I am grateful for any help.
I have a 1988 Corolla FX that sat for 3 years, was running prior to that.
Carburetor, 4AC engine, automatic.
-Cranks. Will run for a few seconds with starter fluid.
-Added a few gallons of fresh gas.
-Fuel filter (in engine bay) looks full and the fuel looks ok from what I can see (the filter is semi-clear). I plan to replace it anyway.
-There is a mechanical fuel pump mounted to the engine block. I disconnected the hose going from the pump to the carb. I cranked and it looks like at least some fuel was coming out of the pump. It doesn't look like a lot, but I have no idea whether it should be a little trickle or more.
That's where I am with it right now. I was about to go buy a fuel pump, but am hesitating. Can a mechanical pump fail such that it pumps a little, but not enough to run the engine?
What would you check from here?
Thank you.
Thank you.
