Originally Posted by burla
Yes, pretty reasonable oci. You may opt for a used oil analysis from blackstone at the 7k mile mark and make sure tbn is holding up. Every car is different, you never know. You may as well look into spun microglass filtration such as fram ultra as well. Paper degrades but spun microglass doesn't. I have even cut them open at 24 mos and they were still like new. Royal Purple, amsoil ea, fram ultra, wix xp and the most popular. Pair synthetic oil with synthetic filter for the win on a long oci.
Agree it is reasonable. Paper works fine at 24 months as well.
OP, is the engine in there one of the sludge monster engines? Does it smoke?
If it has the risk of sludge, which many Toyota v6 engine sof that era did, I'd go slow. Supertech syn may have less solvency than others, but it may also clean.
You might consider doing 1-2 short OCIs on an HDEO as well if sludge is a possibility.
