Fram Extra Guard now rated to 10k miles
by addyguy - 11/20/19 08:47 PM
HF Mechanic's Cart Coupon
by TheLawnRanger - 11/20/19 08:45 PM
Factory Fill 2019 VW Jetta 1.4t
by DuckRyder - 11/20/19 08:12 PM
Castrol Edge Professional LL IV FE 0W/20 (VW508)
by DuckRyder - 11/20/19 08:08 PM
2019 Kia Sedona - Oil Filter Housing
by XpressAuto - 11/20/19 07:46 PM
Belt/ Tensioner wear
by bruckus - 11/20/19 07:42 PM
Eneos CVT fluid
by bbhero - 11/20/19 07:38 PM
Game changer?
by P10crew - 11/20/19 07:34 PM
Permatex Brake Lubricant
by Snagglefoot - 11/20/19 07:01 PM
2015 BMW 328i Pennzoil Platinum 5w40 Euro
by TurboJW - 11/20/19 06:55 PM
STP S2808 (Blue) now also a H/K clone
by wemay - 11/20/19 06:30 PM
New to shortwave radio
by cwilliamsws6 - 11/20/19 06:22 PM
Ford Tempo
by Eric Smith - 11/20/19 05:40 PM
quick FL-910s C&P
by BeerCan - 11/20/19 04:50 PM
Adding keyless entry to an older car
by atikovi - 11/20/19 04:36 PM
blind spot monitoring sensor 2017 jetta
by raaizin - 11/20/19 04:33 PM
Subaru Forester rear brakes
by Donald - 11/20/19 04:19 PM
Cummins ISX15 OCI
by The Critic - 11/20/19 04:07 PM
It's A Radial Robert
by Yah-Tah-Hey - 11/20/19 04:02 PM
ImBoosted, XpressAuto, Jmpage388, baileyclarke, Jbloggs
69924 Registered Users
119 registered members (4WD, 379KITTY, 2015_PSD, 007, 8 invisible), 1,893 guests, and 22 spiders.
Topics297,698
Posts5,120,890
Members69,924
Most Online3,589
Nov 2nd, 2019
Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles #5243865 10/19/19 04:42 AM
J
john_pifer Offline OP
J
For quite a while now - can't say exactly how long, I've been hearing a "hum", similar to the hum I've heard coming from the tires of trucks with aftermarket, off-road tires, but not nearly as loud. It starts coming on at around 40 mph. As I said, not too loud, but, I've owned this truck since I bought it new in 2007, so I know the noises my truck makes.
It's not the tires - I'm running highway-biased Michelin LTX M/S tires that are very quiet. And they're fairly new - only about 20,000 miles on them.
I suspect the front wheel bearings (I replaced both rear wheel bearings several months ago due to one of them wearing out, and being alerted to the failure by the axle seal on that side failing and allowing diff oil into the bearing housing where the wheel speed sensor is, and causing it to fail, illuminating the ABS/BRAKE warning lamps).
Well, yesterday, while rotating the tires, I checked the bearings for play (grabbed wheel at 12:00 & 6:00 and tried to rock it) and I could not detect any play whatsoever.
Couldn't really tell if there was noise or roughness by rotating the wheel, or the hub, once the wheels were off, because of the brakes scrubbing a bit.
Anyway, it's time for a front brake job, and I was trying to decide whether to replace the front wheel bearings, or just let them ride for a bit longer.
The truck is my daily driver. 222,500 miles. I drive it around town - not many out of town trips - usually we take the GF's 2018 Civic for road trips. Still, it's how I get to work.
I don't have any experience with symptoms of wheel bearing failure, as this is the first vehicle I've had with this many miles.
So, can the front wheel bearings have enough wear to warrant replacement even if they don't have noticeable play?
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 222K
18 Civic HB 1.5T 6MT (Fiance's) - Castrol Edge 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5243878 10/19/19 05:14 AM
B
BretK Offline
B
If you turn, as in going around a curve in the road, does the sound change or get louder?
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5243934 10/19/19 06:54 AM
spasm3 Offline
If you turn the wheel back and forth at speed does the sound change, increase decrease? They can have noise before you can detect play.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 16400 miles m1 0w40
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244065 10/19/19 09:24 AM
J
J
I need to go out and drive it and see if it makes more noise when I go around a turn, go around corners at speed, turning wheel back and forth at speed, etc.
