wix 2019 sienna oil filter cartridge fitment
by s2krunner - 02/23/20 02:19 PM
Urban Carry G3
by Gebo - 02/23/20 02:16 PM
Denso Iridium TT's are great
by jayjr1105 - 02/23/20 01:46 PM
Girl Scout question
by ffhdriver - 02/23/20 01:36 PM
MTD Snowblower issues
by 97prizm - 02/23/20 01:19 PM
OBD scanner
by NH73 - 02/23/20 10:18 AM
Oil additive and effects on oil analysis results
by MoneyJohn - 02/23/20 09:48 AM
More 6.7 PSD engine repairs
by mattd - 02/23/20 09:10 AM
How to get sediment out of heater oil tank?
by BAJA_05 - 02/23/20 08:37 AM
Oil Prices in Europe
by BBDartCA - 02/23/20 08:08 AM
Fury -Wilder 3?
by pbm - 02/23/20 06:41 AM
toro super recycler
by passgas55 - 02/23/20 06:05 AM
Chain style for ag tires
by puma4440 - 02/23/20 04:25 AM
2014 GMC Terrain 2.4L AWD
by Char Baby - 02/23/20 02:06 AM
Conventional VS Synthetic In The Winter Months
by BlueOvalFitter - 02/23/20 01:36 AM
Paint Splatter
by rrretiree7 - 02/23/20 12:54 AM
Lucase483, Chaucha, UofA, Jeffrey78, Markovchain
70788 Registered Users
103 registered members (762fermeandyou, 928, 74Widebody, alchargo, 67ZL1, 13 invisible), 2,709 guests, and 17 spiders.
Topics301,834
Posts5,203,577
Members70,788
Mobil ATF 320 #5191158 08/19/19 09:34 AM
B
BlueSky Offline OP
B
My car says to use Mobil ATF 320 in the power steering unit. The problem is it's impossible to find. Anyone have a source? Is there a substitute I can use?
Thanks in advance to replies.
Re: Mobil ATF 320 [Re: BlueSky] #5191161 08/19/19 09:38 AM
K
kschachn Offline
K
Can you post the entire section about what can be used? It says only that fluid or does it give an acceptable substitute if that is not available?
What car exactly?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: Mobil ATF 320 [Re: BlueSky] #5191201 08/19/19 10:34 AM
U
UG_Passat Offline
U
Google: Mobil ATF 320
and you get:
https://www.mobil.com/English-GB/Passenger-Vehicle-Lube/pds/GLXXMobil-ATF-320
According to ExxonMobil, this product is of the following quality level:
Allison C-4
Ford MERCON
GM DEXRON IIiG
There you have it... substitutes that can be used.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Mobil ATF 320 [Re: UG_Passat] #5191409 08/19/19 03:02 PM
K
kschachn Offline
K
and you get:
Allison C-4
Ford MERCON
GM DEXRON IIiG
I saw that too, but the owner's manual for the vehicle should still list some sort of acceptable substitute.
1994 BMW 530i, 251K
Re: Mobil ATF 320 [Re: UG_Passat] #5191423 08/19/19 03:28 PM
4WD Offline
Prior to Dex VI … I used Mobil 1 MV ATF in several Dex III applications - as did guys towing heavy back in those days.
Pretty high VI despite being called thicker than Dex VI
For a small amount like that it's not that pricey
Re: Mobil ATF 320 [Re: kschachn] #5191722 08/19/19 10:27 PM
U
UG_Passat Offline
U
and you get:
Allison C-4
Ford MERCON
GM DEXRON IIiG
The factory parts ATF would be some sort of acceptable substitute, which may likely be the Mobil ATF 320 in the Vehicle manufacturer's packaging
Re: Mobil ATF 320 [Re: kschachn] #5191743 08/19/19 11:20 PM
B
BlueSky Offline OP
B
The manual exactly says, "Jaguar recommends Mobil ATF320 PAS fluid"
I have a 2015 Jaguar F-Type S V8
Re: Mobil ATF 320 [Re: UG_Passat] #5191745 08/19/19 11:29 PM
B
BlueSky Offline OP
B
I'm a little leery about using a substitute - you know how temperamental Jaguars are...
Re: Mobil ATF 320 [Re: BlueSky] #5191748 08/19/19 11:51 PM
U
UG_Passat Offline
U
Sounds you need to stop by the dealership parts department.
Re: Mobil ATF 320 [Re: UG_Passat] #5192047 08/20/19 12:05 PM
N
nthach Offline
N
And the dealer techs will use Dex III fluid.
Your Jag uses a largely Ford-derived or ZF/Bosch system. Ford calls for Mercon V for their systems. ZF/Bosch wants a fluid on their approved list or Pentosin CHF11S/202.
Re: Mobil ATF 320 [Re: BlueSky] #5201468 08/31/19 01:13 PM
G
gamefoo21 Offline
G
Redline PS Fluid works great in the Beetles power steering and it calls for that viciously expensive CHF fluid.
Re: Mobil ATF 320 [Re: BlueSky] #5201699 08/31/19 07:37 PM
dave1251 Offline
DEXRON/MERCON ATF would be a fine substitute as well as MERCON V.
You can also email XOM and ask for their recommendation.
don't use.
