Tractor Supply more Mobil 1 clearance
by jayjr1105 - 02/24/20 10:51 AM
BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
S&W 38 Special
by BlueOvalFitter - 02/23/20 07:23 PM
Oil Life Monitor question
by Mark72 - 02/23/20 07:06 PM
Any member a tax accountant ?
by mjk - 02/23/20 07:00 PM
Driven oil delivered after 6 months
by luna - 02/23/20 06:48 PM
M1 209 VS M1 209A
by BlueOvalFitter - 02/23/20 06:19 PM
Sig P516 - my take
by stockrex - 02/23/20 05:45 PM
Advise for Euro E36 M50 engine
by Lucase483 - 02/23/20 05:43 PM
PeterNST, SkinnRS, Bama65, wjamyers, L00btech
70793 Registered Users
115 registered members (53' Stude, Alfred_B, 1978elcamino, Astro14, Bailes1992, 01VFR, 11 invisible), 2,391 guests, and 17 spiders.
Topics301,866
Posts5,204,262
Members70,793
Liqui-moly motor saver and mos2 #5204979 09/05/19 02:56 AM
E
Espada Offline OP
E
I had smoke burning at start up and started using motor oil saver added a full can to 3.3 liter of oil and had good results, to keep the results do i use it with every oil change ? And can i add MOS2 safely at every oil change because its much cheaper to use the oil i am using and adding MOS2 additive made by LM than using their oil with the additive in it, i change my oil every 2000km its an SJ rated oil
Re: Liqui-moly motor saver and mos2 [Re: Espada] #5204981 09/05/19 03:05 AM
Dufus2 Offline
I used Motor Saver and the front seal quit slinging oil, used a 2nd can when the valve seals were causing excessive smoking. I really don't think you need to use it with every oil change.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
Re: Liqui-moly motor saver and mos2 [Re: Dufus2] #5204983 09/05/19 03:09 AM
E
Espada Offline OP
E
To keep seals and pistons from burning oil do i add it every 20000km as they recommend or do i add like small amounts with each change to keep the effect
Re: Liqui-moly motor saver and mos2 [Re: Espada] #5205004 09/05/19 04:08 AM
Dufus2 Offline
I used one can to 9 qts of oil and it worked well for me. I have little experience with the product.
