Originally Posted by alarmguy
I find this a fascinating subject. We have a 13 year old home with a HUGE attic. Well insulated with blown in cellulose. However our two Hvac units are up in the attic and wow, it gets hot up there.
When the AC kicks on, your greeted with a hot blast of air.
I always wondered if what the OP did would significantly reduce the temperatures in the attic during summer.
Im assuming the attic is around 130 degrees on a 90+ degree day and its above 90 degrees everyday for 4 months.
Anyway, always wondered, not even sure if I would be able to do it, attic ceiling is high and a lot of blown in insulation would end up getting messed up because it would have to be pushed around to find the joists to walk on.
Maybe I could wrap the AC/Heat ducts with the stuff? Sounds nuts, but wonder if adding to the insulated reflective flex duct would help.
As far as the reflective stuff on the rafters, I know some areas I could more easy get too, like above the master br and if the stuff works, its would help in that area of the home.
My posts are based on directly stapling to the rafters with airspace between the roof, from the soffit to the ridge vent
Unfortunately HVAC in vented attic is standard in the SE US. Basically the equipment is "outside". In this case the best solution is to bring the HVAC equipment inside the housing envelope. This means you move the insulation from the attic floor to the roof deck and create an unvented roof. The best way to do that is to sandwich a layer of rigid foam between the rook deck and the exterior roofing material (Asphalt Shingles, Metal, tile, etc). The second way is to insulate from the interior side of the roof deck with closed cell spray foam (ccSPF) or a combination of ccSPF and either open cell spray foam (ocSPF) or fluffy stuff. Then add a small takeoff supply/return to the attic space to control humidity which travels up from the floors below.
ccSPF at 2" essentially becomes a vapor barrier. ocSPF will allow water vapor to migrate through to the roof sheathing where after repeated daytime solar drive that moisture will de-absorb and reabsorb at high sections of the roof and eventually rot.
The side benefit is that with an air-sealed attic space, you will get much better performance out of your HVAC and might even be able to save more $$ by replacing it with a smaller unit.
HVAC systems should NEVER be in an vented attic. Builders do it because they want to save money on construction costs.
