Thanks for the input fellas. I'll probably go with the TRW; sounds like you can't really go wrong with that brand, whereas the others have lines of varying quality.
I'm going to avoid Monroe this time around, I replaced the front struts about 50k ago with Monroe Limited Edition struts, which were a premium line at the time. The drivers side is already leaking fluid. So what was going to be a simple tie rod end replacement has now turned into lower control arms, struts, strut mounts and the tie rod ends. Might as well replace the sway bar end links while I'm in there. I did all this together about 50k ago but the boots have cracked and hemorrhaged grease on both the tie rod ends AND ball joints. I always err on the side of quality when buying parts, so this was all reasonably name brand stuff-- seems it's terribly difficult to find quality parts that hold up nowadays! Seems like I'd be better off buying the cheap Ultra Power and roll the dice... I digress. Will give the name brand stuff another go-around, the last set was supposed to follow this car to the grave!