There’s a hilly neighborhood with some curvy roads not far from here that will be perfect.
I’ll report back.
I’d like to get my stuff ordered today. Need pads, and trying to decide whether to take the rotors off and take them to a shop to be machined, or just buy new rotors. I know I don’t want cheap [censored] Chinese rotors. Bought some from Auto Zone once, and they warped very quickly. Ended up just getting my stock rotors turned, and that’s what is on the truck now.
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244139 10/19/19 11:17 AM
M
mattd Online Content
Online Content
M
Your best bet is to jack it up and spin the wheels by hand and listen for grumble and feel for roughness
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244146 10/19/19 11:23 AM
SatinSilver Offline
I recently had a front wheel bearing replaced on the 05 Matrix. It was the right front bearing. The shop took it for a test drive then put in on a lift. Had a guy in the car who put it in drive and accelerated. The right front was wobbling pretty good. The other side was much less. Funny the same shop replaced that bearing two years ago while the others are still original. Had the right front replaced using an SKF bearing this time.
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: mattd] #5244148 10/19/19 11:26 AM
javacontour Offline
Yep,
I just did this for my MIL. Rear wheels in her 2015-ish Altima. We waited until she changed tires as they were too worn for impending winter. Sound remained so she left the car with me this weekend while she and oilBabe went to Pittsburgh. Driving it, it sounds like it's from the drivers side. But off the ground, the grumbly bearing is on the passenger side.
Sound is telegraphed in a car, so the best way to figure it out is get it in the air and spin the wheels.
As others indicated, There was no play. I pulled on the wheels like we would doing a tech inspection for AutoX and no noticeable play. But a quick spin of the elevated wheel revealed the noisy bearing.
network down, IP packets delivered via UPS -BOFH
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: mattd] #5244199 10/19/19 12:25 PM
J
J
Like I said in my original post, I did that and couldn’t detect any roughness.
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244206 10/19/19 12:38 PM
M
Online Content
M
Then maybe it is not a front wheel bearing. It should bet obvious if it is. I did replace several of them of that generation of Tacoma’s FWIW when I worked at my other job.
It could also be that it’s not bad enough yet for you to detect. You have to listen and feel very carefully. Put your ear right next to the hub while it spins
ASE Master, L1
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: mattd] #5244223 10/19/19 01:15 PM
J
J
Thanks for your input. I’ll just have to do it when I take the rotors off, then. If the bearing is making noise, I can’t hear it over the scrubbing of the brake pads against the rotors.
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244242 10/19/19 01:34 PM
02SE Offline
If the pads are scrubbing that hard against the rotors, I'd inspect for pad(s) or caliper piston(s) sticking.
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244248 10/19/19 01:41 PM
4WD Online Confused
Online Confused
Cheap things first - raise that wheel - grab W/E and shake - that checks linkage/bearing. Grab it N/S and shake - that checks bearing more.
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244472 10/19/19 06:54 PM
H
HangFire Offline
H
My Dakota 4WD driver's front wheel bearing had no play, nor ground when spun with brake removed, but howled while driven. Had me mystified until the tire shop alignment guy told me the replace the bearing. I had just done the other side ball joint and tie rod end to complete the alignment, so he wasn't surprised when I declined the service and did that, too. I used the new Timken hub from Rockauto, since Timken was an OEM supplier.
Man, with new Michelin's, 3 new suspension components and no howl, the Dakota feels like a new truck.
Various musings: http://hangfire.net
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244690 10/20/19 05:21 AM
M
ms21043 Offline
M
6 lug? Save yourself the aggravation of needing a special socket and tricky press work, buy the hub and bearing assembly instead of just the bearing.
5W30, whatever's on sale
Re: Sounds Like Front Wheel Bearing Noise - 2007 Tacoma (2WD), 222,500 miles [Re: john_pifer] #5244737 10/20/19 06:57 AM
M
MaximaGuy Offline
M
One of the things with bearings on an older vehicle is it is very difficult to diagnose - there are many rattling and worn components.
Wheel bearings especially of a truck does take enough beating to last a long time. 225K if they are original then it is a winner - I replaced the ones at 175K even though there was very faint noise coming from the wheels.
Tires too can be very tricky - especially Michellins they freaking suck big time (only idioots would buy a Michellin)
2018 MB GLE350
2011 Lexus ES350
2006 Toyota Highlander 4WD
