Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Tractor Supply more Mobil 1 clearance
by jayjr1105 - 02/24/20 10:51 AM
BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
PeterNST, SkinnRS, Bama65, wjamyers, L00btech
70793 Registered Users
123 registered members (1978elcamino, 01VFR, 2015_PSD, 53' Stude, advocate, Alfred_B, 10 invisible), 2,270 guests, and 16 spiders.
Topics301,868
Posts5,204,287
Members70,793
ford 8n grey gooey gunk in the oil pan. #5210685 09/12/19 05:44 AM
J
jakewells Offline OP
J
Pulled the oil pan due to leaks and noticed grey gunk on the bottom some was gooey the rest was hardened i got it cleaned out and it was chore some of it was really on there. Is this sludge or combustion by products of the gasoline used in the early years of this tractors life.
2001 Mercury Cougar base 2.5l CD4E automatic.
Re: ford 8n grey gooey gunk in the oil pan. [Re: jakewells] #5210693 09/12/19 05:52 AM
F
Fawteen Offline
F
A combination of all of the above. Those old tractors were used in some of the worst environments, and to top it off they had overly robust cooling systems, and it's not uncommon for people to completely remove the thermostat. That really never allows the engine to fully warm up unless it's out plowing for a few hours. Decades of vintage oils, a vintage filtering system, and an old flathead engine design all contribute to the problem. The kicker is that those old engines still perform just fine despite all that.
If you want an eye opener, pull the side covers off the valves and give that area a good cleaning.
Re: ford 8n grey gooey gunk in the oil pan. [Re: jakewells] #5210695 09/12/19 05:55 AM
doitmyself Offline
If that pan has never been off, I suppose that layer could be from the old days of low/no detergent oil that allowed contaminants to settle out, unlike today's oils that keep contaminants suspended and they exit the engine with an oil change. Just a hunch.
Re: ford 8n grey gooey gunk in the oil pan. [Re: jakewells] #5210703 09/12/19 06:12 AM
Chris142 Offline
Lead from leaded gas.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: ford 8n grey gooey gunk in the oil pan. [Re: Fawteen] #5210705 09/12/19 06:13 AM
J
J
Side cover is clean i have owned it for a little over 4 years and i adjust valves yearly during normal maintenance it has been always clean every time i have been in there. I run a 192 thermostat in my tractor because the prev thermostat was a 160 from the original owner and that is not hot enough. I use harvest king sae 30 in the pan but previous years i used delo sae 30 CF/SL .
Re: ford 8n grey gooey gunk in the oil pan. [Re: jakewells] #5210738 09/12/19 07:13 AM
Chris142 Offline
Running a 192 thermostat may be a bit much. The OEM thermostat was likely a 150 or 160 and that's where Ford designed it to run. Maybe use a 180. Is the radiator pressurized? 4psi maybe? A 192 thermostat puts it too close to the boiling point imo.
Re: ford 8n grey gooey gunk in the oil pan. [Re: Chris142] #5210746 09/12/19 07:23 AM
J
J
slight pressure in the radiator but i noticed with a higher thermostat the oil has no condensation or water. before switching i never could get the engine hot enough to get rid of the moisture in the oil.
Re: ford 8n grey gooey gunk in the oil pan. [Re: Chris142] #5210882 09/12/19 10:26 AM
O
Oldmoparguy1 Offline
O
+1
All I/C engines prior to the introduction of unleaded gas had the same gunk in the pans & valley covers, and any other place oil would sit. I've cleaned up a number of of them in my day.
Nasty stuff.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: ford 8n grey gooey gunk in the oil pan. [Re: jakewells] #5210910 09/12/19 11:10 AM
Cujet Offline
The grey colored paste is very likely to be lead deposits from the past use of leaded fuels.
People really don't understand how much fuel bypasses the rings, evaporates and leaves deposits. Not to mention the blow-by of combustion.
Re: ford 8n grey gooey gunk in the oil pan. [Re: Chris142] #5211087 09/12/19 03:17 PM
L
Lubener Offline
L
The cooling system in those old N- tractors were over engineered. It took something serious to boil them over. My 9N (which is older than an 8N)uses a stock 180 stat and a non pressurized system. That gunk on the bottom of the pan is accumulated debris by using non detergent oil of that time which could be dating back as far as 1948 and who knows if one of the past owners may have removed the thermostat at some point contributing to the sludge...
The "thinking" man's friend.
