I scored an old Pioneer Premier stereo at the thrift store for $5 and the crackhead wiring of the previous owner is so bad you can't help but be impressed by it.
They used house wire nuts on mostly everything which is the #1 automotive wiring sin but it gets even better...
They spliced together all of the speaker positives and grounds so they could run 4 channels of audio out to 2 speakers, and they spliced together the constant, ignition, and remote wires.
I'm assuming in it's past life this stereo was hooked up to a bench power supply and used as a garage radio based on everything I seen. I plan to do the same thing with it myself but I'm cleaning up the wiring and doing it properly. Might just get a new-old-stock replacement harness from PACParts...
