - 04/09/20 08:57 AM
Sludge concerns
by otis24 - 04/09/20 08:43 AM
Anyone Ever Have Their OEM rims Powder Coated?
by LoneRanger - 04/09/20 07:59 AM
Group 7 V2222
by GumbyJarvis - 04/09/20 03:56 AM
I'm looking for a 0w30 A5 B5 oil
by Marco620 - 04/08/20 11:57 PM
Does anyone put heat shrink tubing over a connector plug?
by motor_oil_madman - 04/08/20 10:39 PM
Anyone ‘excited’ for API SP/GF-6?
by addyguy - 04/08/20 10:30 PM
O'Reilly online learning for .gov email addresses
by spackard - 04/08/20 10:26 PM
Welding Helmet Fogging Up
by George7941 - 04/08/20 09:54 PM
Detroit 4-53T 2009 Ford F350 Update.:)
by A310 - 04/08/20 09:48 PM
Thoughts on CAFE standards
by otis24 - 04/08/20 09:20 PM
PUP amazon 5w-20
by Koncrete_Cam - 04/08/20 08:54 PM
Duralube Trans Shudder Fixx question
by soulburner - 04/08/20 08:36 PM
Number of Spare Magazines You Consider Adequate?
by 2015_PSD - 04/08/20 08:24 PM
Troy Bilt TB6044XP string trimmer dies when hot
by 92saturnsl2 - 04/08/20 07:18 PM
JD Yanmar deisel engine
by yankees1 - 04/08/20 07:14 PM
PQIA Looks at Leading 0W-20's
by Jackson_Slugger - 04/08/20 07:03 PM
Marine oil in a passenger car engine
by Thunderbolt - 04/08/20 06:50 PM
edot1, Tori, siroisma, i4ni, Monica
71133 Registered Users
107 registered members (53' Stude, 77GrandPrix, Alfred_B, 1978elcamino, 007, aquariuscsm, 7 invisible), 1,951 guests, and 20 spiders.
Topics303,812
Posts5,242,332
Members71,133
Page 1 of 5 1 2 5
At a Crossroad with My F-150; sell or keep? #5253142 10/29/19 02:20 PM
P
panthermike Offline OP
P
Regarding my 2010 F-150 with the 5.4; having a hard time deciding if i should keep it or trade it in.
Some may have seen my thread about the longblock being replaced at 103K(now 106K). It was in the shop for 52 days for that one. So why am I asking this question in the first place?
The good:
-Reman longblock (not Ford but builder claims they use AER)
- Truck looks great and I love the interior
The Bad: I feel like I am constantly chasing a couple of issues with it
1. Miss at idle and under load, also seems to miss under heavy acceleration
2. Light knocking sound from a deadstop (goes away after about 15mph)
3. Bad vibration in OD around 1-1.4K RPM
4. Lots of little stupid things; right blinker doesn't turn off on its own, blend door occasionally makes some noise. These are pretty small and tolerable/easily fixable.
Regarding the misfire; i changed the plugs and boots before the motor replacement to no avail. Multiple fuel cleaners just in case. Also was hoping this may fix the vibration in overdrive (#3) which can apparently be caused by misfire. Now I have read the coil may be the issue. So if I keep the truck, I would replace the plugs as well the boots w/ coil springs and clean the contacts. This is the recommendation on a Ford forum. If that failed, then off to a mechanic to see if a misfire is read. The truck has never had a CEL or any stored codes.
Regarding #2, this is something that I never noticed prior to longblock replacement. I've read about Slip-yokes being an issue with this gen F-150 but I don't anything to compare to. Apparently Ford's answer to this, assuming that's the issue; is to grease it. The greasing is a temporary fix and must be redone according to most accounts.
So there's my crossroad with this truck; I can get about what I owe on trade. Of course I would be adding some debt by getting something a little newer/lower mileage, which is not desireable.
Or I could keep it for now. Replace plugs/boots/springs and go from there(replace coil(s) if needed). Also would hope this would fix issue #3, which is pretty severe at times. As far as the possible slip-yoke or whatever is causing #2, maybe get it checked out and hope a mechanic can replicate it.
Any advice from fellow bitogers on what they would do? I need a vehicle that I can payoff quickly AND not be a constant problem child. Not looking for bashing or anything, just honest opinions about the truck/situation.
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253158 10/29/19 02:31 PM
diyjake Offline
If you are planning to replace it in the near future, might as well do it now instead of sticking more money into it or fix the issues and driver it for another 100k+ miles
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253159 10/29/19 02:32 PM
demarpaint Offline
I'd get rid of it. W/O actually seeing/driving it, It sounds like it has all the makings of a money pit.
God Bless Our Troops
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253162 10/29/19 02:34 PM
A
AITG Offline
A
Paid for is worth a lot. Fixing everything may only be the cost of two or three payments on something different. Nothing that's bothering you is all that expensive compared to a new trans or a set of tires. JMHO.
OTOH, it's your money, you get to pick how you spend it.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253166 10/29/19 02:35 PM
CKN Offline
That's an issue when you put a new motor in-but the rest of the truck has issues.
