Spark plug gap f
by Rohan - 02/22/20 10:28 PM
Mad mike hughes.rip
by Chris142 - 02/22/20 10:15 PM
MTF drain = chocolate milk
by Texasdoc - 02/22/20 10:02 PM
New Valvoline looks promising?
by kr_bitog - 02/22/20 08:45 PM
rock like debris in generac generator 17kw
by jb5150 - 02/22/20 08:25 PM
FL820S C&P BAD GLUE JOB
by naterbomb - 02/22/20 08:21 PM
Photo Uploader Not Working
by ZeeOSix - 02/22/20 07:49 PM
Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Markovchain, o_s, naterbomb, Jimiii, jb5150
70784 Registered Users
94 registered members (2strokeNorthstar, AC1DD, 01VFR, 2013ecof150, 4WD, 2010Civic, 12 invisible), 1,673 guests, and 17 spiders.
Topics301,808
Posts5,203,104
Members70,784
grease in a golf cart clutch #5196079 08/25/19 08:53 AM
J
jacobsond Offline OP
J
Ok oil peeps need advise. Gas golf cart a greasable clutch. What kind of temp range should I look for. Been using a grease with a temp range of 0-200F. I think that’s why I screwed up my clutch bushing. Would a Marine & Off-Road Calcium Sulfonate NLGI #2 Grease be ok? Temp range of -40 to 350F Traveller brand 1028449. Im just using a little 3oz grease gun.
Re: grease in a golf cart clutch [Re: jacobsond] #5196183 08/25/19 11:32 AM
N
NormanBuntz Offline
N
In my 2002 Yamaha gas cart, I use run of the mill multi-purpose lithium grease. It's still runs great after 17 years. Some grease is better than none.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 96K, original owner
2007 Infiniti M35, 115K, original owner
Re: grease in a golf cart clutch [Re: jacobsond] #5196202 08/25/19 11:51 AM
T
tundraotto Offline
T
What is the manufacturers recommended type? Why risk it not working right? I know in my Yamaha Rhino centrifical clutch the specified grease is a specific type, and if its not used - it often doesn't work 100% right
Re: grease in a golf cart clutch [Re: jacobsond] #5196313 08/25/19 02:32 PM
J
J
Its a 1992 cart. The manual does not recommend a specific type. Just trying to figure out what to use when the new sliding sheave arrives. I’m not going to put that 200 degree stuff in. I will use the 350 degree stuff.
