RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
JDXer, Ivan30, mikespine, Typerguy, showtyme1958
71530 Registered Users
103 registered members (AlienBug, Ag76, AndyB, AandPDan, 2015_PSD, 11 invisible), 2,600 guests, and 52 spiders.
Topics305,899
Posts5,282,406
Members71,530
DIY: Mazda 2.5L Skyactiv Water Pump #5194360 08/23/19 06:03 AM
The Critic Online Crying OP
OP Online Crying
Mazda Skyactiv engines seem to be popular on this site so hopefully this is a helpful DIY.
Replacing the engine water pump on the 2.5’s is very very easy. I think the 2.0 is similar. This job was performed on a 2014 with 125K. The water pump had some coolant staining on the body and there was some splattered coolant (residue) in the adjacent area. This condition had been present for the last 15K. According to the Mazda TSB, this was still passable since there was no active leak but the customer still wanted the pump replaced.
The pump pulley is held on by three 8mm bolts. There is a big hole on the pulley (and a corresponding recess on the pump) where you can insert a bolt and the pulley will lock onto the body. The pump itself is bolted to the engine using 3 10mm bolts. Undo the wire harness clip and the 10mm clamp bolt for the inlet pipe. Pump comes out. The new pump from Mazda, came with the pump gasket pre-installed but the water inlet pipe o-ring is sold separately. You must replace the o-ring.
You will also need a new stretch belt, a new alternator belt and almost two gallons of the Mazda FL22 55/45 pre-mix. Vacuum fill the system, allow the engine to idle for 30-45 min (until the rad fan comes on) with a coolant funnel or with the rad cap off, extract and refill the coolant reservoir and you should be good to go!
Parts needed:
#PEDD-15-010 $119.28
#PE01-15-287 $2.32
#PY01-15-908 (CX-5 2.5L) $20.17
#PY01-15-909A (CX-5 2.5L) $37.48
#0000-77-508E-20 (qty: 2) $25.32/gal
1CDC9589-9AB6-4883-B279-5A472C988C25.jpeg3A9D29C6-C303-4B51-8614-8550282261D0.jpeg57C38DCC-4C7B-47FD-AACD-19490C566017.jpeg5ADC0882-33B2-4F19-B10E-C2842080651A.jpegBE470AE3-0957-4E5E-A919-2B5BBBBA38CF.jpeg
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5194400 08/23/19 07:16 AM
B
BMWTurboDzl Offline
B
Thanks for sharing! I always enjoy reading this stuff.
435i
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5194467 08/23/19 08:54 AM
B
buster Offline
B
Thanks Critic, good write up.
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5194585 08/23/19 11:38 AM
cudavid Offline
Thanks for a good write up Can you offer a followup please?
The stretch belt is new to me , how did you remove and install? Thank you
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: cudavid] #5194589 08/23/19 11:43 AM
OP Online Crying
For removal, you can either cut the belt or pull the belt towards you and rotate the crank pulley simultaneously.
For install, zip-tie the belt to the p/s pulley and slowly turn the crank while ensuring that the belt is walking onto the pulley grooves.
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5194603 08/23/19 12:02 PM
5
50jeffrey Offline
5
If the vehicle is a 2015 or newer, there is no p/s pulley, as the vehicle has electric-assist steering (no pump). Can just zip-tip the belt to the w/p pulley itself.
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5194999 08/23/19 08:49 PM
splinter Offline
Nice!
I autocross my Miata which is indeed a joy on which to twist wrenches.
Upside to competing -besides the fun- is Mazda NA HQ in Irvine supplies all factory replacement hardware at actual dealer cost.
They're a great company with solid hardware imho.
PUP 0W-40
Total Quartz 5W-40
M1 5W-50
Past performance is no guarantee of future results.
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5323293 01/15/20 10:49 AM
J
jayjr1105 Offline
J
Parts needed:
#PE01-15-287 $2.32
What is the bottom half part you're holding in the last pic?
2013 Mazda 3 - PP 0w20
2005 Honda Odyssey - PP HM 5w20
Re: DIY: Mazda 2.5L Skyactiv Water Pump [Re: The Critic] #5323299 01/15/20 10:58 AM
B
bulwnkl Offline
B
Thanks for the write-up!
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