Mis at idle-is something that could be any number of things-and you could spend a long time chasing it. Mis fires without codes is a real PITA. Could be a ground issue-somewhere........
It sounds like it's giving you a headache. If you can afford to replace it-that's what I would do. You can't have it both ways however- a newer truck puts you in debt-the old one gives you anxiety-you choose.
You could probably get a decent truck with less miles for the mid-20's if you are looking to buy used.
Re: At a Crossroad with My F-150; sell or keep? [Re: AITG] #5253170 10/29/19 02:39 PM
Donald Online Content
Online Content
Its not paid for "I can get about what I owe on trade."
I would fix the issues. You will need to fix the anyway to get a decent sale price.
Why did the block need replacing?
2015 Ford F-250 w/Powerstroke
Re: At a Crossroad with My F-150; sell or keep? [Re: demarpaint] #5253173 10/29/19 02:40 PM
Mr Nice Offline
Yep, sell it and find something more reliable.
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253174 10/29/19 02:40 PM
J
JeffKeryk Offline
J
Wow, you are in a tight spot.
I like keeping them alive.
New trucks, for me, are too nice to use as trucks.
I loan my old Tundra out all the time; it is on loan right now.
Not sure I could do this on a new one...
On another note, you can do real well on a 2019 right now.
An F150, SuperCrew 4WD with the 2.7 or 3.5 EcoBoost sounds real good to me.
I hear that 10 speed is real sweet.
Is it in the budget?
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: At a Crossroad with My F-150; sell or keep? [Re: Donald] #5253197 10/29/19 03:04 PM
CKN Offline
He is talking about trading it in- a dealer may very well payoff the truck to sell him something different even with the issues. Of course-this is uncertain until he tries to make something happen.
I traded in a truck with the very same issues-mis - fires. It had less than 40,000 miles on it. NO ONE COULD FIX IT. It was so clean the dealer gave me high book for it. I have no idea if they fixed it or not. The only thing I do know is that sold it the first weekend after I traded it in.
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253229 10/29/19 03:40 PM
supton Online Content
Online Content
That's the problem with big high dollar repairs--it's often followed by a slew of others. Everything's a gamble...
If you want it to be something that isn't going to nickle and dime you, then I'd vote with moving on. I'd also look at if you truly need a truck or if something smaller (and cheaper) would do the trick. If you do need a truck, well, you're stuck, good trucks cost money--and when they get older, just like everything, they need work. At that point, do you buy something older with a new set of problems but is at least paid off? or go newer and take on the loan? Hard call.
2011 Toyota Camry, base, 2.5L/6MT, 203k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 158k, ours
1999 Toyota Camry LE, 2.2L/4AT, 223k, his
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253231 10/29/19 03:43 PM
W
wdn Offline
W
Did you have to change the coil on plugs, or the injectors yet? You want to talk about a money pit. And just 100,000 miles on it.
Re: At a Crossroad with My F-150; sell or keep? [Re: diyjake] #5253240 10/29/19 03:49 PM
L
Leo99 Offline
L
Agreed. It's a bad penny.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 392,000 miles
2015 Camry 90,000 miles
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253270 10/29/19 04:10 PM
K
krismoriah72 Offline
K
Someone down the road is going to fix whats wrong.. either a small lot, or the dealer that you sell it to.
Financially its more sound to keep what you have. "What i owe" is that including the cost of the long block? if not then you will be out the cost of that on the trade.
My vote would be to find a shop to give you an estimate.. then go from there.
You probably wont fix it on a forum.. its gonna need good diagnostics.
Re: At a Crossroad with My F-150; sell or keep? [Re: krismoriah72] #5253358 10/29/19 05:45 PM
CKN Offline
I believe there are issues (very rare) that are so intermittent, unpredictable, etc., that trying to get them diagnosed is a futile effort. This is speaking from personal experience-after taking a vehicle to three different guys who" if they can't fix it nobody can" types.
Re: At a Crossroad with My F-150; sell or keep? [Re: panthermike] #5253366 10/29/19 05:54 PM
T
Tman220 Offline
T
Dang, I was going to come in here and tell you to dump that 5.4 (3 valve bomb) before it turned into the turd they can be, except it has already been successful in screwing another person over.
With that being said, even with the reman engine, I would still dump that truck with the nickle and dime stuff you already mentioned and recurring spark plug, injector, coil issues that can make the most loyal 5.4 owner buy a chevy.
I know the 5.4 has treated millions of people perfect, but its still a stupid engine! All the years Ford produced the modular engine, they had coil issues, spark plug issues, timing chain tensioner, valve timing actuator, oil pump problems from practically day one, to the day they died which ford refused to fix!! In the case of the spark plug issue Ford failed to fix the issue and arguably made it worse! I know they all have their problems but these common problems just happen to be extremely expensive for the average person that needs to bring their vehicle in to get fixed.
Anyway, that is my rant, do what makes sense to your wallet.
2012 Regal GS Turbo PP 5w30 90k
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30 165k
2005 GMC Sierra 1500 5.3 170k
2004 Civic LX M5 190k
2007 Camry 2.4 250k
2016 Victory Vegas
Page 1 of 5 1 2 5
