Temp Range to Check ATF '09 Highlander
VA
What is the temp range needed to check the ATF fill on a 2009 Toyota Highlander? I have the Scangauge.
I found a PDF for all my Lexus but can't seem to locate one that applies to Toyotas.
Char Baby, that is a most excellent idea. I follow you but I just looked at my Lexus chart and it only goes to '08
Hmmm sorry 'bout that. However, the '08 RX may be the same as an '09?!?!
IDK! I think the major change came in 2010?
CB
They do have same engine and transmission.
Genius thought process. I am impressed.
It's best to get the correct range...can you ask your dealer politely? Try someone in the parts department that has access. May have to call multiple dealers.
The two Aisin's I've worked on were both 35-45C. ‘05 MINI & 19 Buick Regal.
Actually, I'm looking for the PDF
Most all the Lexus are between 97-133F or 36-56C
I'm thinking 104-113 like Lotl said.
Originally Posted by Char Baby
Who, me?
Who else could it be?
