Hello everyone l decided to make a post here after seeing that you guys seem to really known your stuff. So here goes nothing
I guess this will be my first detailed post. Little backstory for you guys, I bought this 2007 g35x sedan in March from Philly. It was super clean had no issues and I loved it. Still do but my recent discovery has definitely put a damper on that love.
A month ago I started to have cooling issues that I couldn't track down. It first started with bubbles in the coolant reservoir so I thought the worse and assumed it was the head gaskets (scary) did a block test and was happy to see it wasn't my issue.
So next I decided to do some research and found that sometimes a radiator cap would cause a bubbling issue due to it not holding pressure anymore so I swapped that and all was good for a week or so.
Fast forward and I'm having the same issues and now I'm even more aggravated so I decided to check the lower radiator hose after a drive and long behold the [censored] hose is cold and the upper is like extremely hot. So now I'm like great, it's the thermostat that's sticking and this shouldn't be to much effort to change it.
And this is where things went from optimistic to just downright horrible.
I went past infiniti to grab an oem thermostat and a gasket and went home to remove the thermostat that's when the horror arrived.
At first glance I really thought the thermostat that was removed from the car was r thermostat for a vq35de but upon further inspection... That IS A HOLE THAT WAS DRILLED INTO THE THERMOSTAT THAT WAS DRILLED INTO THE ENGINE BLOCK BEHIND THE THERMOSTAT. ...¡
Why drill a hole? Why drill a hole and then drill into the block itself? I did more looking and then found out why.
It looks and felt as though the hole where the screw goes was broken so they used another bolt to secure the thermostat to the block. I also found out that the bolts they were using to secure the thermostat was the wrong size and were being secured by more rtv. I'm being annoyed with all this stuff and I'm trying to process how to fix this situation because besides this issue the car has no issues whatsoever.
Thanks for reading my post of frustration and hopefully someone can chime in and help me out a bit
Images would help but I'm trying to figure out how to upload. Thanks in advance
