GENERAL Q regarding SPX snow plow
by Kira - 11/16/19 03:13 PM
78 C10 at show
by WiskyBadger - 11/16/19 03:00 PM
300blk ammo?
by buck91 - 11/16/19 02:52 PM
The Rock is still alive!
by Char Baby - 11/16/19 02:48 PM
Weird fuel leak
by BeerCan - 11/16/19 01:02 PM
Sinopec 75w-90 Synthetic
by jdw1222 - 11/16/19 12:51 PM
Honda Oil Filter
by miden851 - 11/16/19 12:28 PM
VOA for QSAD 10w-40?
by natas - 11/16/19 12:02 PM
Ford v Ferrari - anyone seen the movie yet?
by Oro_O - 11/16/19 12:01 PM
who made this??
by ted s - 11/16/19 11:41 AM
Drill Bits
by MasterSolenoid - 11/16/19 11:32 AM
2000 Honda Insight Crunchy 1st & 2nd
by Rmay635703 - 11/16/19 09:32 AM
Update Site to VerticalScope Inc board?
by CB900F2 - 11/16/19 09:27 AM
Replace brake clips with each pad change
by Donald - 11/16/19 08:26 AM
HDEO in motorcycles
by kebabaluba - 11/16/19 08:14 AM
More on Cord Cutting - costs going up
by Donald - 11/16/19 07:24 AM
Bosch 3423 C&P
by FordBroncoVWJeta - 11/16/19 05:50 AM
Monroe wouldn’t patch a trailer tire
by dlundblad - 11/16/19 05:06 AM
Ruger Wrangler .22LR
by ZeeOSix - 11/16/19 03:09 AM
aka_Claus, Diverdown, natas, matt3540, ChrisWild
69885 Registered Users
91 registered members (2oldtommy, 928, 10ecfarmer, 77GrandPrix, 14Accent, 92saturnsl2, 7 invisible), 2,582 guests, and 20 spiders.
Topics297,509
Posts5,117,052
Members69,885
Most Online3,589
Nov 2nd, 2019
03 Tiburon delayed crank #5248341 10/23/19 06:36 PM
H
HyundaiAbuser Offline OP
H
My 2003 Hyundai Tiburon, when the key is turned, delays an inconsistent amount between turning the key and the engine cranking. Once cranking the car starts right up and runs great. I don't really know a whole lot about it, what do you guys think it could be?
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Supertech 5w30 Full Synthetic
Valvoline Dex/Merc
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5248360 10/23/19 06:55 PM
W
Warstud Online Content
Online Content
W
Sounds like a bad Battery. The longer it sits the longer it's gonna crank.
Re: 03 Tiburon delayed crank [Re: Warstud] #5248380 10/23/19 07:14 PM
H
H
It doesn't crank for a good bit until It does and the crank itself seems normal. Once it starts cranking it fires up just fine there is just a delay between turning the key and the starter cranking the engine.
However battery does affect everything so I will check it.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5248411 10/23/19 07:56 PM
P
perfect_oil Offline
P
It could be high resistance in the starter circuit. Loose connections or corrosion at the connections.
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5248556 10/23/19 11:55 PM
B
boom10ful Offline
B
V6? I would check the crankshaft position sensor as it's well known for the wiring insulation on it to get cooked from the exhaust manifold and cause a short/fault...
Re: 03 Tiburon delayed crank [Re: boom10ful] #5248562 10/24/19 12:35 AM
dogememe Offline
I'm not positive but I think the OP is saying that the vehicle doesn't crank right away, not that it has a long crank time?
2010 Ford Escape 2.5 ~101K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~283K Miles: Unknown Oil, Filter.
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5248681 10/24/19 06:34 AM
SVTCobra Offline
My guess is either corrosion as already mentioned or a starter relay not operating correctly. An old diesel pickup I have does the same thing, turn the key and sometimes starts right away and other times there is a definite delay. Everytime it starts with a delay I hear a click from the starter relay right before it fires up.
Think twice, speak once.
Re: 03 Tiburon delayed crank [Re: dogememe] #5248818 10/24/19 09:21 AM
H
H
That is correct. I'm kind of leaning toward clutch safety switch. When I somewhat violently pump the clutch I can get it to start, although that's not a cement observation.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5248865 10/24/19 10:27 AM
M
mk378 Offline
M
Turn the lights on and watch to see if the whole car loses power (and then recovers) when you try to start. If it does it's probably a loose connection at a battery terminal or the main ground wire.
Re: 03 Tiburon delayed crank [Re: mk378] #5248904 10/24/19 11:14 AM
H
H
I have checks the battery terminals and they are all clean and solid. I’ll be sure to do that at the next opportunity.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 03 Tiburon delayed crank [Re: SVTCobra] #5248934 10/24/19 11:54 AM
H
H
It appears as though the delay is less immediately after driving. Aka a shut off then in a minute or so turning back on.
That is interesting i will have to look at that. When i turn it i hear a click in the passenger side of the car which i assume is from the ecu and nothing else. I do not think that I have actually heard the relay in the fuse box. I think I replaced in awhile back but I'm not sure.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5249504 10/25/19 05:23 AM
SVTCobra Offline
On my pickup the relay I'm referring to is the starter relay mounted on the passenger fender. It's just a 4 connection relay that allows high current to flow from the battery to the starter. When it clicks it's the electromagnet energizing and the contacts closing. The delay in some starts is the electromagnet not working correctly for whatever reason.
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5250277 10/25/19 11:34 PM
A
AdRock Offline
A
Try bypassing the clutch safety switch and see if it cranks right away. A buddy had this happen on his '04 Tib and I fixed it with a new clutch safety switch.
2018 Ford F150 STX Crew Cab 5.0
2002 Ford Mustang GT 4.6
2016 Ford Escape 2.4
Pennzoil Platinum 5w30 in all 3
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5250436 10/26/19 08:24 AM
H
H
I found a new one for 10 bucks so I just decided to order it anyway. It’s supposed to come in today so I’ll let you guys know what happens.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
Re: 03 Tiburon delayed crank [Re: HyundaiAbuser] #5251645 10/27/19 07:12 PM
H
H
Eureka. Clutch safety switch swap worked perfectly.
03 Hyundai Tiburon:
Castrol Edge 0w40
Redline MT90
94 Mazda B4000
Valvoline Dex/Merc
