Does anyone have second citizenship?
by Martula - 11/14/19 10:38 PM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
Redline Professional Series 5w20
by burla - 11/14/19 06:00 PM
Backup Camera
by George7941 - 11/14/19 05:26 PM
'11 Prius 15k OCI Amsoil 0W-20
by mdv - 11/14/19 05:16 PM
Lightweight easy up
by Redright9 - 11/14/19 05:00 PM
Thinking of getting a cat
by 53' Stude - 11/14/19 04:42 PM
Apple Watch users
by madRiver - 11/14/19 03:05 PM
It's here, arrived early still 1 week to wait
by BeerCan - 11/14/19 02:20 PM
Cooling leaks at hose to housing connections
by Fitz98 - 11/14/19 12:53 PM
rov137, Dorisy, DesktopDave, HPD, kildeth
69868 Registered Users
57 registered members (14Accent, BeerCan, AndyB, 2003f7, Bailes1992, 5 invisible), 1,345 guests, and 27 spiders.
Topics297,431
Posts5,115,472
Members69,868
Most Online3,589
Nov 2nd, 2019
"MYSTERY Oil" - 320 ppm Zinc #5194517 08/23/19 09:20 AM
L
Linctex Offline OP
L
I like MolaKule's little mystery oil quizzes.
So here is one for y'all - - would you run this in your car or truck?
YES - it is an internal combustion engine oil - - - - Spark ignition, not diesel.
The application might surprise you a bit... or a LOT!
Zinc PPM and Phosphorus PPM don't mean everything in the world of "long engine life" - .
These engines run more hours before overhaul than ANY engine you will ever own.
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194523 08/23/19 09:31 AM
K
kschachn Offline
K
Absolutely not. I am incapable of determining if an oil is suitable for my vehicles based on a VOA or UOA, the only way I can determine that is by whether it carries the specification or approval required by the manufacturer.
I no longer work in a research laboratory, but if I did I bet I could produce a product that gives the same values as in your chart but would wreck you engine in under a minute. For me this is a good illustration of the problem of making an oil choice based on an analysis like that.
1994 BMW 530i, 250K
1996 Honda Accord, 280K
1999 Toyota Sienna, 425K
2000 Toyota ECHO, 284K
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: kschachn] #5194547 08/23/19 09:54 AM
I
Imp4 Offline
I
Hmmm, while you may be incapable of determining suitability, I think the OP's intent is for a good natured brain teaser and nothing more.
Having said that, I'll throw my hat in the ring.
The acid and base numbers appear awfully low, so that provides some hesitation. I'll say 'No' I wouldn't run this in a car or truck.
But there's probably a catch here somewhere that will justify doing so...
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: kschachn] #5194549 08/23/19 09:58 AM
L
Linctex Offline OP
L
I no longer work in a research laboratory, but if I did I bet I could produce a product that gives the same values as in your chart but would wreck you engine in under a minute. .
EXACTLY!!
People around here throw around statements like: "Buy Quaker State Ultimate Durability, it has the most Moly for engine protection!"
Or like: "Don't run the new CK rated oils in a Ford PowerStroke, they don't have enough Zinc and Phosphorus"
I'm waiting for comments like "There's NO WAY I would run that in any engine I own; it doesn't have hardly ANY Zinc and Phosphorus!!"
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Imp4] #5194550 08/23/19 09:59 AM
L
Linctex Offline OP
L
Originally Posted by Imp4
, I think the OP's intent is for a good natured brain teaser and nothing more....
You are 100% correct, sir
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194577 08/23/19 10:28 AM
M
Mad_Hatter Offline
M
While I agree with kschachn (can't believe I said that) that you can't make a determination on OA alone, but I think there's some generalities I can safely say about this lubricant. (if my understanding of stuff isn't all fubar'd)...
-for starters, the reference to "run more hours" leads me to believe this is a commercial engine like in a tractor or something and not a passenger car
-its low VI indicates it's 100% mineral
-its low VI would make it unsuitable for a pcmo where loads change frequently. (lower VI's are more suitable for static loads)
-its low BN would not make it suitable for long drain intervals..so fluid exchange is done on hrs ran
-i would think it's low Phos and Zinc means the oil isn't in service too long, so the levels don't need to be sky high to account for depletion, and maybe this is not a tight tolerance engine type where the oil film thickness is super thin (it's a sae30/40..so it can't be super tight tolerance where a thicker oil with bigger molecules can actually cause wear, can it??)
Ok, go ahead and shred me.. flame 🔥 suit on!
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194579 08/23/19 10:29 AM
dave1251 Offline
It seems this uses organic compounds for antiwear such as ester.
don't use.
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Mad_Hatter] #5194597 08/23/19 10:51 AM
L
Linctex Offline OP
L
It is a stationary commercial engine, yes.
I have never seen the oil get changed in one.
I need to find a more "hands on tech" and ask what the OCI interval is - - - or if there even is one.
There's a device that adds oil from a bulk tank as needed to keep the sump capacity topped off.
Sump capacity is about 10 gallons, with three large oil filters.
Base number is only needed to fight condensation from starts and stops, correct?
These engines never get shut off.
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194600 08/23/19 10:55 AM
dave1251 Offline
Acids are produced during the combustion process.
don't use.
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194663 08/23/19 12:29 PM
B
bullwinkle Offline
B
Is it for a 2-stroke diesel engine, like a Detroit or possibly a locomotive engine? They seem to really like low additive numbers due to the silver bearings.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194666 08/23/19 12:32 PM
B
bullwinkle Offline
B
Oil value is all in the application-there are some awesome synthetic 2-stroke (gas) oils in the world, for racing snowmobiles or motocross, but I wouldn't put them in the sump of a diesel engine!
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194683 08/23/19 12:46 PM
B
bbhero Offline
B
First question is. would you mind this in your car or truck??
No...
Normal zinc and phos are no where near API SN limits. And that is not a good thing. Nor a expected finding if it was tested by say PQIA.
And yes that does matter... Whether you like it or not.....
Why do the PQIA test chart have a expected range for zinc and phos ??
But there is no expected range for say molybdenum ?? Nope. Neither for say titanium... Nope. No expected range for boron... No range for sodium...
So... One can state that in this particular scenario in regards to these two measurable elements... A very low reading clearly indicates something is not good for use in modern vehicles.
Nissan Altima 3.5 Coupe
Cam2 Dexos1 Gen 2 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194684 08/23/19 12:47 PM
A
A_Harman Offline
A
I'd guess it's a 2-stroke locomotive oil.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Linctex] #5194687 08/23/19 12:52 PM
N
Needleman Offline
N
Nat gas low ash
2014 Subaru Legacy 2.5 53k -- Subaru 0W-20/Subaru OEM filter
Re: "MYSTERY Oil" - 320 ppm Zinc [Re: Needleman] #5194693 08/23/19 12:55 PM
L
Linctex Offline OP
L
Originally Posted by Needleman
Nat gas low ash
DING DING DING!!!!
