belt squeaking suddenly
by dogememe - 02/24/20 11:45 PM
Is Mobil 1 advanced synthetic a full synthetic?
by apollo18 - 02/24/20 11:08 PM
what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
57 registered members (Arob, apollo18, A_User55555, alcyon, aleneros, 8 invisible), 1,468 guests, and 20 spiders.
Topics301,895
Posts5,204,831
Members70,798
So terrible you can't help but be impressed #5196416 08/25/19 05:09 PM
cwilliamsws6 Offline OP
I scored an old Pioneer Premier stereo at the thrift store for $5 and the crackhead wiring of the previous owner is so bad you can't help but be impressed by it.
They used house wire nuts on mostly everything which is the #1 automotive wiring sin but it gets even better...
They spliced together all of the speaker positives and grounds so they could run 4 channels of audio out to 2 speakers, and they spliced together the constant, ignition, and remote wires.
I'm assuming in it's past life this stereo was hooked up to a bench power supply and used as a garage radio based on everything I seen. I plan to do the same thing with it myself but I'm cleaning up the wiring and doing it properly. Might just get a new-old-stock replacement harness from PACParts...
[Linked Image from i.imgur.com]
2007 Honda CR-V LX "The Linoleum Falcon" 210K miles
HK conv 5w20, STP blue bottle, PrimeGuard POF4610 filter.
"Bad decisions make good stories."
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196426 08/25/19 05:28 PM
E
eljefino Offline
E
That's not all that bad-- if you have a pickup with only two speakers this takes the fader out of the equation.
Only weird thing is including the remote wire in the mess. Of course if they didn't include it in the bundle, they'd have had to cap it off, using another expensive cap. LOL
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196458 08/25/19 05:52 PM
Update: it lives! The faceplate won't slide out to reveal the CD player because that button is broken off, but the tuner works great.
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196473 08/25/19 06:00 PM
On a side note, if I go through with my 4th gen camaro LS build I wanna swap this radio into the car as it would be period correct to the car. Anyone know where I can get a used or NOS XM module for it?
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196546 08/25/19 07:18 PM
H
hallstevenson Offline
H
What's wrong with using wire nuts ? Didn't know they were only for "house" wiring. In fact, they're not. They make wire nuts for wire as small as 22ga and you'll pretty much never have this in home electrical usage.Is there a concern about, maybe vibration ? I've used them myself with no issues but my preference was male/female bullet connectors. This was quite a few years ago though....
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196554 08/25/19 07:29 PM
It's mainly because wirenuts are designed for solid core wire, not stranded wire which is common for automotive. Instead of threading on the wire properly a wirenut will crush the stranded wire which can lead to connection problems.
https://www.mobileedgeonline.com/wire-nuts-car-radio/
On all the stereo installs I've done I have used heatshrink butt connectors and/or crimp caps, whichever I have on hand at the time.
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196624 08/25/19 08:32 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Yet every UL listed lighting fixture gives you stranded wire to nut to your conductors.
Lots of other places use conduit and stranded.
Not saying it’s right for a vehicle where there is vibration and sometimes shock events.
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196658 08/25/19 09:14 PM
R
rubberchicken Offline
R
eBay- a couple of sellers offer "rebuild" services for period radios, so I bet they could get you something if its not listed.
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196826 08/26/19 06:19 AM
I
incognito_2u Offline
I
How does it sound?? laugh
2006 Jeep Commander 3.7 V6 -115k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -87k (M1EPHM5W30/XG3600)
1999 Toyota Corolla 1.8 -89k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196866 08/26/19 07:02 AM
I hooked it up to the bookshelf speakers in my room and it sounds really clear and has crisp, punchy bass too.
I'm definitely keeping it in case my 4th gen Camaro project moves forward because then I'll put it into that car so long as I can get the faceplate release button fixed.
I might open the radio up later and solder some wires coming out to a momentary switch that I can just push to open the faceplate as it's motorized flip-out. Won't be the most beautiful solution but it'll work.
Re: So terrible you can't help but be impressed [Re: JHZR2] #5196885 08/26/19 07:19 AM
H
H
It's mainly because wirenuts are designed for solid core wire....
Not true. Sounds like a case of "I've heard...." vs what's factual and spec'd by wire nut manufacturers.
Stranded wire is very common - ask any electrician if the 500' spools of 12 or 14 gauge wire in his truck is stranded or solid. It will be stranded. Ever worked with solid wire ? It's stiff !
Re: So terrible you can't help but be impressed [Re: hallstevenson] #5196895 08/26/19 07:26 AM
SubieRubyRoo Offline
Back when my dad was still working as an electrician, his arms and forearms were quite impressively muscled even though he didn't lift weights. He gave all the credit to fishtape, solid-conductor wires, and long conduit runs LOL
De omnibus dubitandum.
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5196958 08/26/19 08:38 AM
Hootbro Offline
That thing is like trying to fix a disposable BIC lighter when empty, not worth the effort.
2020 Jeep Gladiator Rubicon 3.6L (Dealer Bulk 0W-20)
2017 Jeep Renegade Latitude 2.4L (Idemitsu 0W-20)
2013 Volkswagen Jetta 2.5L (Havoline HM 5W-30)
Re: So terrible you can't help but be impressed [Re: Hootbro] #5198020 08/27/19 12:37 PM
SirTanon Offline
I dunno.. For $5, it looks like a pretty decent little stereo. Also, if he's enjoying the labor of getting it working, and it sounds good, I'd call it a win.
2013 Nissan Altima SV - 2.5 liter/CVT - 125,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 68,000mi
2010 Ford Fusion - 274k mi - SOLD
Re: So terrible you can't help but be impressed [Re: cwilliamsws6] #5198069 08/27/19 01:21 PM
G
George7941 Offline
G
Wire nuts work well in house wiring when at least one of the conductors is solid because the stranded ones can be lightly wrapped around the solid one and the wire nut, when twisted on, will bite into the assembly and hold them together tightly.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
