Jaguar / LandRover Filter cut open
by kstanf150 - 11/15/19 02:14 PM
trolley jack or something else
by John_Conrad - 11/15/19 01:58 PM
Are there any deals for oil at Walmart?
by whatplsty - 11/15/19 01:56 PM
"Medallion ATF" for Toyota WS
by TmanP - 11/15/19 01:37 PM
Ford Mustang Mach-E
by SlavaB - 11/15/19 01:26 PM
2005 Ford Taurus Fram Cabin Filter
by Snagglefoot - 11/15/19 12:15 PM
Is 10 microns concidered a bypass filter?
by jkhawaii - 11/15/19 12:09 PM
2018 Charger Hellcat 12,000 mile update
by mbacfp - 11/15/19 11:51 AM
Automotive Oscilloscope
by LazyDog - 11/15/19 11:42 AM
Let’s see how this looks after 4 seasons
by Bettez88 - 11/15/19 11:04 AM
Interstate batteries problems
by JimPghPA - 11/15/19 09:49 AM
2008 Dodge Ram 3500, first sample
by A_Harman - 11/15/19 09:44 AM
Steelers/Browns
by CourierDriver - 11/15/19 09:04 AM
Beard care in cold weather?
by pandus13 - 11/15/19 08:39 AM
Door Sill protection for new car - which one?
by henni - 11/15/19 08:18 AM
Exterior Home Security Cameras?
by Gebo - 11/15/19 08:13 AM
5w-20 ok for GMC 6.2l ?
by jdw1222 - 11/15/19 08:02 AM
M. Defender vs Cont. TrueContact Tour?
by lukejo - 11/15/19 07:53 AM
DjS71, Akhunter, rov137, Dorisy, DesktopDave
69870 Registered Users
102 registered members (73Duster, Aichiguy, 2015_PSD, 28oz, 53' Stude, 11 invisible), 2,151 guests, and 43 spiders.
Topics297,450
Posts5,115,969
Members69,870
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Lower MPG #5239580 10/14/19 05:02 PM
B
borgward Offline OP
B
2013 Fiesta SE Hatch Manual Trans 1.6 Liter Engine 55,000 miles. Bought brand new. The odometer has consistently reported 37 MPG overall mileage until lately. It is now showing 35 MPG overall MPG for the last several months. Seems a little early for spark plugs. No fuel in the oil. Hardly measurable oil usage between oil changes that I do my self. Mobil 1 From the first time I changed oil. Next oil change is due in several hundred miles. Oil analysis always come back very good. I plan to check the compression at next oil change.
I do suspect gasoline quality is heading south in Texas (Shell Regular) - I drove up to Kansas and out west to the Pacific coast last year. Car ran better on gas once I was going west. Even in California. As I entered Texas on the way back I got less pep and poorer MPG.
Anything else I should check?
Re: Lower MPG [Re: borgward] #5239587 10/14/19 05:06 PM
ctechbob Offline
Not sure if/when they roll out winter blend gas where you're at or not, but that is a possibility.
2008 Acura TL Type S-155k*
2003 Honda Accord V6-207k
Oil-Havoline ProDS 5W30 / *HM 5W20
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Lower MPG [Re: borgward] #5239588 10/14/19 05:11 PM
B
borgward Offline OP
B
I have been through 7 winter blend cycles here (if there is one here) and consistently got 37MPG overall - all seasons, until recently.
Re: Lower MPG [Re: borgward] #5239622 10/14/19 05:55 PM
CARJ Offline
Did you get new tires and/or have you checked your pressures recently?
2004 Toyota 4Runner | 193k | Havoline Pro DS 5w-30, YZZD3
2012 VW Passat | 96k | M1 0w-40, XG9911
1997 Honda Civic HX | 222k | M1 0w-30, PH3593a
Re: Lower MPG [Re: borgward] #5239626 10/14/19 05:57 PM
Dinoburner Offline
Curious if anyone else in that area is suffering the same problem.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Lower MPG [Re: borgward] #5239633 10/14/19 06:00 PM
M
mjk Offline
M
Have you checked the scale lately ? wink
Re: Lower MPG [Re: borgward] #5239638 10/14/19 06:04 PM
domer10 Offline
Try a fuel system cleaner such as Amsoil additive, or techron....and bump it up a grade while running it. Tire pressure also, with temp change tires tend to deflate a bit.
2013Jeep Wrangler Sahara Unlimited
2001 Toyota 4Runner
20010 Harley Davidson Rocker
Re: Lower MPG [Re: borgward] #5239656 10/14/19 06:19 PM
M
MParr Offline
M
Is your clutch slipping? At 55,000 miles that is possible. Seasonal gas blends can make a difference. What is the ethanol content of the fuel that you have been using?
2019 VW Tiguan SE Now: Mobil 1 ESP 5W30 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Lower MPG [Re: CARJ] #5239662 10/14/19 06:25 PM
B
borgward Offline OP
B
New tires a year ago. Pressure is on spec.
Re: Lower MPG [Re: mjk] #5239675 10/14/19 06:34 PM
B
borgward Offline OP
B
What scale? a measuring device, scale on something in the engine
Re: Lower MPG [Re: borgward] #5239681 10/14/19 06:40 PM
dareo Offline
is that year direct injected? if so, maybe carbon buildup?
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
Re: Lower MPG [Re: borgward] #5239690 10/14/19 06:47 PM
A
AC1DD Offline
A
I'm thinking sticking brake caliper or bad wheel bearing?
Re: Lower MPG [Re: borgward] #5239735 10/14/19 07:32 PM
V
vwmaniaman Offline
V
Have alignment checked. Maybe a pothole got ya.
Don't waste your time on a slipshod repair.
Re: Lower MPG [Re: borgward] #5239737 10/14/19 07:32 PM
V
vwmaniaman Offline
V
Weak battery needing more from your alternator.
Re: Lower MPG [Re: borgward] #5239740 10/14/19 07:38 PM
T
tiger862 Offline
T
Sounds like carbon build up.
Tiger862
2018 Grand Caravan
Page 1 of 3 1 2 3
