New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
103 registered members (Ag76, AC1DD, Aichiguy, ABursell, 2003f7, 2009Caraman, 8 invisible), 1,946 guests, and 22 spiders.
Topics301,806
Posts5,203,090
Members70,784
Page 1 of 3 1 2 3
Difficulty reading dipstick to accurately check oil level? #5207957 09/08/19 06:08 PM
E
Ed_Flecko Offline OP
E
I don't know if it's the oil, the color, how thin it seems, etc., but I'm having a really tough time actually seeing how much oil is on the dipstick!
I need your help/advice.
I have a new 2019 Toyota Tacoma with the 3.5L, V6 motor. I drove my truck on a few errands around town to get the motor and oil hot and then I changed my factory fill oil today, with appx. 1,500 miles on it, I refilled with the factory specified 0W-20 TGMO oil and installed the TRD (PTR43-00082 - https://bit.ly/2Y2uo2R) filter rather than the OEM cartridge (04152-YZZA1 - https://bit.ly/2XObs3P) filter.
My manual says my capacity is 6.1 qt. To be on the safe side, I've added, maybe, 5.5 qt., started my truck and let it run for a few minutes to check for leaks and then parked in my garage. For the last few hours, I'm waiting for all oil to drain back into the pan and hoping to be able to get a good read on my dipstick, but it's challenging. I find it very difficult to see where the oil line is!
I'm one of the picky people who likes to get my oil full...without overfilling.
Maybe I'm agonizing too much. Should I just dump in the remaining amount from the quart bottle (it might be about .5 quart?) and call it good?
smile
Thanks for your thoughts!
Ed
K-9s teach the suspect that if you run...you'll only be arrested tired.
Support YOUR local law enforcement K-9 Unit!
https://www.ssdk9.com/
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5207973 09/08/19 06:24 PM
W
WylieCoyote Offline
W
After an oil change, I add the prescribed quantity, run it a few minutes, park it in the garage, pull & wipe, re-insert part-way, and leave the hood up overnight as a reminder to check it the next morning. Stick & pull the next morning, and check the level under a light fixture. You should be able to see a definite line. If not, you may need glasses. (I have to wear mine to check oil).
I always check oil cold, for consistency.
2015 GMC Canyon 3.6
2018 Mustang Ecoboost Convertible
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5207980 09/08/19 06:35 PM
Nick1994 Offline
Get those blue shop paper towels and lay it under the hood. Pull the dipstick and rest the end on the paper towel and see where it's wet.
2015 Hyundai Genesis 5.0L 57k Mobil 1 5w30 & Wix
2000 Toyota Camry 2.2L 236k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5207982 09/08/19 06:37 PM
T
TmanP Offline
T
The 3.5 we have in the Sienna is similar. Very difficult to check the oil on for the first few thousand miles after a change. I've found that it's easier to check when completely cold and without wiping off at all. Fortunately, I've never had to add a drop in 200,000 miles! (And that's with some OCIs in excess of 10,000 miles with Mobil 1 or similar.)
2012 Toyota Camry 2.5 60,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 50,000 mi
2010 Toyota Sienna 3.5 V6 200,000 mi
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5207999 09/08/19 07:16 PM
M
mattd Online Content
Online Content
M
Angle the dipstick in the light you should be able to see it
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208006 09/08/19 07:30 PM
paulri Online Content
Online Content
I've given up trying to read my Toyota dipsticks (different engine--both have 3.3L) after running the motor. I have since taken to pulling the dispstick first thing in the morning, before engine is turned on. I don't even wipe it off to insert it back in and then pull it out a second time. I read it with the first pull out, and I can always see clearly where the oil level is.
2005 Toyota Sienna LE; 163,000 miles
2006 Toyota Highlander Hybrid 118,000 miles
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208008 09/08/19 07:34 PM
slacktide_bitog Online Content
Online Content
Honda uses an orange plastic dipstick on their newer cars, and it is impossible to see the oil until it darkens during the OCI mad
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208023 09/08/19 07:45 PM
B
borgward Offline
B
Similar problem w/1.6 liter Ford Fiesta SE Manual. Hard to see. Also, the marks on the dipsitck do not jive w/reality. I do an oil and filter change, add the prescribed amount of oil, it is never up to the full mark. Even after running the engine, and then checking cold in the morning. Either the marks on the stick are wrong, or the owners manual is wrong.
Re: Difficulty reading dipstick to accurately check oil level? [Re: Nick1994] #5208030 09/08/19 07:55 PM
B
buster Offline
B
That's not a bad idea.
The dipstick I have now, and previously on the Mazda, had a hole at the top. I just changed the OE fill @ 1k miles. The oil is very light but you can see it if you look close enough. Once the truck is at operating temperature, wait about 10 minutes then check it.
2019 Frontier Pro 4X - RGT 5w30
2019 Impreza Sport - OE fill
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208046 09/08/19 08:23 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Ive found atf to be a bigger challenge to check...
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208048 09/08/19 08:25 PM
CT8 Offline
Put in the rest of the oil to make it 6 qts and drive it.
2015 F150 2.7
2018 F350 6.2
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208049 09/08/19 08:26 PM
G
geeman789 Offline
G
I have three cars ... Honda Pilot has a wonderful etched aluminum tip dipstick which is super easy to read, new oil, old oil, hot, cold. Works awesome. The Mazda has a standard flat steel oil dipstick with high and low notches. Works ok, but seeing brand new oil is a bit of a challenge sometimes. After a few 100 miles, works fine...
The Subaru dipstick is terrible. Check the oil three times in a row, get three different readings. The dipstick itself goes thru an S curve to get to the pan, so half the time the reading is scraped / smudged too much to read. Worst dipstick ever. And, of course, it is the car that actually burns / leaks a measurable amount of oil ... so I need to check it more frequently than the others.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Difficulty reading dipstick to accurately check oil level? [Re: CT8] #5208050 09/08/19 08:28 PM
G
Gebo Offline
G
+1
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
QS HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Difficulty reading dipstick to accurately check oil level? [Re: Nick1994] #5208077 09/08/19 09:30 PM
B
bbhero Online Content
Online Content
B
This is the ticket in my opinion ^^^^^^^
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Carquest r84356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Difficulty reading dipstick to accurately check oil level? [Re: Ed_Flecko] #5208136 09/09/19 12:06 AM
oilmutt Offline
smile
Ed
On our 2016 toyota 4 cyl,the manual calls for 4.7 qt. for a change,I use a 5qt. container and the dip stick shows the oil at the full mark,if we try 4.7qt. of oil the reading is all over the dip stick,its never the same reading for 2 oil changes in a row.Go figure!
'05 Chevy Malibu 6cyl,119k, Syn. Oil (owned)
'16 Toyota Camry,4cyl 25k Syn oil (leased)
'92 Ford Tempo ,4cly 26k Conv oil (managed)
Page 1 of 3 1 2 3
