New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
95 registered members (AJB0009, alarmguy, 4WD, AandPDan, andyd, 03s, 5 invisible), 1,841 guests, and 18 spiders.
Topics306,004
Posts5,284,527
Members71,558
What is the reasoning for 2-fuel tanks on a rv? #5214658 09/16/19 07:54 PM
R
RazorsEdge Offline OP
R
A friend if mine has a older RV with 2-fuel tanks.
Anyone know the reasoning behind this?
Schaeffer Oil 👍😎
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214661 09/16/19 07:57 PM
spasm3 Offline
So you can drive further between gas stations.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214662 09/16/19 07:57 PM
E
E150GT Offline
E
Longer range? My truck has two fuel tanks.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214669 09/16/19 08:03 PM
R
R
When you look underneath you'll see one take has a fuel pump, the other doesn't so I'm assuming there is some sort of a switch to switch between the two tanks?
Schaeffer Oil 👍😎
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214674 09/16/19 08:08 PM
Chris142 Online Content
Online Content
4 mpg most likely.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214693 09/16/19 08:28 PM
O
oldhp Offline
O
Premium in one tank for hills.....................
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214702 09/16/19 08:36 PM
K
KGMtech Offline
K
Balancing the weight?
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214704 09/16/19 08:37 PM
P
PumpPusher Offline
P
Design limitations? Easier to build around two smaller tanks vs 1 large one?
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214743 09/16/19 09:24 PM
H
HangFire Offline
H
It is cheaper and easier to add a tank, then it is to replace the OEM tank with a larger tank.
Various musings: http://hangfire.net
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214765 09/16/19 09:48 PM
Cubey Offline
I don't know how true it is, but I was told that my diesel class C (see sig) is odd for having dual tanks. It has a third tank for gasoline, which IS uncommon, I think. Rather than equip it with an LP generator, they put a gasoline one with it's own fuel tank and fuel level gauge. I only use the 18 gallon front tank right now. It gets 9ish hwy mpg so that's fine for me. I like to take a break after 100 miles or so anyway.
1985 Ford E-350 27ft Class C RV (6.9L IDI w/ ATS 085 Turbo, C6 A/T, Dana 70 4.10) MPG @ Fuelly
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214768 09/16/19 09:52 PM
U
UncleDave Offline
U
because gasoline rigs share the fuel with the genset its so they can have some actual range or dry camping staying power.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: UncleDave] #5214778 09/16/19 10:09 PM
Cubey Offline
UD
I had a 78 Dodge 1 ton van chassis Class B (SRW) motorhone with a factory single 36 gallon gas tank. I had to rebuild the impossible to find fuel sending unit and hand cut a new cork gasket for it. It fed the generator too but only to a certain point in the tank, so the generator would run dry without emptying the tank. That tiny 19ft short class b got 9 bloody mpg and I had it when gas was $4. Yeah, ouch.
I get about 9 mpg hwy in my current big 27' class C diesel with a 4.10 rear. The Dodge had 3.55. I'd probably get 10.5mpg if I had a 3.55 in the C...
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: Cubey] #5214786 09/16/19 10:29 PM
U
UncleDave Offline
U
UD
The genset feeds are purposefully set short in the tank so you dont inadvertently get yourself in a situation where you cant drive out of a dry camp where you are under a heavy load like an AC unit running 24/7.
This can be super annoying if you aren't level which can reduce run time even further.
UD
Uncle Dave
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214788 09/16/19 10:37 PM
J
jongies3 Offline
J
Until the mid 90's, dual tanks were the norm on pickup trucks. Not very unusual for RVs to have them also! Both guzzle gas so it makes sense to have one for backup.
My old first generation Bronco has them as well, it's nice since the fuel gauge doesn't work, when one runs out, just switch over and carry on! Handy as heck.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: QSGB 5W-30, FRAM PH3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: What is the reasoning for 2-fuel tanks on a rv? [Re: RazorsEdge] #5214801 09/16/19 11:16 PM
A
A_Spruce Offline
A
As has been said, low MPG of the vehicle and the genset adding to the fuel load, requires the need for more fuel storage for longer distances and "parked" ability while running a genset. Even with all that, it isn't a bad idea to carry an extra 5 to 10 gallons at all times.
'03 Suburban
