Is it worth its weight in cast iron?
by spavel6 - 07/06/20 03:42 PM
Hyundai O.E.M. 28113-H8100 replacement
by odie - 07/06/20 03:22 PM
Valvoline SynPower Power Steering Fluid
by Cheezit - 07/06/20 03:17 PM
Shell Rotella Gas Truck or Pennzoil?
by DCMotorsports - 07/06/20 02:49 PM
Interesting domino game
by 53' Stude - 07/06/20 02:49 PM
Grinding brakes when hot
by mclasser - 07/06/20 02:41 PM
Nylon spacers
by VeeDubb - 07/06/20 02:37 PM
Extra Long Valve Caps
by Mr_Luke - 07/06/20 02:28 PM
using vinegar to flush cooling system
by old1 - 07/06/20 02:11 PM
Best lube for refrigerator door hinges?
by paulri - 07/06/20 01:11 PM
RIP Ennio Morricone
by 2015_PSD - 07/06/20 12:49 PM
What oil do you recommend?
by BretBouer - 07/06/20 12:36 PM
NAPA Synthetic / Filter Sale
by WyrTwister - 07/06/20 12:16 PM
Squished Stihl MS 181
by Gebo - 07/06/20 12:14 PM
Used Review- '17 Nissan Armada Platinum
by panthermike - 07/06/20 11:53 AM
RIP Charlie Daniels.
by PimTac - 07/06/20 11:34 AM
Transmission fluid change
by dan765 - 07/06/20 10:53 AM
Toyota LL or SLL in a Ford?????
by TacoFergie - 07/06/20 10:52 AM
Pulling a vacuum to remove water
by Donald - 07/06/20 10:42 AM
Colt_38, DCMotorsports, BryceMateo, Dodgerose, AnotherPerson
71862 Registered Users
116 registered members (4WD, 2015_PSD, 928, 97prizm, 77GrandPrix, 64bawagon, 12 invisible), 2,283 guests, and 21 spiders.
Topics307,501
Posts5,312,201
Members71,862
2017 Chrysler Pacifica Oil #5217681 09/20/19 08:08 AM
M
Mathew_Boss Offline OP
M
We did infact pick up the 2017 Pacifica I asked about last week. The oil was very black so I changed it Sunday to PUP 0w20 with a Purolator One filter. I noticed high oil temps on the drive home. After changing the oil it's down a little but still higher than expected on interstate driving. before the oil change it maxed out at 240*F. Now the highest I have seen it is 232*F. This is at around 1,750RPM at 75 MPH. I do have another chance of PUP and a Wix filter for my next oil change. After that I was planning on regular Pennzoil Platinum and following the Oil Life Monitor. With that high of temps I was wondering if I should use QSUD which has a little more focus on anti wear but then is it going to leave more deposits due to the oil temp? Help me choose between QSUD and PP 0w-20 for my 2017 Chrysler Pacifica Touring L w/ 3.6L Pentastar (5 Quart Capacity Sump NOT 6) W/ 9Spd Auto
1.7k Mile 2019 Toyota Highlander LE Plus AWD 3.5L 2GR-FKS. PP or EDGE EP 0W20 w M1 or RP Filters
66k Mile 2015 Dodge Charger 3.6L Pentastar Pennzoil Platinum, QSUD or EDGE EP 0/5W20, or 5W30
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217712 09/20/19 08:48 AM
H
Hoot_r Offline
H
Just out of curiosity, how many miles are on the engine? You mentioned the oil being very black when you picked it up -- wondering if there's residual dirt still working its way through. The lower temps after the change are promising, but still on the high side.
2020 Kia Soul LX, 2.0L Atkinson-cycle I-4 (Nu)
Valvoline Advanced Synthetic 5W30, OEM Filter
Re: 2017 Chrysler Pacifica Oil [Re: Hoot_r] #5217719 09/20/19 08:52 AM
M
M
It had about 11,500 miles on it when I bought it. It was a 1 year lease in 17 that ended up sold at auction. it still has bumper to bumper warranty. I know the engine is still breaking in and that could be part of the higher temps but I have a 2015 Charger 3.6L AWD I bought with 32k miles on it and now it's about to hit 70k. On the interstate even pushing 82MPH temps dont normally exceed 195. It also has the 6 quart sump though.
