Especially since BMW issued LL-01 approval to Mobil very recently for one of their new oils. So, no, its not impossible to obtain LL-01 from BMW.
Originally Posted by wemay
Originally Posted by edyvw
Originally Posted by f355spider
Originally Posted by Donald
Look in the owners manual to see what spec oil it needs. Go to Walmart and pick some up. Decent filter like a NAPA Gold.
Your generic answer won't work in this case. Per the OP, he has a BMW. Walmart doesn't carry oil filters for BMWs, nor does it carry any oils that are BMW LL-01 spec...unless you get lucky and find some old stock Castrol Edge 0w-40 that still had the LL-01 approval.
Castrol Edge is still recommended for LL01. BMW is not doing LL01 approvals and Castrol changed formula which means it would have to go through new approval, which is impossible.
He can use with confidence Castrol 0W40, Mobil1 0W40 in that engine. Both carry MB229.5 which is stricter than LL01. Only difference between LL01 and MB 229.5 is that LL01 has slightly stringent oxidation requirement.
In the past, when these oils did meet LL01 you were all about "you need to use only what the car is spec'd for, period". Now that these oils don't carry said spec... "use with confidence" along with attached justifications is your new twist?
