17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
Glock 44
by bradepb - 01/22/20 08:04 AM
Open up area in basement
by redhat - 01/22/20 07:42 AM
Briggs Intek Leaking Crankshaft Oil Seal
by UncleNorby - 01/22/20 06:26 AM
1ZZ-FE MR-2 (weekends and trackdays)
by geetar - 01/22/20 04:58 AM
Did Rotella Ever Have JASO MA Certification?
by BBDartCA - 01/22/20 12:49 AM
Old Tundra Headlamp Upgrade
by JeffKeryk - 01/21/20 09:41 PM
Phildrum, 335xiE92FBO, oldrover, sarojasaruu, someoldguy
70503 Registered Users
108 registered members (4WD, 928, 28oz, 335xiE92FBO, 69Torino, 6 invisible), 2,064 guests, and 21 spiders.
Topics300,434
Posts5,175,709
Members70,503
Barb fittings and correct hose size? #5170217 07/24/19 10:03 PM
TheLoneRanger Offline OP
I have a remote filter kit that has 3/8" ID fittings, and a length of 5/16" hose. The hose will push on the fittings, but it's very tight
and seems to be too small. I'm concerned the hose will split. My thoughts are that a 3/8" hose would be a much better fit.
I also have an old ATF external cooler kit on the shelf, and it too has 3/8" fittings and 5/16" hose....it seems some mfgs ship
their kits with the next smaller sized hose.
What size hose do you guys use with a particular sized barb fitting?
Some days you eat the bear, some days the bear eats you.....
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5170225 07/24/19 10:47 PM
O
oldhp Offline
O
I've always used the size of the fitting. 3/8" O.D. barb fitting gets 3/8" I.D. hose etc.
"None of us are getting out here alive.....drink that beer.....eat that pizza......drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just wait"
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5170232 07/24/19 11:08 PM
clinebarger Offline
Don't stretch 5/16" hose onto 3/8" fittings.....You will stress/break the reinforcement cords in the hose! Universal kits are just that.....They Universally fit NOTHING!
2001 Chevy Camaro L92/4L80E
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5170423 07/25/19 08:51 AM
I
Ihatetochangeoil Online Happy
Online Happy
I
Your life, your money, your engine, etc. My two cents (and experience) is do NOT use anything except the correct size hose for the fittings! Additionally, you need hose sufficiently rated not only for the pressure but also for the temperatures. IF you have an unexpected LEAK at highway speed (while you're cruising/listening to music/watching the world go by...) how many SECONDS will it take to cost you an engine?
I have twenty-something fittings under my hood; I also carry with me at all times extra fittings, hose, clamps, knife, wrenches & assembly tools to replace any hose anywhere I'm at. It all fits in a small tackle box in my trunk and helps my heart be still on long trips. You probably know you can't go to Walmart or Napa or Autobone in Anytown, USA and buy AN barb fittings, NPT adapters and whatever is necessary to plumb a remote or bypass filter.
Whatever
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5170978 07/25/19 09:28 PM
Good advice from all. I carry an emergency tool set in my vehicles, but extra hose, clamps, etc (and ATF) is a good idea.
I bought some 3/8" ATF hose. It's Gates brand, rated for 400 psi and high temp. Surprisingly it's also made in the USA.
Looks to be a good quality hose, with strong reinforcement cords.
Any opinions on using constant tension/spring clamps vs worm gear clamps?
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5173086 07/28/19 03:13 PM
E
eljefino Offline
E
Put a mic on that barb, it could be an in-between size like 11/32. They seem to pull this a lot with ATF hose.
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5173398 07/28/19 09:43 PM
I measured it again with my calibrated eyeballs, and it's indeed 3/8". I know what you mean, Eljefino. I think mfgs put
5/16" hose in both their 5/16 and 3/8 kits just to save a few pennies.
Re: Barb fittings and correct hose size? [Re: eljefino] #5181140 08/07/19 12:23 PM
L
Linctex Offline
L
The hose that comes included with most all trans cooler kits is indeed 11/32"
Re: Barb fittings and correct hose size? [Re: TheLoneRanger] #5213473 09/15/19 01:48 PM
Yah-Tah-Hey Offline
You can't do any better than a constant pressure Mobea type hose clamp.
Re: Barb fittings and correct hose size? [Re: Yah-Tah-Hey] #5214791 09/16/19 09:39 PM
I used constant tension clamps, and looked on the box today for the brand, but it wasn't listed. They might
be Mobea/Mubea but I'm not sure.
The clamp size is for a 5/8" OD hose, and the clamp measures 9/16" ID. It's that 1/16 of an inch difference
that gives the clamp it's clamping force. Interesting....