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217721 09/20/19 08:53 AM
B
Bighorn2500 Online Content
Online Content
B
Either one will be fine, I find the QSUD is typically a few bucks cheaper.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217734 09/20/19 09:05 AM
J
JC1 Offline
J
Yes either oil is fine. You'll be fine, don't sweat it.
If that was me and I was that concerned, I'd probably run some cheap 5w-20 through it for a short 1000 OCI to see if that cleaned it up.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217736 09/20/19 09:10 AM
H
Hoot_r Offline
H
Lease? With oil as dirty as you described, I wonder about maintenance during that 1 year period. Were there any service records that came along with the vehicle?
Re: 2017 Chrysler Pacifica Oil [Re: Hoot_r] #5217741 09/20/19 09:16 AM
M
M
No service records. My charger oil life is always exactly 10k miles and I know the van is rated up to 10k miles. Worst case scenario I did the first oil change it ever had and it was 1,500 miles late. I think the two oil changes of PUP would clean any deposits that may be there. There didnt appear to be any sludge on the cartridge filter. The filter. Was also not installed properly so there a chance it was. Changed at some point. With the Pentastar the oil filter snaps onto the end cap and this on was just placed down in the engine with the cap screwed on.
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217767 09/20/19 09:40 AM
dtownfb Online Content
Online Content
Congratulations on the purchase. My guess is you did the first oil change on the van. Here's a link to the Chrysler Pacifica Forum: https://www.pacificaforums.com/forums/#2017-chrysler-pacifica-tech-section.369
You may find out more about the oil temperatures there.
Good luck.
2006 Toyota Camry
2013 Toyota Sienna
2015 Toyota Camry
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217829 09/20/19 10:50 AM
O
oldhp Offline
O
What is the water temp when the oil is 232°? My 2018 RAM 3.6 the oil temp will slowly follow the water temp, higher and lower. The water will go from 195° to 230°.
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: 2017 Chrysler Pacifica Oil [Re: oldhp] #5217831 09/20/19 10:54 AM
M
M
Yeah water temp was right around 230 as well. On my dash it was still below half way on the temp gauge. My Charger water temp also follows the oil. It didnt seem concerned but everything just seems higher than I expected. I know oil does help cool the engine. the Pacifica forum folks say its normal. Maybe it's just a byproduct of the 5 quart sump.
For oil choice would go go for anti wear QSUD or extra detergent on PP
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217833 09/20/19 10:56 AM
A
ATex7239 Offline
A
Have you checked the fans, radiator, coolants, etc for levels and obstruction as well?
'12 Buick Enclave 173K
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Vehicle) 90K
Oil - Don't know
Filter - Don't care
Re: 2017 Chrysler Pacifica Oil [Re: ATex7239] #5217835 09/20/19 10:58 AM
M
M
All fluid levels are good with no leaks. I dont recall checking the fan. We bought the van on Saturday and my Niece was diagnosed with Leukemia Monday morning so we have put almost 700 miles on it driving back and forth since then. I'll check tonight to see if the fan spins.
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217868 09/20/19 11:34 AM
M
M
Maybe I should try Royal Purple ICE additive. That's might lower my coolant and oil temp.
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5217944 09/20/19 12:45 PM
A
ATex7239 Offline
A
The fan on my wifes Buick was squeaking last week and engine temp was hotter than normal. WD40 fixed it right up. But my fan issues were at idle, I wouldn’t imagine (referencing your problem) it is on at highway speed.
I have however rigged up the fan to run all the time in past, when the car has over heating issues... but that’s a broke and need my old junky car fix... not a new car fix
ACDelco PF63E
Oil - Don't know
Filter - Don't care
Re: 2017 Chrysler Pacifica Oil [Re: Mathew_Boss] #5218039 09/20/19 02:34 PM
O
oldhp Offline
O
I put QSUD 5W20 in the wife's Charger 3.6. I like the amount of moly it has in it.
I just bought the Chevron Supreme 5W20 5qt jug 6 pack form Walmart for $73.19 to my door. This is going in my 2018 RAM 3.6.
